How to display the CPU Utilization of linux machine in %
vnoc
Re: How to display the CPU Utilization of linux machine in %
Post by vnoc »
Please find the attachment
check_mem.zip
(3.98 KiB) Downloaded 207 times
The screen shot from your earlier post looks like the help screen for the check_nrpe command and I would guess that there is a mis-configuration in either the command definition or the service definition so you would have to post those here so we can check them for errors.
The plugin you posted it for a memory check and not a CPU utilization check so you may want to upload the one you are using.
vnoc
Post by vnoc »
sorry please find the correct attachement
check_load.zip
(728 Bytes) Downloaded 232 times
That plugin looks like it prints the CPU Load in percentage but if it is not what you are looking for, you can search for another plugin at the Exchange site.
https://exchange.nagios.org/
