No - nothing in the nagios.log file related to errors, no multiple nagios processes running, no extra notifications going out.
Load average is higher while npcd is running (~9-10 npcd started down to ~6-7 npcd stopped), but this shouldn't be a problem for a 4xCPU VM .
Also tried running the VM with 2xCPU & 3xCPU - again no real difference - Load average was higher ~12.
I did have a look at the link you sent from Daniels presentation, but looked past what you were referring to.
He had a one liner there to renice the perfdata run command in npcd.cfg
perfdata_file_run_cmd = /bin/nice -n 19 /usr/local/nagios/libexec/process_perfdata.pl
I set the reaper values back to default as you suggested and latency improved a little bit ~30-35secs
The office is closing over the Christmas/New Year period - so if you respond to this I will probably only see it when I get back.
However by then, I'm sure you will have had a breakthrough and I will be able to implement the solution to my performance problems
Thanks for your help! regards... Fred
(My latest stats)
Nagios Stats 3.2.3
Copyright (c) 2003-2008 Ethan Galstad (www.nagios.org)
Last Modified: 10-03-2010
License: GPL
CURRENT STATUS DATA
Status File: /var/nagiosramdisk/status.dat
Status File Age: 0d 0h 0m 14s
Status File Version: 3.2.3
Program Running Time: 0d 0h 47m 6s
Nagios PID: 7774
Used/High/Total Command Buffers: 0 / 0 / 4096
Total Services: 5507
Services Checked: 5507
Services Scheduled: 5507
Services Actively Checked: 5507
Services Passively Checked: 0
Total Service State Change: 0.000 / 37.170 / 0.051 %
Active Service Latency: 10.221 / 63.098 / 32.035 sec
Active Service Execution Time: 0.018 / 46.974 / 1.236 sec
Active Service State Change: 0.000 / 37.170 / 0.051 %
Active Services Last 1/5/15/60 min: 666 / 4282 / 5471 / 5507
Passive Service Latency: 0.000 / 0.000 / 0.000 sec
Passive Service State Change: 0.000 / 0.000 / 0.000 %
Passive Services Last 1/5/15/60 min: 0 / 0 / 0 / 0
Services Ok/Warn/Unk/Crit: 5287 / 55 / 66 / 99
Services Flapping: 8
Services In Downtime: 0
Total Hosts: 679
Hosts Checked: 679
Hosts Scheduled: 679
Hosts Actively Checked: 679
Host Passively Checked: 0
Total Host State Change: 0.000 / 16.840 / 0.081 %
Active Host Latency: 0.000 / 59.670 / 30.981 sec
Active Host Execution Time: 0.038 / 10.129 / 0.182 sec
Active Host State Change: 0.000 / 16.840 / 0.081 %
Active Hosts Last 1/5/15/60 min: 41 / 492 / 657 / 679
Passive Host Latency: 0.000 / 0.000 / 0.000 sec
Passive Host State Change: 0.000 / 0.000 / 0.000 %
Passive Hosts Last 1/5/15/60 min: 0 / 0 / 0 / 0
Hosts Up/Down/Unreach: 678 / 1 / 0
Hosts Flapping: 1
Hosts In Downtime: 0
Active Host Checks Last 1/5/15 min: 102 / 707 / 1900
Scheduled: 61 / 513 / 1351
On-demand: 41 / 194 / 549
Parallel: 61 / 517 / 1361
Serial: 0 / 0 / 0
Cached: 41 / 190 / 539
Passive Host Checks Last 1/5/15 min: 0 / 0 / 0
Active Service Checks Last 1/5/15 min: 1033 / 4605 / 13387
Scheduled: 1033 / 4605 / 13387
On-demand: 0 / 0 / 0
Cached: 0 / 0 / 0
Passive Service Checks Last 1/5/15 min: 0 / 0 / 0
External Commands Last 1/5/15 min: 0 / 0 / 0
