Configure NTFS mount points disk space monitoring
keerthiprashanths
Re: Configure NTFS mount points disk space monitoring
Yes we have tried it and we got the same error.
keerthiprashanths
@ kyang:-
We have tried it as mentioned earlier
kyang
Can you show me how you defined it in your nsclient.ini file?
Also can you post the command of how you ran this?I'm not 100% sure, this will fix it but if we are escaping the # with a \ you should have 3 \\\ after C: because the standard in the check has 2 \\
keerthiprashanths
The nsclient.ini file is already attached with the post itself..
kyang
Got it,
But it still works like this.
Can you show me the path you are trying to check on your windows? I would like to try and replicate it so I can create it and test it myself.
All i created in my C: drive was folder like this #_test_data_ and the path is C:\#_test_data_
/usr/local/nagios/libexec/check_nrpe -H 192.168.3.46 -c CheckDriveSize -a Drive='C:\\\#_test_data_\\\' MinCritFree=15% MinWarnFree=20%
OK All 1 drive(s) are ok|'C:\\\#_test_data_\\\ free'=281.593GB;90.38594;67.78945;0;451.9297 'C:\\\#_test_data_\\\ free %'=62%;20;15;0;100
/usr/local/nagios/libexec/check_nrpe -H 192.168.3.46 -c CheckDriveSize -a Drive='C:\#_test_data_' MinCritFree=15% MinWarnFree=20%
OK All 1 drive(s) are ok|'C:\#_test_data_ free'=281.59249GB;90.38594;67.78945;0;451.9297 'C:\#_test_data_ free %'=62%;20;15;0;100
