End to end monitoring
tacolover101
Re: End to end monitoring
Post by tacolover101 »
philipjohnwilliams wrote:Thanks all, I'll look into installing the agent if it hasn't already been done
if your machines are Linux, you could also leverage check_by_ssh with keys, too.
Post by dwhitfield »
tacolover101 wrote: if your machines are Linux, you could also leverage check_by_ssh with keys, too.
This is absolutely true. I mentioned NRPE rather than generic agents to be more concrete. You could also use NCPA...or even NSClient.
They all have their pluses and minuses. I definitely don't see any point in using NSClient on Linux though. check_by_ssh will be the most secure, but will also mean the most load.
