ERROR: rsyslog configuration check failed.
Kumar_pinkesh
Re: ERROR: rsyslog configuration check failed.
output is below :
# rsyslogd -f /etc/rsyslog.conf -N 1
rsyslogd: invalid option -- N
usage: rsyslogd [-46AdhqQvw] [-l hostlist] [-m markinterval] [-n] [-p path]
[-s domainlist] [-r[port]] [-tport[,max-sessions]] [-gport[,max-sessions]] [-f conffile] [-i pidfile] [-x]
I've attached a script that has the "-N 1" option removed since it doesn't appear your version of rsyslog supports it.
Kumar_pinkesh
I have removed "N -1" and tested still same error
# bash setup-linux.sh -s 172.50.50.6 -p 5544
Detected rsyslog 2.0.6
Detected rsyslog work directory /var/spool/rsyslog
Destination Log Server: 172.25.25.6:5544
Creating /etc/rsyslog.d/99-nagioslogserver.conf. . .
ERROR: rsyslog configuration check failed.Re: ERROR: rsyslog configuration check failed.
Try this instead. The previous one was failing because it was trying to start an already running service. This one comments out the section responsible for the check.
Kumar_pinkesh
Now I have upgraded the rsyslog version from 2.0.6 to 3.22.1 and now file execution is successful.
But still I cant see the logs on nagios log server and same time if I am checking port status for serveras well as client , both are unused/free.
Detected rsyslog 3.22.1
Destination Log Server: 172.50.50.6:5544
Creating /etc/rsyslog.d/99-nagioslogserver.conf...
rsyslog configuration check passed.
Restarting rsyslog service with 'service'...
Shutting down system logger: [ OK ]
Starting system logger: [ OK ]
Okay.
rsyslog is running with the new configuration.
Visit your Nagios Log Server dashboard to verify that logs are being received.
# netstat -an | grep 5544 : port is free , no connection established
# netstat -an | grep 514 : port is free , no connection established
setup-Linux.shBut still I cant see the logs on nagios log server and same time if I am checking port status for server
5544Code: Select all
514# bash setup-linux.sh -s 172.50.50.6 -p 5544
Okay.
Glad to hear you were able to get that upgraded
Verify that you have an input that is active and configured to use 5544 under Administration > Global Configuration. There should be a default input that looks like:
syslog {
type => 'syslog'
port => 5544
On the same page you'll see a Verify button. Click that to make sure the config is ok.
Finally, try running:
while on another terminal restarting the logstash service:
Take note of any errors this may log in the logstash.log.
syslog {
type => 'syslog'
port => 5544
tail -f /var/log/logstash/logstash.log Code: Select all
service logstash restartAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Kumar_pinkesh
configuration on log server is fine and verification is also ok.
syslog {
type => 'syslog'
port => 5544
After service logstash restart , i can see below logs :
{:timestamp=>"2017-07-10T12:52:42.970000+0000", :message=>"Received an event that has a different character encoding than you configured.", :text=>"\\xFF\\xED\\xFF\\xFD\\u0006\\xFF\\xED\\xFF\\xFD\\u0006\\xFF\\xED\\xFF\\xFD\\u0006\\xFF\\xED\\xFF\\xFD\\u0006\\xFF\\xED\\xFF\\xFD\\u0006\\xFF\\xED\\xFF\\xFD\\u0006\\xFF\\xED\\xFF\\xFD\\u0006", :expected_charset=>"UTF-8", :level=>:warn}
{:timestamp=>"2017-07-17T06:45:39.986000+0000", :message=>"SIGTERM received. Shutting down the pipeline.", :level=>:warn}
But still same issue , logs are not moving to log server. And 5544 port status is not in use as well.
syslog {
type => 'syslog'
port => 5544
What sorts of machines are you having send their logs to Nagios Log Server currently?
Are any of these machines using an encoding other than:
For Linux:
https://support.nagios.com/forum/viewto ... 14#p219978
For Linux:
- UTF-8
- CP-1252
Kumar_pinkesh
all servers having encoding method : UTF-8 only.
Here when I tried to telnet 5544 from client machine then connection go established and same host can be seen on dashboard .and logs also can be found.
but as per the normal process , automatically log server should listen the port and connection shouldd be established then only log will move, not using telnet.
There could be another machine sending to this port.
Try reconfiguring /etc/rsyslog.d/99-nagioslogserver.conf. . . to use port 5545 instead and add a source on NLS under Administration > Global > Global Configuration > Inputs, that looks like:
syslog {
type => 'syslog'
port => 5545
syslog {
type => 'syslog'
port => 5545
