Error: Unexpected token or statement in file
Rhobar
Re: Error: Unexpected token or statement in file
Post by Rhobar »
Hi!
Unfortunately I'm getting the same error as you can see from these:
[root@vmnagios spool]# tail -50 /var/log/mysqld.log
170526 10:24:08  InnoDB: Completed initialization of buffer pool
170526 10:24:08  InnoDB: Started; log sequence number 0 44233
170526 10:24:08 [Note] Event Scheduler: Loaded 0 events
170526 10:24:08 [Note] /usr/libexec/mysqld: ready for connections.
Version: '5.1.73'  socket: '/var/lib/mysql/mysql.sock'  port: 3306  Source distribution
170526 16:22:32 [Note] /usr/libexec/mysqld: Normal shutdown
170526 16:22:32 [Note] Event Scheduler: Purging the queue. 0 events
170526 16:22:32  InnoDB: Starting shutdown...
170526 16:22:34  InnoDB: Shutdown completed; log sequence number 0 44233
170526 16:22:34 [Note] /usr/libexec/mysqld: Shutdown complete
170526 16:22:34 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
170526 16:23:07 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
170526 16:23:07  InnoDB: Initializing buffer pool, size = 8.0M
170526 16:23:07  InnoDB: Completed initialization of buffer pool
170526 16:23:08  InnoDB: Started; log sequence number 0 44233
170526 16:23:08 [Note] Event Scheduler: Loaded 0 events
170526 16:23:08 [Note] /usr/libexec/mysqld: ready for connections.
170526 16:23:58 [Note] /usr/libexec/mysqld: Normal shutdown
170526 16:23:58 [Note] Event Scheduler: Purging the queue. 0 events
170526 16:23:58  InnoDB: Starting shutdown...
170526 16:24:03  InnoDB: Shutdown completed; log sequence number 0 44233
170526 16:24:03 [Note] /usr/libexec/mysqld: Shutdown complete
170526 16:24:03 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
170526 16:24:03 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
170526 16:24:04  InnoDB: Initializing buffer pool, size = 8.0M
170526 16:24:04  InnoDB: Completed initialization of buffer pool
170526 16:24:04  InnoDB: Started; log sequence number 0 44233
170526 16:24:04 [Note] Event Scheduler: Loaded 0 events
170526 16:24:04 [Note] /usr/libexec/mysqld: ready for connections.
170529 10:06:02 [Note] /usr/libexec/mysqld: Normal shutdown
170529 10:06:02 [Note] Event Scheduler: Purging the queue. 0 events
170529 10:06:02  InnoDB: Starting shutdown...
170529 10:06:03  InnoDB: Shutdown completed; log sequence number 0 44233
170529 10:06:03 [Note] /usr/libexec/mysqld: Shutdown complete
170529 10:06:03 mysqld_safe mysqld from pid file /var/run/mysqld/mysqld.pid ended
170529 10:06:03 mysqld_safe Starting mysqld daemon with databases from /var/lib/mysql
170529 10:06:03  InnoDB: Initializing buffer pool, size = 8.0M
170529 10:06:03  InnoDB: Completed initialization of buffer pool
170529 10:06:04  InnoDB: Started; log sequence number 0 44233
170529 10:06:04 [Note] Event Scheduler: Loaded 0 events
170529 10:06:04 [Note] /usr/libexec/mysqld: ready for connections.
[root@vmnagios spool]# grep ndo /var/log/nagios/nagios.log
[1496045193] Error: Could not load module '/usr/local/nagios/bin/ndomod.o' -> /var/log/nagios/spool/checkresults/nebmod9vBoNM: undefined symbol: num_objects
[root@vmnagios spool]# grep ndo /var/log/messages
May 29 10:06:33 vmnagios nagios: Error: Could not load module '/usr/local/nagios/bin/ndomod.o' -> /var/log/nagios/spool/checkresults/nebmod9vBoNM: undefined symbol: num_objects
Edit the nagios.cfg file and change the following line from
broker_module=/usr/local/nagios/bin/ndomod.o config_file=/usr/local/nagios/etc/ndomod.cfg
to
broker_module=/usr/local/nagios/bin/ndomod config_file=/usr/local/nagios/etc/ndomod.cfg
Save the file and restart the nagios daemon, if the correct version of the ndomod is copied over to the /usr/local/nagios/bin/ folder, that should fix the issue for you.
If not, in the src folder where you compiled the ndoutils is a files called ndo2db-3x, copy that file to the /usr/local/nagios/bin/ folder but call it ndomod and reload nagios.
Rhobar
Post by Rhobar »
Finally it works!
I was using a wrond ndomod module :)
Thanks for your precious help
Your welcome, glad it is working now. I'll lock and mark the post as solved but if you have any new questions, please feel free to open a new post.
