First, thank you very much for your assistance and patience. I apologize for the delay in posting this message. I have been out of town for some time.
Second, I discovered a couple of things while troubleshooting this issue and implementing the suggestions you provided me.
- I missed two sets of \" \" in my GROK statement I posted last. These generated the GROK error.
- After fixing these issues I had at least six variables with duplicate values in their tags. Some were parsed by GROK. Some were parsed by KV.
- ap AP221U,AP221U
- logtime 1502908275,1502908275
- signal -95,-95
- radioband 802.11n,802.11n
- After implementing scottwilkerson's suggestion and reviewing more information and examples on the Internet, I discovered the reuse of the variable "message" between GROK and KV caused the duplication of values. One suggestion was to use a different variable name on each out subsequent function. Therefore, I used the new variable "message_remainder" in the GREEDYDATA function output. I had noticed duplicate values appear in the GROKDEBUGGER output when testing,
but didn't make the correlation between what was happening in memory (please correct me if I am wrong as I am often.
if [type] == 'FortiLog' {
grok {
match => [ 'message' , "\<%{DATA:grokpri}\>date=%{DATA:grokdate} time=%{TIME:groktime} %{GREEDYDATA:message_remainder}" ]
tag_on_failure => [ 'failure_grok_fortiOS' ]
mutate {
gsub => [ 'message_remainder','^<[0-9]*>','' ]
kv {
source => 'message_remainder'
geoip {
source => 'dstip'
mutate {
remove_field => [ 'message_remainder' ]
}https://mega.nz/#!HsRDxQrS!NtxTwT_hLUkI ... v-K8zhYA3g
https://mega.nz/#!6xZTVRBb!rWIXXhCCOmYU ... JhqbIAQY7o
Again, I apologize for the delay in responding to your assistance, but I hope this information helps someone who is going through the same issues I have gone through.
Thank you for all your help.
Rodney.
