Check_HP_Blade_Chassis
tacolover101
Re: Check_HP_Blade_Chassis
Post by tacolover101 »
well, either SNMP isn't working properly, or you're missing a pre-req for the plugin on the new server. it's hard to say, but logically, those are the only two options.
Post by dwhitfield »
ponnpr7 wrote:I'm sure what are u asking
I'm still trying to figure out if there are two servers (which is the assumption @tacolover101 seems to be making too). If there are two servers, we can compare the two to figure out what you need to do.
Let's assume for the moment there is one server. What's the output of sestatus? Also, can you post your /etc/sudoers?
ponnpr7
Post by ponnpr7 »
[root@localhost etc]# cat sudoers
## Sudoers allows particular users to run various commands as
## the root user, without needing the root password.
## Examples are provided at the bottom of the file for collections
## of related commands, which can then be delegated out to particular
## users or groups.
## This file must be edited with the 'visudo' command.
## Host Aliases
## Groups of machines. You may prefer to use hostnames (perhaps using
## wildcards for entire domains) or IP addresses instead.
# Host_Alias     FILESERVERS = fs1, fs2
# Host_Alias     MAILSERVERS = smtp, smtp2
## User Aliases
## These aren't often necessary, as you can use regular groups
## (ie, from files, LDAP, NIS, etc) in this file - just use %groupname
## rather than USERALIAS
# User_Alias ADMINS = jsmith, mikem
## Command Aliases
## These are groups of related commands...
## Networking
# Cmnd_Alias NETWORKING = /sbin/route, /sbin/ifconfig, /bin/ping, /sbin/dhclient, /usr/bin/net, /sbin/iptables, /usr/bin/rfcomm, /usr/bin/wvdial, /sbin/iwconfig, /sbin/mii-tool
## Installation and management of software
# Cmnd_Alias SOFTWARE = /bin/rpm, /usr/bin/up2date, /usr/bin/yum
## Services
# Cmnd_Alias SERVICES = /sbin/service, /sbin/chkconfig
## Updating the locate database
# Cmnd_Alias LOCATE = /usr/bin/updatedb
## Storage
# Cmnd_Alias STORAGE = /sbin/fdisk, /sbin/sfdisk, /sbin/parted, /sbin/partprobe, /bin/mount, /bin/umount
## Delegating permissions
# Cmnd_Alias DELEGATING = /usr/sbin/visudo, /bin/chown, /bin/chmod, /bin/chgrp
## Processes
# Cmnd_Alias PROCESSES = /bin/nice, /bin/kill, /usr/bin/kill, /usr/bin/killall
## Drivers
# Cmnd_Alias DRIVERS = /sbin/modprobe
# Defaults specification
# Refuse to run if unable to disable echo on the tty.
Defaults   !visiblepw
# Preserving HOME has security implications since many programs
# use it when searching for configuration files. Note that HOME
# is already set when the the env_reset option is enabled, so
# this option is only effective for configurations where either
# env_reset is disabled or HOME is present in the env_keep list.
Defaults    always_set_home
Defaults    env_reset
Defaults    env_keep =  "COLORS DISPLAY HOSTNAME HISTSIZE INPUTRC KDEDIR LS_COLORS"
Defaults    env_keep += "MAIL PS1 PS2 QTDIR USERNAME LANG LC_ADDRESS LC_CTYPE"
Defaults    env_keep += "LC_COLLATE LC_IDENTIFICATION LC_MEASUREMENT LC_MESSAGES"
Defaults    env_keep += "LC_MONETARY LC_NAME LC_NUMERIC LC_PAPER LC_TELEPHONE"
Defaults    env_keep += "LC_TIME LC_ALL LANGUAGE LINGUAS _XKB_CHARSET XAUTHORITY"
# Adding HOME to env_keep may enable a user to run unrestricted
# commands via sudo.
# Defaults   env_keep += "HOME"
Defaults    secure_path = /sbin:/bin:/usr/sbin:/usr/bin
## Next comes the main part: which users can run what software on
## which machines (the sudoers file can be shared between multiple
## systems).
## Syntax:
##      user    MACHINE=COMMANDS
## The COMMANDS section may have other options added to it.
## Allow root to run any commands anywhere
root    ALL=(ALL)       ALL
## Allows members of the 'sys' group to run networking, software,
## service management apps and more.
# %sys ALL = NETWORKING, SOFTWARE, SERVICES, STORAGE, DELEGATING, PROCESSES, LOCATE, DRIVERS
## Allows people in group wheel to run all commands
%wheel  ALL=(ALL)       ALL
## Same thing without a password
# %wheel        ALL=(ALL)       NOPASSWD: ALL
## Allows members of the users group to mount and unmount the
## cdrom as root
# %users  ALL=/sbin/mount /mnt/cdrom, /sbin/umount /mnt/cdrom
## Allows members of the users group to shutdown this system
# %users  localhost=/sbin/shutdown -h now
## Read drop-in files from /etc/sudoers.d (the # here does not mean a comment)
#includedir /etc/sudoers.d
User_Alias      NAGIOSXI=nagios
User_Alias              NAGIOSXIWEB=apache
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/nagios checkconfig
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/ndo2db status
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd start
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd stop
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd restart
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd reload
NAGIOSXI ALL = NOPASSWD:/etc/init.d/npcd status
NAGIOSXI ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/upgrade_to_latest.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/change_timezone.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/reset_config_perms.sh
NAGIOSXI ALL = NOPASSWD:/usr/local/nagiosxi/scripts/backup_xi.sh *
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/messages
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/httpd/error_log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/tail -100 /var/log/mysqld.log
NAGIOSXIWEB ALL = NOPASSWD:/usr/bin/php /usr/local/nagiosxi/html/includes/components/autodiscovery/scripts/autodiscover_new.php *
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/html/includes/components/profile/getprofile.sh
NAGIOSXIWEB ALL = NOPASSWD:/etc/init.d/snmptt restart
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/repair_databases.sh
NAGIOSXIWEB ALL = NOPASSWD:/usr/local/nagiosxi/scripts/manage_services.sh *
# NEEDED TO ALLOW NAGIOS TO CHECK SERVICE STATUS
Defaults:nagios !requiretty
nagios ALL=NOPASSWD: /usr/local/nagios/libexec/check_init_service
# ASTERISK-SPECIFIC CHECKS
# NOTE: You can uncomment the following line if you are monitoring Asterisk locally
#nagios ALL=NOPASSWD: /usr/local/nagios/libexec/check_asterisk_sip_peers.sh, /usr/local/nagios/libexec/nagisk.pl, /usr/sbin/asterisk
[root@localhost etc]# sestatus
SELinux status:                 disabled
Reason: code blocks, ftw!
I see now that I had a typo, which is why your output seemed so strange. Please run the following commands in order and put the output in code blocks.
su - nagios
/usr/local/nagios/libexec/check_hp_bladechassis -H 10.135.133.155 -d
ll /usr/local/nagios/libexec/check_hp_bladechassis
ponnpr7
Post by ponnpr7 »
[nagios@nagios libexec]$ ll /usr/local/nagios/libexec/check_hp_bladechassis
-rwxrwxr-x 1 apache nagios 30478 Aug 25 11:11 /usr/local/nagios/libexec/check_hp_bladechassis
[nagios@nagios libexec]$ clear
[nagios@nagios libexec]$ /usr/local/nagios/libexec/check_hp_bladechassis -H 10.135.133.155 -d
   System:      BladeSystem c7000 Enclosure G3
   ServiceTag:  2M25450CKM
   Firmware:    4.60                     Plugin version:  1.0.1
   System Component Status
  STATE  |    PART NO.    | MESSAGE TEXT
      OK |     681844-B21 | Enclosure overall health condition is Ok
      OK |     456204-B21 | Enclosure management module 1 is Standby, status is Ok
      OK |     456204-B21 | Enclosure management module 2 is Active, status is Ok
      OK |     412140-B21 | Fan 1 condition is Ok
      OK |     412140-B21 | Fan 2 condition is Ok
      OK |     412140-B21 | Fan 3 condition is Ok
      OK |     412140-B21 | Fan 4 condition is Ok
      OK |     412140-B21 | Fan 5 condition is Ok
      OK |     412140-B21 | Fan 6 condition is Ok
      OK |     412140-B21 | Fan 7 condition is Ok
      OK |     412140-B21 | Fan 8 condition is Ok
      OK |     412140-B21 | Fan 9 condition is Ok
      OK |     412140-B21 | Fan 10 condition is Ok
      OK |     727021-B21 | Blade 1 (, ProLiant BL460c Gen9) status is Ok
      OK |     727021-B21 | Blade 2 (, ProLiant BL460c Gen9) status is Ok
      OK |     727021-B21 | Blade 3 (, ProLiant BL460c Gen9) status is Ok
      OK |     727021-B21 | Blade 4 (, ProLiant BL460c Gen9) status is Ok
      OK |     727021-B21 | Blade 9 (, ProLiant BL460c Gen9) status is Ok
      OK |     727021-B21 | Blade 10 (, ProLiant BL460c Gen9) status is Ok
      OK |     727021-B21 | Blade 11 (, ProLiant BL460c Gen9) status is Ok
      OK |     727021-B21 | Blade 12 (, ProLiant BL460c Gen9) status is Ok
      OK |     691367-B21 | I/O module 1 is type noconnect: HP VC FlexFabric-20/40 F8 Module
      OK |     691367-B21 | I/O module 2 is type noconnect: HP VC FlexFabric-20/40 F8 Module
      OK |         BK764A | I/O module 5 is type pciexpress: HP 6Gb SAS BL Switch
      OK |         BK764A | I/O module 6 is type pciexpress: HP 6Gb SAS BL Switch
      OK |     733459-B21 | PSU 1 is Ok, output: 894 W
      OK |     733459-B21 | PSU 2 is Ok, output: 0 W
      OK |     733459-B21 | PSU 3 is Ok, output: 0 W
      OK |     733459-B21 | PSU 4 is Ok, output: 894 W
      OK |     733459-B21 | PSU 5 is Ok, output: 0 W
      OK |     733459-B21 | PSU 6 is Ok, output: 0 W
   System Power Readings
  Total power consumption: 1788 W
What exactly is the issue? It looks like it worked to me. The host screenshot you sent doesn't have the IP you are using. What's the name of the host that is having issues?
ponnpr7
Post by ponnpr7 »
I know I got the result in the CLI but not at the GUI.
ponnpr7
Post by ponnpr7 »
Also does this plugin support IPv6?
The "Run Check Command" is sandboxed and not reliable. When you actually set up the service what is the output on the "Service Detail" page?
ponnpr7
Post by ponnpr7 »
What do mean?
