Requested info below...
/etc/sudoers
## Sudoers allows particular users to run various commands as
## the root user, without needing the root password.
## Examples are provided at the bottom of the file for collections
## of related commands, which can then be delegated out to particular
## users or groups.
## This file must be edited with the 'visudo' command.
## Host Aliases
## Groups of machines. You may prefer to use hostnames (perhaps using
## wildcards for entire domains) or IP addresses instead.
# Host_Alias FILESERVERS = fs1, fs2
# Host_Alias MAILSERVERS = smtp, smtp2
## User Aliases
## These aren't often necessary, as you can use regular groups
## (ie, from files, LDAP, NIS, etc) in this file - just use %groupname
## rather than USERALIAS
# User_Alias ADMINS = jsmith, mikem
## Command Aliases
## These are groups of related commands...
## Networking
# Cmnd_Alias NETWORKING = /sbin/route, /sbin/ifconfig, /bin/ping, /sbin/dhclient, /usr/bin/net, /sbin/iptables, /usr/bin/rfcomm, /usr/bin/wvdial, /sbin/iwconfig, /sbin/mii-tool
## Installation and management of software
# Cmnd_Alias SOFTWARE = /bin/rpm, /usr/bin/up2date, /usr/bin/yum
## Services
# Cmnd_Alias SERVICES = /sbin/service, /sbin/chkconfig, /usr/bin/systemctl start, /usr/bin/systemctl stop, /usr/bin/systemctl reload, /usr/bin/systemctl restart, /usr/bin/syste
mctl status, /usr/bin/systemctl enable, /usr/bin/systemctl disable
## Updating the locate database
# Cmnd_Alias LOCATE = /usr/bin/updatedb
## Storage
# Cmnd_Alias STORAGE = /sbin/fdisk, /sbin/sfdisk, /sbin/parted, /sbin/partprobe, /bin/mount, /bin/umount
## Delegating permissions
# Cmnd_Alias DELEGATING = /usr/sbin/visudo, /bin/chown, /bin/chmod, /bin/chgrp
## Processes
# Cmnd_Alias PROCESSES = /bin/nice, /bin/kill, /usr/bin/kill, /usr/bin/killall
## Drivers
# Cmnd_Alias DRIVERS = /sbin/modprobe
# Defaults specification
# Refuse to run if unable to disable echo on the tty.
Defaults !visiblepw
# Preserving HOME has security implications since many programs
# use it when searching for configuration files. Note that HOME
# is already set when the the env_reset option is enabled, so
# this option is only effective for configurations where either
# env_reset is disabled or HOME is present in the env_keep list.
Defaults always_set_home
Defaults env_reset
Defaults env_keep = "COLORS DISPLAY HOSTNAME HISTSIZE KDEDIR LS_COLORS"
Defaults env_keep += "MAIL PS1 PS2 QTDIR USERNAME LANG LC_ADDRESS LC_CTYPE"
Defaults env_keep += "LC_COLLATE LC_IDENTIFICATION LC_MEASUREMENT LC_MESSAGES"
Defaults env_keep += "LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER LC_TELEPHONE"
Defaults env_keep += "LC_TIME LC_ALL LANGUAGE LINGUAS _XKB_CHARSET XAUTHORITY"
# Adding HOME to env_keep may enable a user to run unrestricted
# commands via sudo.
# Defaults env_keep += "HOME"
Defaults secure_path = /sbin:/bin:/usr/sbin:/usr/bin
## Next comes the main part: which users can run what software on
## which machines (the sudoers file can be shared between multiple
## systems).
## Syntax:
## user MACHINE=COMMANDS
## The COMMANDS section may have other options added to it.
## Allow root to run any commands anywhere
root ALL=(ALL) ALL
## Allows members of the 'sys' group to run networking, software,
## service management apps and more.
# %sys ALL = NETWORKING, SOFTWARE, SERVICES, STORAGE, DELEGATING, PROCESSES, LOCATE, DRIVERS
## Allow Ansible to sudo to root
%ansible ALL=(ALL) NOPASSWD: ALL
## Allows people in group wheel to run all commands
#%wheel ALL=(ALL) ALL
## Same thing without a password
%wheel ALL=(ALL) NOPASSWD: ALL
## Allows members of the users group to mount and unmount the
## cdrom as root
# %users ALL=/sbin/mount /mnt/cdrom, /sbin/umount /mnt/cdrom
## Allows members of the users group to shutdown this system
# %users localhost=/sbin/shutdown -h now
## Read drop-in files from /etc/sudoers.d (the # here does not mean a comment)
#includedir /etc/sudoers.d
User_Alias NAGIOSXI=nagios
User_Alias NAGIOSXIWEB=apache
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios checkconfig
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd status
NAGIOSXI ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/upgrade_to_latest.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/change_timezone.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/reset_config_perms.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/backup_xi.sh *
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/messages
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/httpd/error_log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/mysqld.log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXIWEB ALL = NOPASSWD:/etc/init.d/snmptt restart
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/repair_databases.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
grep ramdisk /usr/local/nrdp/server/config.inc.php /usr/local/nagiosxi/html/config.inc.php /etc/fstab
[root@nagios ~]# grep ramdisk /usr/local/nrdp/server/config.inc.php /usr/local/nagiosxi/html/config.inc.php /etc/fstab
/usr/local/nrdp/server/config.inc.php:$cfg["check_results_dir"]="/var/nagiosramdisk/spool/checkresults";
/usr/local/nagiosxi/html/config.inc.php:$cfg['xidpe_dir'] = '/var/nagiosramdisk/spool/xidpe/';
/usr/local/nagiosxi/html/config.inc.php:$cfg['perfdata_spool'] = '/var/nagiosramdisk/spool/perfdata/';
cat /etc/sysconfig/nagios
[root@nagios ~]# cat /etc/sysconfig/nagios
USE_RAMDISK=1
RAMDISK_DIR=/var/nagiosramdisk
RAMDISK_SIZE=1024
if [ "`mount |grep "${RAMDISK_DIR} type tmpfs"`"X == "X" ]; then
mount -t tmpfs -o size=${RAMDISK_SIZE}m tmpfs ${RAMDISK_DIR}
fi
mkdir -p -m 775 ${RAMDISK_DIR} ${RAMDISK_DIR}/tmp ${RAMDISK_DIR}/spool ${RAMDISK_DIR}/spool/checkresults ${RAMDISK_DIR}/spool/xidpe ${RAMDISK_DIR}/spool/perfdata
chown -R nagios:nagios ${RAMDISK_DIR}
cat /etc/init.d/nagios
[root@nagios ~]# cat /etc/init.d/nagios
#!/bin/sh
# chkconfig: 345 99 01
# description: Nagios network monitor
# processname: nagios
# pidfile: /usr/local/nagios/var/nagios.lock
# File : nagios
# Author : Jorge Sanchez Aymar ([email protected])
# Changelog :
# 1999-07-09 Karl DeBisschop <[email protected]>
# - setup for autoconf
# - add reload function
# 1999-08-06 Ethan Galstad <[email protected]>
# - Added configuration info for use with RedHat's chkconfig tool
# per Fran Boon's suggestion
# 1999-08-13 Jim Popovitch <[email protected]>
# - added variable for nagios/var directory
# - cd into nagios/var directory before creating tmp files on startup
# 1999-08-16 Ethan Galstad <[email protected]>
# - Added test for rc.d directory as suggested by Karl DeBisschop
# 2000-07-23 Karl DeBisschop <[email protected]>
# - Clean out redhat macros and other dependencies
# 2003-01-11 Ethan Galstad <[email protected]>
# - Updated su syntax (Gary Miller)
# Description: Starts and stops the Nagios monitor
# used to provide network services status.
### BEGIN INIT INFO
# Provides: nagios
# Required-Start: $local_fs $syslog $network
# Required-Stop: $local_fs $syslog $network
# Short-Description: Starts and stops the Nagios monitoring server
# Description: Starts and stops the Nagios monitoring server
### END INIT INFO
# Our install-time configuration.
prefix=/usr/local/nagios
exec_prefix=${prefix}
NagiosBin=${exec_prefix}/bin/nagios
NagiosCfgFile=${prefix}/etc/nagios.cfg
NagiosCfgtestFile=${prefix}/var/nagios.configtest
NagiosStatusFile=${prefix}/var/status.dat
NagiosRetentionFile=${prefix}/var/retention.dat
NagiosCommandFile=${prefix}/var/rw/nagios.cmd
NagiosVarDir=${prefix}/var
NagiosRunFile=${prefix}/var/nagios.lock
NagiosLockDir=/usr/local/nagiosxi/var/subsys
#NagiosLockDir=/var/lock/subsys
NagiosLockFile=nagios
NagiosCGIDir=${exec_prefix}/sbin
NagiosUser=nagios
NagiosGroup=nagios
checkconfig="true"
# Source function library
# Some *nix do not have an rc.d directory, so do a test first
if [ -f /etc/rc.d/init.d/functions ]; then
. /etc/rc.d/init.d/functions
elif [ -f /etc/init.d/functions ]; then
. /etc/init.d/functions
elif [ -f /lib/lsb/init-functions ]; then
. /lib/lsb/init-functions
fi
# Load any extra environment variables for Nagios and its plugins.
if test -f /etc/sysconfig/nagios; then
. /etc/sysconfig/nagios
fi
# Automate addition of RAMDISK based on environment variables
USE_RAMDISK=${USE_RAMDISK:-0}
if test "$USE_RAMDISK" -ne 0 && test "$RAMDISK_SIZE"X != "X"; then
ramdisk=`mount |grep "${RAMDISK_DIR} type tmpfs"`
if [ "$ramdisk"X == "X" ]; then
mkdir -p -m 0755 ${RAMDISK_DIR}
mkdir -p -m 0755 ${RAMDISK_DIR}/checkresults
chown -R $NagiosUser:$NagiosGroup ${RAMDISK_DIR}
fi
fi
check_config ()
TMPFILE=$(mktemp /tmp/.configtest.XXXXXXXX)
$NagiosBin -vp $NagiosCfgFile > "$TMPFILE"
WARN=`grep ^"Total Warnings:" "$TMPFILE" |awk -F: '{print \$2}' |sed s/' '//g`
ERR=`grep ^"Total Errors:" "$TMPFILE" |awk -F: '{print \$2}' |sed s/' '//g`
if test "$WARN" = "0" && test "${ERR}" = "0"; then
echo "OK - Configuration check verified" > $NagiosCfgtestFile
chmod 0644 $NagiosCfgtestFile
chown $NagiosUser:$NagiosGroup $NagiosCfgtestFile
/bin/rm "$TMPFILE"
return 0
elif test "${ERR}" = "0"; then
# Write the errors to a file we can have a script watching for.
echo "WARNING: Warnings in config files - see log for details: $NagiosCfgtestFile" > $NagiosCfgtestFile
egrep -i "(^warning|^error)" "$TMPFILE" >> $NagiosCfgtestFile
/bin/rm "$TMPFILE"
return 0
else
echo "ERROR: Errors in config files - see log for details: $NagiosCfgtestFile" > $NagiosCfgtestFile
cat "$TMPFILE"
exit 8
fi
status_nagios ()
if test -x $NagiosCGI/daemonchk.cgi; then
if $NagiosCGI/daemonchk.cgi -l $NagiosRunFile > /dev/null 2>&1; then return 0; fi
else
if ps -p $NagiosPID > /dev/null 2>&1; then return 0; fi
fi
return 1
printstatus_nagios ()
if status_nagios; then
echo "nagios (pid $NagiosPID) is running..."
else
echo "nagios is not running"
exit 3
fi
killproc_nagios ()
kill -s "$1" $NagiosPID
pid_nagios ()
if test ! -f $NagiosRunFile; then
echo "No lock file found in $NagiosRunFile"
exit 3
fi
NagiosPID=`head -n 1 $NagiosRunFile`
# Check that nagios exists.
if [ ! -f $NagiosBin ]; then
echo "Executable file $NagiosBin not found. Exiting."
exit 1
fi
# Check that nagios.cfg exists.
if [ ! -f $NagiosCfgFile ]; then
echo "Configuration file $NagiosCfgFile not found. Exiting."
exit 1
fi
# See how we were called.
case "$1" in
start)
echo -n "Starting nagios:"
if test "$checkconfig" = "true"; then
check_config
# check_config exits on configuration errors.
fi
if test -f $NagiosRunFile; then
echo " another instance of nagios is already running."
exit 0
fi
fi
touch $NagiosVarDir/nagios.log $NagiosRetentionFile
rm -f $NagiosCommandFile
touch $NagiosRunFile
chown $NagiosUser:$NagiosGroup $NagiosRunFile $NagiosVarDir/nagios.log $NagiosRetentionFile
chmod g+r $NagiosVarDir/nagios.log
USER=$NagiosUser G_BROKEN_FILENAMES=1 SSH_TTY=/dev/pts/0 $NagiosBin -d $NagiosCfgFile
if [ -d $NagiosLockDir ]; then touch $NagiosLockDir/$NagiosLockFile; fi
service snmptt restart &>/dev/null ||:
echo " done."
stop)
echo -n "Stopping nagios:"
pid_nagios
killproc_nagios TERM
# now we have to wait for nagios to exit and remove its
# own NagiosRunFile, otherwise a following "start" could
# happen, and then the exiting nagios will remove the
# new NagiosRunFile, allowing multiple nagios daemons
# to (sooner or later) run - John Sellens
#echo -n 'Waiting for nagios to exit .'
for i in 1 2 3 4 5 6 7 8 9 10 ; do
if status_nagios > /dev/null; then
echo -n '.'
sleep 1
else
break
fi
done
echo ''
echo 'Warning - nagios did not exit in a timely manner'
else
echo ' done.'
fi
rm -f $NagiosStatusFile $NagiosRunFile $NagiosLockDir/$NagiosLockFile $NagiosCommandFile
status)
pid_nagios
printstatus_nagios
checkconfig)
printf "Running configuration check...\n"
check_config
fi
if [ $? -eq 0 ]; then
echo " OK."
else
echo " CONFIG ERROR! Check your Nagios configuration."
exit 1
fi
restart)
check_config
fi
$0 stop
$0 start
reload|force-reload)
check_config
fi
$0 start
else
pid_nagios
printf "Reloading nagios configuration...\n"
killproc_nagios HUP
echo "done"
else
$0 stop
$0 start
fi
fi
configtest)
echo "Usage: nagios {start|stop|restart|reload|force-reload|status|checkconfig|configtest}"
exit 1
esac
# End of this script
