An error occurred
mtkaschools
Re: An error occurred
Post by mtkaschools »
Let's just say I have a host called 'Server - LD'. If I go into that server, and mark it as inactive, then save my changes, I end up back in the list. From there, I need to apply the configuration. When I apply the configuration, it spits back an error telling me the error that I've attached in the image.
mtkaschools,
Go to Admin->System Config->Reset Security Credentials and click on "Update Credentials".
You can also run in terminal:
# cd /usr/local/nagiosxi/scripts
# ./reset_config_perms
If this is not helping, you can try fixing your global permissions, following this document:
http://assets.nagios.com/downloads/nagi ... ssions.pdf
Hope this helps.
mtkaschools
That script fixed my issue. Thank you very much.
Glad I could help!
