I don't have access to simulate your settings but I an seeing a long timeout when accessing the URL.
I would remove the localhost entry from this entry
10.10.99.35 nagios.cafaroco.com
Then I would add the nagios.cafarococompany.com to the hosts file on the XI server.
If you have access to the server that you are forwarding the request through, can you check it for any errors or configuration issue as that may point us to the issue.
Rapid Response View Host Detail Extremely Slow
Re: Rapid Response View Host Detail Extremely Slow
You guys...Man you're good. SO I removed the entire line from my host file, then immediately regretted it because no localhost was not defined anywhere. I couldn't write configs yada yada etc.
However, I added local host and the local IP BACK IN 10.10.99.35 localhost and just removed the local entry of nagios.cafaroco.com and BAM removed the lag...I would not have looked there.
Case closed. Host file screwed me. Thanks guys!
