ERROR: Description Table: Request table is empty or does not
Re: ERROR: Description Table: Request table is empty or does
You may need to contact Brocade for more information on what OID's need to be polled to gather that information.
sarfarosh
Post by sarfarosh »
Hi tgriep,
Below is the SNMP & OID config.
sh service snmp
snmp {
community r0m1s2o3u4 {
authorization ro
client 172.16.100.21
client 172.17.131.1
client 172.18.120.222
client 172.17.131.124
client 172.17.131.178
client 172.17.131.179
client 172.17.131.122
client 172.17.131.100
client 172.16.100.28
client 172.18.130.221
contact [email protected]
location DATACENTER-1stFLOOR-CC4-PUNE-MAHARASHTRA-INDIA
notification {
bgp {
all
trap-source 125.18.106.147
trap-target 172.16.100.21
trap-target 172.16.100.28
trap-target 172.17.131.1
trap-target 172.17.131.100
trap-target 172.17.131.122
trap-target 172.17.131.124
trap-target 172.17.131.178
trap-target 172.17.131.179
trap-target 172.18.120.222
trap-target 172.18.130.221
v3 {
group readonly {
seclevel auth
view readview
user netmon {
auth {
plaintext-key "********"
type md5
privacy {
type des
view readview {
oid 1.3.6.1.2.1.4
I think you need to specify the specific OIDs you need to poll on the device.
Also, you may need to setup the firewall to allow the Nagios server to poll the Brocade server.
I suggest going to Brocade's site and search there and see if you can find a document on enabling SNMP on your device.
http://www.brocade.com/en.html
sarfarosh
Post by sarfarosh »
Hi tgriep,
I have came across configuring the Firewall Device. I am configuring it with check_nwc_health and its working fine for interface-errors and uptime but for memory-usage, cpu-load and hardware-health, its not fetching data and exits with output : Mode memory-usage not implemented for this type of device. Please guide me what can be done here.
Make&Model - Fortigate 300D.
CPU Usage - .1.3.6.1.4.1.12356.101.4.1.3.0
snmpget -v2c -cENS-SNMP 192.168.30.1 .1.3.6.1.4.1.12356.101.4.1.3.0
output - SNMPv2-SMI::enterprises.12356.101.4.1.3.0 = Gauge32: 2
Memory Usage - .1.3.6.1.4.1.12356.101.4.1.4.0
snmpget -v2c -cENS-SNMP 192.168.30.1 .1.3.6.1.4.1.12356.101.4.1.4.0
output - SNMPv2-SMI::enterprises.12356.101.4.1.4.0 = Gauge32: 71
I would guess that the plugin is having problems identifying your device so you would need to specify it in the check_nwc_health command like the example below
--servertype Fortigate
sarfarosh
Post by sarfarosh »
Hi tgriep,
Thank you. that worked for me.
bolson
Post by bolson »
Closing this topic as resolved.
Thank you for visiting the Nagios Support Forum!
