Nagios stopped sending alerts after rebooting nagios server
[email protected]
Re: Nagios stopped sending alerts after rebooting nagios ser
Post by [email protected] »
FYI ,All settings are perfect. We are even getting test alert messages to our phone . But we are not getting automated alerts when host or service goes down
We would have to see your System Profile and the output of the commands from my previous post to continue on with the troubleshooting.
You could try this KB article to see if you can resolve the Profile Build Failure.
https://support.nagios.com/kb/article/n ... ailed.html
If this article does not work for you, can you run the following as root and post the output?
ls -l /usr/local/nagiosxi/var/components/
ls -l /usr/local/nagiosxi/var/components/profile/
If you are using a SMTP server to forward the emails, can you login to it and check the logs to see if they are getting blocked?
[email protected]
Output of
[ec2-user@ip-172-31-21-217 ~]$ ls -l /usr/local/nagiosxi/var/components/
total 20
-rwxrwxr-x 1 apache nagios 25 Nov 23 2016 bpi.log
-rw-r--r-- 1 apache nagios 9440 May 4 09:57 capacityplanning.log
drwxr-sr-x 2 apache nagios 4096 Jun 23 13:15 profile
[ec2-user@ip-172-31-21-217 ~]$ ls -l /usr/local/nagiosxi/var/components/profile/
total 0
-rw-r--r-- 1 apache nagios 0 Jun 23 15:48 profile.txt
Please run the following commands as root and post the /tmp/info.txt file.
echo 'select * from xi_users;' | mysql -u root -pnagiosxi nagiosxi -t >/tmp/info.txt
echo 'select * from xi_usermeta;' | mysql -u root -pnagiosxi nagiosxi -t >>/tmp/info.txt
[email protected]
Out put of first command
[ec2-user@ip-172-31-21-217 ~]$ echo 'select * from xi_users;' | mysql -u root -pnagiosxi nagiosxi -t >/tmp/info.txt
[ec2-user@ip-172-31-21-217 ~]$ cat /tmp/info.txt
| user_id | username | password | name | email | backend_ticket | enabled |
| 1 | nagiosadmin | 0eb0a38cfbcf77985e4d281b78cc3336 | Nagios Administrator | [email protected] | lr8mq8tm | 1 |
| 2 | [email protected] | 0d57a5971168b9c8aa2cc7abc60aff9f | Naveen | [email protected] | dlnqr96k9v4rua3atav66u3p4lo4gnurajj5ron5mqvi4vpuam4fl66ootr6jn0s | 1 |
| 3 | [email protected] | b96896a1fa505b72a5dccfb615837b35 | Chandra Pedapudi | [email protected] | l3ukpvkco3oerrf6ea9c84oqfqs3rjhgle2ddjo5mggh9ukm7sveuo8bg5cblso8 | 1 |
| 5 | [email protected] | 4978e99307f68bb6346c35291c6f669d | Rajesh Basa | [email protected] | rvtbg6io03iq05bgs452nt7h2otoeiu9hqhut3mt36n4b0h72j7ogd8h557gm3n5 | 1 |
| 7 | [email protected] | 9178b9555df697232cf7344df79b7916 | Chakrapani | [email protected] | qpklp7kteaah8093o490nkggnmh92lipe4e5a02la94f9chuepv3bdi33292korv | 1 |
| 8 | [email protected] | 95b32c5044eeed503f9e81a6e578d915 | Sai Kuppam | [email protected] | 5eidarj653b3i0a64qqonckljjntqhcuut99mpeprmpem4hqrbgin25alr8fbhb9 | 1 |
| 10 | [email protected] | b56e0b4ea4962283bee762525c2d490f | John Anto | [email protected] | 4itldj7sfubojvr2jjhrq58t2j649q6aa0ukj4e2vppiokhc6v5t4aq3st73ncbv | 1 |
Attached second command output as info.txt
The settings seem to be correct for the following user accounts.
Naveen
Sai Kuppam
John Anto
These accounts the SMS notifications are not enabled so they will have to login to the server and enable the SMS Notification Method.
Chandra Pedapudi
Rajesh Basa
Chakrapani
Login to the XI GUI and go to the Home > Notification menu and verify that the user's SMS notification was sent when the host or service was down, etc....
If you see the entry that the Notification was sent but never received, login as root to the Nagios server and check this log files for any errors on why it was not sent.
/usr/local/nagiosxi/tmp/phpmailer.log
If you need any help on the errors, post them here.
