check_snmp_storage doesn't check all FS
emi65
Re: check_snmp_storage doesn't check all FS
Post by emi65 »
Now I understood !!!
Do you know if there is a way to change the block size values used in the SNMP information ???
Emilio
I think the problem is a rounding issue with the df command.
The output shows that the partition does have some free space and it is not at 100% used.
Try running the df command like the example below using 4048 as the block size.
df -B 4096
