NRPE++ checkiis - no handler for command: checkiis
Nagios_Admin_M
Re: NRPE++ checkiis - no handler for command: checkiis
Post by Nagios_Admin_M »
c:\program files\nsclient++\scripts\checkiss.vbs(63,1) Microsoft VBScript runtime error: path not found.
Can you provide any details on what you are trying to check on the server?
Is the checkiis.vbs script in that folder?
Nagios_Admin_M
I open up log file and found out that result of checkiis is OK.
Is that the way how I should configure the host file [check_command check_nrpe_checkiis] - it is not working.
use template
host_name host1
service_description www
To run the checkiis.vbs script on the Windows system using the NSClient++ agent, you would have to use the check_nrpe command on the Nagios server to run the command on your Windows server.
If you have the check_nrpe command installed on the Nagios server using the default settings, you would change your service check from
to
check_command check_nrpe!check_nrpe_checkiis
Save the change and restart Nagios.
Try that and if you have any errors, post them so we can view them.
Nagios_Admin_M
I updated the config files. Unfortunately the plugin does not report error when its occurs. As an example I get 403.13 error on IIS:
Current Status: OK
Status Information: I ( 0,4,1,73, 2012-12-17) seem to be doing fine...
At this point, you would have to contact the author of the plugin to see what is needed to run it.
Nagios_Admin_M
I have the same output when I use this command:
check_nrpe -H $HOSTADDRESS$ -p 5666 -c CheckEventLog -a file=system MaxWarn=1 MaxCrit=1 "filter=generated > -100d AND severity = 'error' AND id = 5002"
What would the output be when you are running the CheckEventLog command?
Did you enable the checkeventlog module by adding the following in the nsclient.ini file under the [/modules] section and restart the service?
CheckEventLog = 1
Take a look at these for more details in the NSClient++ agent.
https://docs.nsclient.org/reference/win ... figuration
https://docs.nsclient.org/reference/win ... kEventLog/
Nagios_Admin_M
Everything is set as you wrote.
What is the error message?
