Issues with check_iostat
Re: Issues with check_iostat
Thanks @mcapra for the help.
You may also want to take a look at the following link for an explanation on the "No more variables left in this MIB View (It is past the end of the MIB tree)" message
https://stackoverflow.com/questions/146 ... mean-linux
In simple terms, it says that the device you are polling is not responding to that OID because it is not setup to respond to it or that the system doesn't have the OID available as it uses a different OID.
Hauru
Post by Hauru »
Thank you both of you for your help.
I removed "-V systemonly " of this, as your link suggest @tgriep :
rocommunity public default -V systemonly
this command is now working :
snmpwalk -v1 X.X.X.X -c public 1.3.6.1.4.1.2021.13.15.1
and return this :
iso.3.6.1.4.1.2021.13.15.1.1.1.1 = INTEGER: 1
iso.3.6.1.4.1.2021.13.15.1.1.1.2 = INTEGER: 2
iso.3.6.1.4.1.2021.13.15.1.1.1.3 = INTEGER: 3
iso.3.6.1.4.1.2021.13.15.1.1.1.4 = INTEGER: 4
iso.3.6.1.4.1.2021.13.15.1.1.1.5 = INTEGER: 5
iso.3.6.1.4.1.2021.13.15.1.1.1.6 = INTEGER: 6
iso.3.6.1.4.1.2021.13.15.1.1.1.7 = INTEGER: 7
iso.3.6.1.4.1.2021.13.15.1.1.2.1 = STRING: "sdb"
iso.3.6.1.4.1.2021.13.15.1.1.2.2 = STRING: "sdb1"
iso.3.6.1.4.1.2021.13.15.1.1.2.3 = STRING: "sda"
iso.3.6.1.4.1.2021.13.15.1.1.2.4 = STRING: "sda1"
iso.3.6.1.4.1.2021.13.15.1.1.2.5 = STRING: "sda2"
iso.3.6.1.4.1.2021.13.15.1.1.2.6 = STRING: "sda5"
iso.3.6.1.4.1.2021.13.15.1.1.2.7 = STRING: "sr0"
iso.3.6.1.4.1.2021.13.15.1.1.3.1 = Counter32: 1892352
iso.3.6.1.4.1.2021.13.15.1.1.3.2 = Counter32: 868352
iso.3.6.1.4.1.2021.13.15.1.1.3.3 = Counter32: 308947968
iso.3.6.1.4.1.2021.13.15.1.1.3.4 = Counter32: 307016704
iso.3.6.1.4.1.2021.13.15.1.1.3.5 = Counter32: 6144
iso.3.6.1.4.1.2021.13.15.1.1.3.6 = Counter32: 987136
iso.3.6.1.4.1.2021.13.15.1.1.3.7 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.4.1 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.4.2 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.4.3 = Counter32: 299184128
iso.3.6.1.4.1.2021.13.15.1.1.4.4 = Counter32: 299184128
iso.3.6.1.4.1.2021.13.15.1.1.4.5 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.4.6 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.4.7 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.5.1 = Counter32: 239
iso.3.6.1.4.1.2021.13.15.1.1.5.2 = Counter32: 102
iso.3.6.1.4.1.2021.13.15.1.1.5.3 = Counter32: 8601
iso.3.6.1.4.1.2021.13.15.1.1.5.4 = Counter32: 8380
iso.3.6.1.4.1.2021.13.15.1.1.5.5 = Counter32: 2
iso.3.6.1.4.1.2021.13.15.1.1.5.6 = Counter32: 100
iso.3.6.1.4.1.2021.13.15.1.1.5.7 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.6.1 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.6.2 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.6.3 = Counter32: 4011113
iso.3.6.1.4.1.2021.13.15.1.1.6.4 = Counter32: 4011113
iso.3.6.1.4.1.2021.13.15.1.1.6.5 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.6.6 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.6.7 = Counter32: 0
iso.3.6.1.4.1.2021.13.15.1.1.9.1 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.9.2 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.9.3 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.9.4 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.9.5 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.9.6 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.9.7 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.10.1 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.10.2 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.10.3 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.10.4 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.10.5 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.10.6 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.10.7 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.11.1 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.11.2 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.11.3 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.11.4 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.11.5 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.11.6 = INTEGER: 0
iso.3.6.1.4.1.2021.13.15.1.1.11.7 = INTEGER: 0
But I still have the same problem when I run my command, it doesn't find the disk.
Concerning Windows, I think yes I will give up, because I can not use NSClient++. Thank you for your help anyway :)
It is probably because the system only responds to SNMP version 1 so you would have to change the command to use that. Try this to see if that is true.
/usr/local/nagios/libexec/check_diskio_ucd.pl -H X.X.X.X -C community -s 1 -d sdb1 -w 30 -c 50
Hauru
Post by Hauru »
tgriep wrote:It is probably because the system only responds to SNMP version 1 so you would have to change the command to use that. Try this to see if that is true.
And... It finnaly works ! Thank you for your help and your patience, I think you can close this thread :)
bolson
Post by bolson »
Closing topic as resolved.
Thank you for using the Nagios Support Forum.
