Nagios core and graphs columns
Re: Nagios core and graphs columns
Unfortunately, I do not. My findings were the result of modifying the html directly using the Chrome dev tools. I'm pretty sure the underlying Javascript is all solid for handling multiple selections, it's just a weird quirk of how the GUI (html side of things) was built.
- Former Nagios Staff
There are some changes coming in how this works, but currently there is a 60-day trial of XI and you can use a free version up to 7 hosts.
At the very least, how we set up pnp in XI might give you some ideas for your Core setup: https://assets.nagios.com/downloads/nag ... -Linux.pdf
One thing about XI vs Core...it'll only work on CentOS or RHEL 6/7, and needs to be on a separate VM than anything else.
