All this checks are running in 5 minutes interval, and all checks are related with network devices(Mikrotik, Cisco). So there is a lot snmp status checks, and also bandwidth checks, mostly generated by Nagios network wizard. When i speak about logged in users, i can't decrease number of users that log in to Nagios because mostly that's on call support users and they need Nagios XI GUI to search for hosts, as they need to troubleshoot possible problems with host according to they calls and tickets.
Also they do not run any report from 09-17, so i can exclude this thing. I will upgrade CPUs/Cores up to 8 and see load results after that.
Nagios XI CPU Load Problem
Re: Nagios XI CPU Load Problem
If moving to 8 cores doesn't help we will likely need a system profile Admin -> System Profile in order to look further.
You can lock the topic, upgrade cpu to 8 cores resolved the problem, now everything is fine.
bolson
Closing topic as resolved.
Thank you for using the Nagios Support Forum.
