Acknowledgements and Scheduled Downtime not showing up in XI
shilton
Re: Acknowledgements and Scheduled Downtime not showing up i
Post by shilton »
Ran the mysqlcheck
stopped and restarted nagios and ndo2db
tried to schedule downtime:
"One or more scheduled commands could not be sent to Nagios Core."
tried to set a new acknowledgement:
Acknowledgements and Comments did not reflect a new entry
# mysqlcheck -f -r -u root -pnagiosxi --use_frm --databases nagios nagiosql
nagios.nagios_acknowledgements
warning  : Number of rows changed from 0 to 324
status   : OK
nagios.nagios_commands
warning  : Number of rows changed from 0 to 142
status   : OK
nagios.nagios_commenthistory
warning  : Number of rows changed from 0 to 962
status   : OK
nagios.nagios_comments
warning  : Number of rows changed from 0 to 2
status   : OK
nagios.nagios_configfiles
status   : OK
nagios.nagios_configfilevariables
warning  : Number of rows changed from 0 to 131
status   : OK
nagios.nagios_conninfo
warning  : Number of rows changed from 0 to 1966
status   : OK
nagios.nagios_contact_addresses                    OK
nagios.nagios_contact_notificationcommands
warning  : Number of rows changed from 0 to 156
status   : OK
nagios.nagios_contactgroup_members
warning  : Number of rows changed from 0 to 33
status   : OK
nagios.nagios_contactgroups
warning  : Number of rows changed from 0 to 6
status   : OK
nagios.nagios_contactnotificationmethods
warning  : Number of rows changed from 0 to 4650
status   : OK
nagios.nagios_contactnotifications
status   : OK
nagios.nagios_contacts
status   : OK
nagios.nagios_contactstatus
status   : OK
nagios.nagios_customvariables
warning  : Number of rows changed from 0 to 47
status   : OK
nagios.nagios_customvariablestatus
status   : OK
nagios.nagios_dbversion
status   : OK
nagios.nagios_downtimehistory
warning  : Number of rows changed from 0 to 82
status   : OK
nagios.nagios_eventhandlers
warning  : Number of rows changed from 0 to 7
status   : OK
nagios.nagios_externalcommands
warning  : Number of rows changed from 0 to 27
status   : OK
nagios.nagios_flappinghistory
warning  : Number of rows changed from 0 to 3921
status   : OK
nagios.nagios_host_contactgroups
warning  : Number of rows changed from 0 to 81
status   : OK
nagios.nagios_host_contacts
status   : OK
nagios.nagios_host_parenthosts                     OK
nagios.nagios_hostchecks                           OK
nagios.nagios_hostdependencies                     OK
nagios.nagios_hostescalation_contactgroups         OK
nagios.nagios_hostescalation_contacts              OK
nagios.nagios_hostescalations                      OK
nagios.nagios_hostgroup_members
warning  : Number of rows changed from 0 to 62
status   : OK
nagios.nagios_hostgroups
warning  : Number of rows changed from 0 to 16
status   : OK
nagios.nagios_hosts
warning  : Number of rows changed from 0 to 72
status   : OK
nagios.nagios_hoststatus
info     : Delete link points outside datafile at 22008
status   : OK
nagios.nagios_instances
status   : OK
nagios.nagios_logentries
warning  : Number of rows changed from 0 to 10126
status   : OK
nagios.nagios_notifications
warning  : Number of rows changed from 0 to 2867
status   : OK
nagios.nagios_objects
warning  : Number of rows changed from 0 to 2330
status   : OK
nagios.nagios_processevents
warning  : Number of rows changed from 0 to 5697
status   : OK
nagios.nagios_programstatus
status   : OK
nagios.nagios_runtimevariables
warning  : Number of rows changed from 0 to 18
status   : OK
nagios.nagios_scheduleddowntime                    OK
nagios.nagios_service_contactgroups
warning  : Number of rows changed from 0 to 244
status   : OK
nagios.nagios_service_contacts
warning  : Number of rows changed from 0 to 36
status   : OK
nagios.nagios_service_parentservices               OK
nagios.nagios_servicechecks                        OK
nagios.nagios_servicedependencies                  OK
nagios.nagios_serviceescalation_contactgroups      OK
nagios.nagios_serviceescalation_contacts           OK
nagios.nagios_serviceescalations                   OK
nagios.nagios_servicegroup_members
status   : OK
nagios.nagios_servicegroups
status   : OK
nagios.nagios_services
warning  : Number of rows changed from 0 to 280
status   : OK
nagios.nagios_servicestatus
status   : OK
nagios.nagios_statehistory
info     : Delete link points outside datafile at 5022968
warning  : Number of rows changed from 0 to 167031
status   : OK
nagios.nagios_systemcommands
info     : Delete link points outside datafile at 0
info     : Found block with too small length at 1084; Skipped
info     : Found block with too small length at 3164; Skipped
info     : Found block with too small length at 3944; Skipped
info     : Delete link points outside datafile at 23672
warning  : Number of rows changed from 0 to 108
status   : OK
nagios.nagios_timedeventqueue                      OK
nagios.nagios_timedevents                          OK
nagios.nagios_timeperiod_timeranges
warning  : Number of rows changed from 0 to 164
status   : OK
nagios.nagios_timeperiods
status   : OK
nagiosql.tbl_command
warning  : Number of rows changed from 0 to 146
status   : OK
nagiosql.tbl_contact
warning  : Number of rows changed from 0 to 12
status   : OK
nagiosql.tbl_contactgroup
status   : OK
nagiosql.tbl_contacttemplate
status   : OK
nagiosql.tbl_domain
status   : OK
nagiosql.tbl_host
warning  : Number of rows changed from 0 to 110
status   : OK
nagiosql.tbl_hostdependency                        OK
nagiosql.tbl_hostescalation                        OK
nagiosql.tbl_hostextinfo                           OK
nagiosql.tbl_hostgroup
warning  : Number of rows changed from 0 to 17
status   : OK
nagiosql.tbl_hosttemplate
warning  : Number of rows changed from 0 to 66
status   : OK
nagiosql.tbl_info
warning  : Number of rows changed from 0 to 218
status   : OK
nagiosql.tbl_lnkContactToCommandHost
status   : OK
nagiosql.tbl_lnkContactToCommandService
status   : OK
nagiosql.tbl_lnkContactToContactgroup              OK
nagiosql.tbl_lnkContactToContacttemplate
status   : OK
nagiosql.tbl_lnkContactToVariabledefinition        OK
nagiosql.tbl_lnkContactgroupToContact
status   : OK
nagiosql.tbl_lnkContactgroupToContactgroup         OK
nagiosql.tbl_lnkContacttemplateToCommandHost
status   : OK
nagiosql.tbl_lnkContacttemplateToCommandService
status   : OK
nagiosql.tbl_lnkContacttemplateToContactgroup
status   : OK
nagiosql.tbl_lnkContacttemplateToContacttemplate   OK
nagiosql.tbl_lnkContacttemplateToVariabledefinition OK
nagiosql.tbl_lnkHostToContact                      OK
nagiosql.tbl_lnkHostToContactgroup                 OK
nagiosql.tbl_lnkHostToHost                         OK
nagiosql.tbl_lnkHostToHostgroup
status   : OK
nagiosql.tbl_lnkHostToHosttemplate
warning  : Number of rows changed from 0 to 107
status   : OK
nagiosql.tbl_lnkHostToVariabledefinition
status   : OK
nagiosql.tbl_lnkHostdependencyToHost_DH            OK
nagiosql.tbl_lnkHostdependencyToHost_H             OK
nagiosql.tbl_lnkHostdependencyToHostgroup_DH       OK
nagiosql.tbl_lnkHostdependencyToHostgroup_H        OK
nagiosql.tbl_lnkHostescalationToContact            OK
nagiosql.tbl_lnkHostescalationToContactgroup       OK
nagiosql.tbl_lnkHostescalationToHost               OK
nagiosql.tbl_lnkHostescalationToHostgroup          OK
nagiosql.tbl_lnkHostgroupToHost
warning  : Number of rows changed from 0 to 65
status   : OK
nagiosql.tbl_lnkHostgroupToHostgroup
status   : OK
nagiosql.tbl_lnkHosttemplateToContact
status   : OK
nagiosql.tbl_lnkHosttemplateToContactgroup
warning  : Number of rows changed from 0 to 20
status   : OK
nagiosql.tbl_lnkHosttemplateToHost
status   : OK
nagiosql.tbl_lnkHosttemplateToHostgroup
status   : OK
nagiosql.tbl_lnkHosttemplateToHosttemplate
warning  : Number of rows changed from 0 to 61
status   : OK
nagiosql.tbl_lnkHosttemplateToVariabledefinition   OK
nagiosql.tbl_lnkServiceToContact
status   : OK
nagiosql.tbl_lnkServiceToContactgroup              OK
nagiosql.tbl_lnkServiceToHost
status   : OK
nagiosql.tbl_lnkServiceToHostgroup
warning  : Number of rows changed from 0 to 34
status   : OK
nagiosql.tbl_lnkServiceToServicegroup              OK
nagiosql.tbl_lnkServiceToServicetemplate
warning  : Number of rows changed from 0 to 111
status   : OK
nagiosql.tbl_lnkServiceToVariabledefinition
warning  : Number of rows changed from 0 to 26
status   : OK
nagiosql.tbl_lnkServicedependencyToHost_DH         OK
nagiosql.tbl_lnkServicedependencyToHost_H          OK
nagiosql.tbl_lnkServicedependencyToHostgroup_DH    OK
nagiosql.tbl_lnkServicedependencyToHostgroup_H     OK
nagiosql.tbl_lnkServicedependencyToService_DS      OK
nagiosql.tbl_lnkServicedependencyToService_S       OK
nagiosql.tbl_lnkServiceescalationToContact         OK
nagiosql.tbl_lnkServiceescalationToContactgroup    OK
nagiosql.tbl_lnkServiceescalationToHost            OK
nagiosql.tbl_lnkServiceescalationToHostgroup       OK
nagiosql.tbl_lnkServiceescalationToService         OK
nagiosql.tbl_lnkServicegroupToService
status   : OK
nagiosql.tbl_lnkServicegroupToServicegroup         OK
nagiosql.tbl_lnkServicetemplateToContact
status   : OK
nagiosql.tbl_lnkServicetemplateToContactgroup
status   : OK
nagiosql.tbl_lnkServicetemplateToHost              OK
nagiosql.tbl_lnkServicetemplateToHostgroup
status   : OK
nagiosql.tbl_lnkServicetemplateToServicegroup      OK
nagiosql.tbl_lnkServicetemplateToServicetemplate
warning  : Number of rows changed from 0 to 90
status   : OK
nagiosql.tbl_lnkServicetemplateToVariabledefinition OK
nagiosql.tbl_lnkTimeperiodToTimeperiod             OK
nagiosql.tbl_logbook                               OK
nagiosql.tbl_mainmenu
status   : OK
nagiosql.tbl_service
warning  : Number of rows changed from 0 to 119
status   : OK
nagiosql.tbl_servicedependency                     OK
nagiosql.tbl_serviceescalation                     OK
nagiosql.tbl_serviceextinfo                        OK
nagiosql.tbl_servicegroup
status   : OK
nagiosql.tbl_servicetemplate
warning  : Number of rows changed from 0 to 97
status   : OK
nagiosql.tbl_session
info     : Delete link points outside datafile at 832
status   : OK
nagiosql.tbl_session_locks
info     : Delete link points outside datafile at 184
status   : OK
nagiosql.tbl_settings
status   : OK
nagiosql.tbl_submenu
warning  : Number of rows changed from 0 to 29
status   : OK
nagiosql.tbl_timedefinition
warning  : Number of rows changed from 0 to 170
status   : OK
nagiosql.tbl_timeperiod
status   : OK
nagiosql.tbl_user
status   : OK
nagiosql.tbl_variabledefinition
info     : Delete link points outside datafile at 5392
warning  : Number of rows changed from 0 to 152
status   : OK
Reason: Please use [code][/code] tags around long output
Post by dwhitfield »
What's the output of sestatus? Also, please attach your /etc/sudoers. Has there been any other hardening on this server?
shilton
Post by shilton »
Info sent in PM.
Scheduled Downtimes and Acknowledgements were working in the recent past, no server reconfiguration other than Nagios XI upgrades in that window.
Can you run the following commands and post the output?
chage -l nagios
grep nag /etc/passwd
grep nag /etc/group
shilton
Post by shilton »
Info sent in a PM
cdienger
Post by cdienger »
Tom is out this week. Please PM me the info and I can take a look and make it available for other techs here as well.
Mod Edit: Files received and placed on shared drive
shilton
Post by shilton »
cdienger wrote:Tom is out this week. Please PM me the info and I can take a look and make it available for other techs here as well.
PM sent.
Something is odd, there is a missing file (profile.txt) from the profile you sent. Everything else was present though. That might point to something, just not sure what.
I did notice that in your /usr/local/nagiosxi/html/config.inc.php file you have $cfg['use_https']=false; set but you appear to be using SSL elsewhere - can you edit that file to say $cfg['use_https']=true; and try again? In addition, go to Admin -> System Settings in the web interface and make sure the Program URL uses https:// at the beginning.
shilton
Post by shilton »
tmcdonald wrote:Something is odd, there is a missing file (profile.txt) from the profile you sent. Everything else was present though. That might point to something, just not sure what.
Thanks for the help tmcdonald,
I changed these settings and restarted Nagios but still no ability to schedule downtime for a host.
Can you verify this, from the command line on your Nagios XI server, can localhost be found?
ping localhost
or
cat /etc/hosts
