Config wizard doesn't detect switch ports
Re: Config wizard doesn't detect switch ports
Have any security sweeps been done on the server? Generally when we see Permission Denied errors, something has been done to the /etc/sudoers file, or changes to the file/directory permissions/ownership have been made.
jericho_g
Post by jericho_g »
No security updates have been done recently. The only update recently was when we upgraded to version 5.4.4.
When the Wizard runs, it creates a temporary file and it looks like the permissions are wrong, run the following as root to delete it.
rm /usr/local/nagiosxi/tmp/mrtg-10.11.36.1*
Then run the wizard and see if the ports are detected when the wizard is run.
jericho_g
Post by jericho_g »
Thanks, I'll try that if it happens next time. We reset ownership of the /usr/local/nagiosxi/tmp directory back to user 'apache' and the config wizard found the ports.
-Jericho
OK, it wasn't the file permissions but the folder's permissions that caused it to fail. Glad it is working now.
