unable to login using nagiosadmin account
Re: unable to login using nagiosadmin account
Okay, so, for fun, what happens if you reboot the box and try to log in?
For Eloyd
[root@IWKSEUWPSSNLS01 ~]# df -k
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 619273992 428618868 159205396 73% /
udev 15390940 112 15390828 1% /dev
tmpfs 15411524 0 15411524 0% /dev/shm
/dev/xvde1 619273992 428618868 159205396 73% /
none 15411524 0 15411524 0% /dev/shm
[root@IWKSEUWPSSNLS01 ~]# free -k
total used free shared buffers cached
Mem: 30823048 30674140 148908 204 129196 12346204
-/+ buffers/cache: 18198740 12624308
Swap: 262136 1780 260356
Reboot did not help, still same issue. Unable to login
I'd still be interested to see the full contents of this file:
Something definitely busted the nagioslogserver index, which is where user information (among other things) is stored. It can be rebuilt from scratch with a new user; It's just a huge pain in the butt.
You might try to restore from a previous backup using this script:
The backups are typically kept somewhere in the /store path. Basically, you provide a backup to that script (the full path to the backup) as an argument and execute it.
/var/log/elasticsearch/0418383b-07ee-4161-ad5b-e7d7e3b1e9d8.logYou might try to restore from a previous backup using this script:
/usr/local/nagioslogserver/scripts/restore_backup.shFormer Nagios employee
- Former Nagios Staff
Assuming you want to go the restore route...
Basically, it should look something like the following:
Change the file name and file path accordingly.
/usr/local/nagioslogserver/scripts/restore_backup.sh /store/backups/nagioslogserver/nagioslogserver.2015-01-21.123456789.tar.gzRe: unable to login using nagiosadmin account
Before we restore, I would like to tell you that the disk space was increased on this server by remounting the root volume from 400Gb to 600Gb and then resize2fs /dev/xvde1
[root@IWKSEUWPSSNLS01 ec2-user]# resize2fs /dev/xvde1
resize2fs 1.41.12 (17-May-2010)
Filesystem at /dev/xvde1 is mounted on /; on-line resizing required
old desc_blocks = 25, new_desc_blocks = 38
Performing an on-line resize of /dev/xvde1 to 157286400 (4k) blocks.
If you wanted to wait to do the restore you could attach /var/log/elasticsearch/0418383b-07ee-4161-ad5b-e7d7e3b1e9d8.log.
Otherwise, let us know if the restore resolves your issue.
Log attached for review
Attached here
