It is NSClient ++ (x64) version 0.4.4.23kyang wrote:Can you tell me the version of NSClient++ you are running?
Problem with service Queue Depth
Cristian Godoy
Re: Problem with service Queue Depth
kyang
Looks like I gave the wrong command. Forgot a \
Try this and let us know the output!
/usr/local/nagios/libexec/check_nt -H 10.161.176.75 -s "Config2006" -p 12489 -v COUNTER -l "\\PhysicalDisk(6)\\Avg. Disk Queue Length\\","Drive C:\MSSQL\PCL\LOGS queue length is %.2f %%" -w 80 -c 90 -
Cristian Godoy
The same messagekyang wrote:Looks like I gave the wrong command. Forgot a \
Try this and let us know the output!Code: Select all
[nagios@nvsplmonnagvt01 ~]$ /usr/local/nagios/libexec/check_nt -H 10.161.176.75 -s "Config2006" -p 12489 -v COUNTER -l "\\PhysicalDisk(6)\\Avg. Disk Queue Length\\","Drive C:\MSSQL\PCL\LOGS queue length is %.2f %%" -w 80 -c 90
NSClient - ERROR: Invalid return from command: check_pdh-
Sorry this is being so tricky, we have some trailing \\ on the performance counter
I believe this is correct
/usr/local/nagios/libexec/check_nt -H 10.161.176.75 -s "Config2006" -p 12489 -v COUNTER -l "\\PhysicalDisk(6)\\Avg. Disk Queue Length","Drive C:\MSSQL\PCL\LOGS queue length is %.2f %%" -w 80 -c 90-
Cristian Godoy
scottwilkerson wrote:Sorry this is being so tricky, we have some trailing \\ on the performance counter
I believe this is correctCode: Select all
I work, thank you very much to all for the help
Glad we were able to sort it out for you!
