Nagios XI gone crazy
Re: Nagios XI gone crazy
reincarne wrote:
tgriep wrote:Thanks @tacolover101 for the suggestions.
Segmenting the server will help out in this issue.
Try moving the system to a faster hard drive as well as adding a Ramdisk to the system.
For now we solved the issue by splitting the check intervals, it stabilized the system.
From my side, you can close the topic.
Great, glad you found something that is workable.
