I saw that you had issues changing to the nagios user account and it could be that it has a password assigned to it or that it is expired.
Login as root and run the following to remove the password and reset the account.
[root@lxelkapp] 10:50 # chage -l nagios
Last password change : Aug 04, 2014
Password expires : never
Password inactive : never
Account expires : never
Minimum number of days between password change : -1
Maximum number of days between password change : -1
Number of days of warning before password expires : -1
[root@lxelkapp] 10:50 # grep nag /etc/passwd
nagios:x:496:491::/var/spool/nagios:/sbin/nologin
[root@lxelkapp] 10:50 # grep nag /etc/group
nagios:x:491:nagios
nagcmd:x:10668:nagios
[root@lxelkapp] 10:50 # ls -l /usr/local/nagios/libexec/check_users
-rwxr-xr-x 1 root nagios 136185 May 30 08:12 /usr/local/nagios/libexec/check_users
[root@lxelkapp] 10:50 # uname -a
Linux lxelkapp.tecsys.us 2.6.32-431.23.3.el6.x86_64 #1 SMP Wed Jul 16 06:12:23 EDT 2014 x86_64 x86_64 x86_64 GNU/Linux
[root@lxelkapp] 10:50 # cat /etc/*release*
LSB_VERSION=base-4.0-amd64:base-4.0-noarch:core-4.0-amd64:core-4.0-noarch:graphics-4.0-amd64:graphics-4.0-noarch:printing-4.0-amd64:printing-4.0-noarch
cat: /etc/lsb-release.d: Is a directory
Red Hat Enterprise Linux Server release 6.5 (Santiago)
cpe:/o:redhat:enterprise_linux:6server:ga:server
[root@lxelkapp] 10:51 #
Save the file and see if the check_users plugin functions.
This will give the nagios user account back the ability to login and run the plugins on the server.
tgriep wrote:Try and upgrade the plugins in the remote server by following this KB article and see if that resolves the issue for you. https://support.nagios.com/kb/article/n ... ource.html
Let us know if it works for you.
I installed the plugins manually as was described in article, but the issue steel.
I was hoping that would fix it.
The check_users command does the same functionality as the users command and not the who command.
Can you login to that server, run the following and post the output?
