Nagios Log Server Reporting
sgiworks
Re: Nagios Log Server Reporting
Post by sgiworks »
Attached a output file, however it contains lot of other information which is not needed. If there a way to filter it?
Post by mcapra »
You should be able to do that in the query itself with the fields parameter:
https://www.elastic.co/guide/en/elastic ... est-fields
sgiworks
Post by sgiworks »
ok, let me try and I will get back to you with results. Thanks for guiding me through this new process.
sgiworks wrote:ok, let me try and I will get back to you with results. Thanks for guiding me through this new process.
Let us know if we can be of further assistance.
sgiworks
Post by sgiworks »
I tried below filters, but still the output have all the fields listed.
java -jar nlsexport.jar -host=localhost -date_start=2017.09.07 -date_end=2017.09.07 -output_path=/tmp/export_nls/ -query='{"query":{"filtered":{"query":{"bool":{"should":[{"query_string":{"query":"*"}}]}},"filter":{"bool":{"must":[{"range":{"@timestamp":{"from":1504735059807,"to":1504821459807}}},{"fquery":{"query":{"query_string":{"query":"EventID:(\"4625\" \"4771\" \"4776\")"}},"_cache":true}},{"fquery":{"query":{"query_string":{"query":"_type:(\"eventlog\")"}},"_cache":true}}],"must_not":[{"fquery":{"query":{"query_string":{"query":"message:(S-1-0-0)"}},"_cache":true}},{"fquery":{"query":{"query_string":{"query":"SComInstaller,Guest, IWKSEA%, IWKSSA%, SRV_PE_URL_MON"}},"_cache":true}}]}}}}}' -output_format=csv
Regards,
Swapnil
Post by mcapra »
Filters aren't good enough; Try the fields parameter I previously mentioned:
mcapra wrote:You should be able to do that in the query itself with the fields parameter:
Something like this should work:
	"fields": ["field_1", "field_2", "field_n"],
	"query": {
        ## query here
Before applying fields:
[root@nagios ~]# curl -XGET 'http://esprod00:9200/someindex/_search?size=1&pretty' -d '{"query":{"bool":{"should":[{"query_string":{"query":"*"}}]}}}'
  "took" : 267,
  "timed_out" : false,
  "_shards" : {
    "total" : 4,
    "successful" : 4,
    "failed" : 0
  "hits" : {
    "total" : 46835893,
    "max_score" : 1.0,
    "hits" : [ {
      "_index" : "someindex",
      "_type" : "request",
      "_id" : "AV5QjP4d_YLmLq5Ed9h3",
      "_score" : 1.0,
      "_source":{"field1":"value1","field2":"value2","field3":"value3"}
After applying fields:
[root@nagios ~]# curl -XGET 'http://esprod00:9200/someindex/_search?size=1&pretty' -d '{"fields":["field3"],"query":{"bool":{"should":[{"query_string":{"query":"*"}}]}}}'
  "took" : 267,
  "_shards" : {
    "total" : 4,
    "successful" : 4,
    "failed" : 0
  "hits" : {
    "total" : 46835893,
    "max_score" : 1.0,
    "hits" : [ {
      "_score" : 1.0,
      "_source":{"field3":"value3"}
cdienger
Post by cdienger »
Did following mcapra's suggestion help?
sgiworks
Post by sgiworks »
Just discovered that Nagios LogServer version 2.0 will have ability to export table data via CSV, which is planned to be released in Q4 of 2017. Correct? Do we know if this will be available in October 2017?
https://www.nagios.com/roadmaps/?_ga=2. ... 1504900374
Regards,
Swapnil
sgiworks wrote:Just discovered that Nagios LogServer version 2.0 will have ability to export table data via CSV, which is planned to be released in Q4 of 2017. Correct? Do we know if this will be available in October 2017?
Regards,
Swapnil
We don't have a specific date, Q4 would mean sometime before the end of the year.
sgiworks
Post by sgiworks »
Is there a chance to get a beta version available for testing the reporting feature?
