I figured it out, it is just the wording of "xi guest" confused me. I set it to NAT and was able to load it in my browser.dwhitfield wrote:run yum install lynx, then try the lynx command again. That should tell us if you have Internet access too.
Please send a screenshot of your browser when you go to http://192.168.2.54/nagiosxi
Don't worry about the VMWare until you've seen if you can connect with either of the two options I've given above.
In VMWare, find the XI guest, right click and go to settings. From there, you should see network adapter settings. Depending on your Windows and network security, select the appropriate option. NAT is what I use, so if you aren't set to that, try that.
Thank you for your input, really appreciate it!
