I was put back the contents that, but not work.tgriep wrote:Lets but back the php.conf file back to it's default settings and see if that fixes the issue.
Edit this file
/etc/httpd/conf.d/php.conf
And put back the contents back to the following.
Upgrade NagiosXI from 5.4.6 to 5.4.7 Failed
Re: Upgrade NagiosXI from 5.4.6 to 5.4.7 Failed
Lets try this, edit the /etc/php.ini file and change this line from
to
Save the file and restart Apache by running
service httpd restart
Then try the manual upgrade procedure and it is fails, post the error message as well as the upgrade.log file.
And, post the output of this command as well.
upload_max_filesize = 2MCode: Select all
upload_max_filesize = 10Mservice httpd restart
ls -l /tmp/nagiosxi/nagiosxi/basedir/html/includes/Be sure to check out our Knowledgebase for helpful articles and solutions!
Manual upgrade procedure and it was fails
the upgrade.log file:
error message:
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib64/php/modules/ixed.5.6.lin
Sourceguardian extension found for PHP version 5.6
Sourceguardian extension already in php.ini
Stopping httpd: [ OK ]
Starting httpd: [ OK ]
PHP Fatal error: Allowed memory size of 4294967296 bytes exhausted (tried to allocate 4294902125 bytes) in /tmp/nagiosxi/nagiosxi/basedir/html/includes/dbl.inc.php on line 2Code: Select all
[root@nagios nagiosxi]# ls -l /tmp/nagiosxi/nagiosxi/basedir/html/includes/
total 3636
-rwxr-xr-x 1 root root 5980 Jul 10 22:54 auth.inc.php
-rwxr-xr-x 1 root root 807 Jul 10 22:54 common.inc.php
drwxr-xr-x 59 root root 4096 Jul 10 22:54 components
-rwxr-xr-x 1 root root 1060 Jul 10 22:54 components.inc.php
drwxr-xr-x 62 root root 4096 Jul 10 22:54 configwizards
-rwxr-xr-x 1 root root 619 Jul 10 22:54 configwizards.inc.php
-rwxr-xr-x 1 root root 21991 Jul 10 22:54 constants.inc.php
-rwxr-xr-x 1 root root 24962 Jul 10 22:54 constants-nagioscore.inc.php
drwxr-xr-x 3 root root 4096 Jul 10 22:54 css
drwxr-xr-x 10 root root 4096 Jul 10 22:54 dashlets
-rwxr-xr-x 1 root root 680 Jul 10 22:54 dashlets.inc.php
-rwxr-xr-x 1 root root 315257 Jul 10 22:54 dbauth.inc.php
-rwxr-xr-x 1 root root 16234 Jul 10 22:54 db.inc.php
-rwxr-xr-x 1 root root 133733 Jul 10 22:54 dbl.inc.php
-rwxr-xr-x 1 root root 763 Jul 10 22:54 errors.inc.php
drwxr-xr-x 2 root root 4096 Jul 10 22:54 fonts
-rwxr-xr-x 1 root root 56 Jul 10 22:54 footer-child.inc.php
-rwxr-xr-x 1 root root 7409 Jul 10 22:54 footer.inc.php
drwxr-xr-x 5 root root 4096 Jul 10 22:54 fpdf
-rwxr-xr-x 1 root root 564 Jul 10 22:54 header-child.inc.php
-rwxr-xr-x 1 root root 20209 Jul 10 22:54 header.inc.php
drwxr-xr-x 6 root root 4096 Jul 10 22:54 js
drwxr-xr-x 3 root root 4096 Jul 10 22:54 lang
-rwxr-xr-x 1 root root 163 Jul 10 22:54 notificationmethods.inc.php
-rw-r--r-- 1 root root 17905 Jul 10 22:54 page-default-splash.php
-rwxr-xr-x 1 root root 2428 Jul 10 22:54 page-home-main.php
-rwxr-xr-x 1 root root 824 Jul 10 22:54 page-home.php
-rwxr-xr-x 1 root root 835 Jul 10 22:54 page-missing.php
-rwxr-xr-x 1 root root 31246 Jul 10 22:54 pageparts.inc.php
drwxr-xr-x 2 root root 4096 Jul 10 22:54 phpmailer
-rwxr-xr-x 1 root root 3495 Jul 10 22:54 utils-auditlog.inc.php
-rwxr-xr-x 1 root root 80645 Jul 10 22:54 utils-backend.inc.php
-rwxr-xr-x 1 root root 13373 Jul 10 22:54 utils-ccm.inc.php
-rwxr-xr-x 1 root root 40313 Jul 10 22:54 utils-commands.inc.php
-rwxr-xr-x 1 root root 3797 Jul 10 22:54 utils-components.inc.php
-rwxr-xr-x 1 root root 12064 Jul 10 22:54 utils-configwizards.inc.php
-rwxr-xr-x 1 root root 177657 Jul 10 22:54 utils-dashboards.inc.php
-rwxr-xr-x 1 root root 143621 Jul 10 22:54 utils-dashlets.inc.php
-rwxr-xr-x 1 root root 6408 Jul 10 22:54 utils-email.inc.php
-rwxr-xr-x 1 root root 27577 Jul 10 22:54 utils-events.inc.php
-rwxr-xr-x 1 root root 2036 Jul 10 22:54 utils-graphtemplates.inc.php
-rwxr-xr-x 1 root root 38115 Jul 10 22:54 utils.inc.php
-rw-r--r-- 1 root root 253049 Jul 10 22:54 utilsl-data.inc.php
-rw-r--r-- 1 root root 215909 Jul 10 22:54 utilsl-helpers.inc.php
-rwxr-xr-x 1 root root 751601 Jul 10 22:54 utilsl.inc.php
-rwxr-xr-x 1 root root 9328 Jul 10 22:54 utils-links.inc.php
-rw-r--r-- 1 root root 109189 Jul 10 22:54 utils-macros.inc.php
-rwxr-xr-x 1 root root 75864 Jul 10 22:54 utils-menu.inc.php
-rwxr-xr-x 1 root root 27445 Jul 10 22:54 utils-metrics.inc.php
-rwxr-xr-x 1 root root 1998 Jul 10 22:54 utils-mibs.inc.php
-rwxr-xr-x 1 root root 321457 Jul 10 22:54 utils-nagioscore.inc.php
-rwxr-xr-x 1 root root 2080 Jul 10 22:54 utils-notificationmethods.inc.php
-rwxr-xr-x 1 root root 148921 Jul 10 22:54 utils-notifications.inc.php
-rwxr-xr-x 1 root root 38661 Jul 10 22:54 utils-objects.inc.php
-rwxr-xr-x 1 root root 2442 Jul 10 22:54 utils-perms.inc.php
-rwxr-xr-x 1 root root 4333 Jul 10 22:54 utils-reports-export.inc.php
-rwxr-xr-x 1 root root 45445 Jul 10 22:54 utils-reports.inc.php
-rw-r--r-- 1 root root 6099 Jul 10 22:54 utils-rrdexport.inc.php
-rw-r--r-- 1 root root 1392 Jul 10 22:54 utils-rss.inc.php
-rwxr-xr-x 1 root root 5473 Jul 10 22:54 utils-status.inc.php
-rwxr-xr-x 1 root root 2379 Jul 10 22:54 utils-systat.inc.php
-rwxr-xr-x 1 root root 14349 Jul 10 22:54 utils-tables.inc.php
-rwxr-xr-x 1 root root 726 Jul 10 22:54 utils-themes.inc.php
-rw-r--r-- 1 root root 9954 Jul 10 22:54 utils-time.inc.php
-rwxr-xr-x 1 root root 4340 Jul 10 22:54 utils-tools.inc.php
-rwxr-xr-x 1 root root 45017 Jul 10 22:54 utils-updatecheck.inc.php
-rwxr-xr-x 1 root root 31613 Jul 10 22:54 utils-users.inc.php
-rwxr-xr-x 1 root root 48121 Jul 10 22:54 utils-views.inc.php
-rwxr-xr-x 1 root root 6705 Jul 10 22:54 utils-wizards.inc.php
-rwxr-xr-x 1 root root 17899 Jul 10 22:54 utilsx.inc.php
-rwxr-xr-x 1 root root 34326 Jul 10 22:54 utilsx-json.php
-rwxr-xr-x 1 root root 4364 Jul 10 22:54 utils-xmlauditlog.inc.php
-rwxr-xr-x 1 root root 37057 Jul 10 22:54 utils-xmlobjects.inc.php
-rwxr-xr-x 1 root root 33960 Jul 10 22:54 utils-xmlreports.inc.php
-rwxr-xr-x 1 root root 62752 Jul 10 22:54 utils-xmlstatus.inc.php
-rwxr-xr-x 1 root root 7753 Jul 10 22:54 utils-xmlsysstat.inc.php
-rwxr-xr-x 1 root root 1947 Jul 10 22:54 utils-xmlusers.inc.phpRe: Upgrade NagiosXI from 5.4.6 to 5.4.7 Failed
I am thinking that the issue withthe version of PHP that is installed on the server.
It looks fairly new.
Can you run the following and post the output so I can see where that version came from?
yum list installed |grep phpBe sure to check out our Knowledgebase for helpful articles and solutions!
It here:tgriep wrote:I am thinking that the issue withthe version of PHP that is installed on the server.
Can you run the following and post the output so I can see where that version came from?Code: Select all
[root@nagios ~]# yum list installed |grep php
graphviz-lang-php.x86_64 2.40.20161221.0239-1.el6 @graphviz-stable
php.x86_64 5.6.31-1.el6.remi @remi-php56
php-cli.x86_64 5.6.31-1.el6.remi @remi-php56
php-common.x86_64 5.6.31-1.el6.remi @remi-php56
php-gd.x86_64 5.6.31-1.el6.remi @remi-php56
php-ldap.x86_64 5.6.31-1.el6.remi @remi-php56
php-mbstring.x86_64 5.6.31-1.el6.remi @remi-php56
php-mcrypt.x86_64 5.6.31-1.el6.remi @remi-php56
php-mssql.x86_64 5.6.31-1.el6.remi @remi-php56
php-mysqlnd.x86_64 5.6.31-1.el6.remi @remi-php56
php-pdo.x86_64 5.6.31-1.el6.remi @remi-php56
php-pear.noarch 1:1.10.5-2.el6.remi @remi
php-pear-HTML-Template-IT.noarch 1.3.0-8.el6.remi @remi
php-pecl-jsonc.x86_64 1.3.10-2.el6.remi.5.6 @remi-php56
php-pecl-ssh2.x86_64 0.13-3.el6.remi.5.6 @remi-php56
php-pecl-zip.x86_64 1.14.0-1.el6.remi.5.6 @remi-php56
php-pgsql.x86_64 5.6.31-1.el6.remi @remi-php56
php-process.x86_64 5.6.31-1.el6.remi @remi-php56
php-snmp.x86_64 5.6.31-1.el6.remi @remi-php56
php-soap.x86_64 5.6.31-1.el6.remi @remi-php56
php-xml.x86_64 5.6.31-1.el6.remi @remi-php56 Re: Upgrade NagiosXI from 5.4.6 to 5.4.7 Failed
Thanks for the data.
The remi-php56 repository we have found is not compatible with Nagios XI so you will have to remove it, disable that repo and go back to the Base install of PHP to upgrade the system.
So, I update to remi-php71, do have compatibale with Nagios XI?tgriep wrote:Thanks for the data.
As of present we can only confirm compatibility with 5.6.xduhd wrote:So, I update to remi-php71, do have compatibale with Nagios XI?tgriep wrote:Thanks for the data.
