Upgrade to 2.3 says successful, but not showing new version
- snapon_admin
Re: Upgrade to 2.3 says successful, but not showing new vers
OK so it seems to be an SSL issue. Not sure why SSL isn't working but if I change to HTTP it works. Looking for the SSL setup now so I can fix this, but if you could post that info before I find it that'd be appreciated.
EDIT: I found the documentation but all of my SSL certs and config are already in place exactly as they should be according to this: https://assets.nagios.com/downloads/nag ... alyzer.pdf and it's still not working with SSL.
It looks like the backups did not finish at there should be tar.gz files in that folder and not just directories.
Please reboot the server and then login to the GUI and if you see any errors, screen capture them and post them here.
Then check the Apache error logs in the /var/log/httpd folder for any errors while you login, post them as well.
Also, when a backup is run, you should see it in the Apache logs as well. Look at them to see if you can find out why they didn't finish.
- snapon_admin
You mean errors in the GUI? I'm just getting 404'd, but again only when using https.Please reboot the server and then login to the GUI and if you see any errors, screen capture them and post them here.
I can log in fine, but only when using http, SSL does not work. Don't know what you need here so here's a couple snips:Then check the Apache error logs in the folder for any errors while you login, post them as well.
[root@lisl-ngna-01-pv ~]# tail -100 /var/log/httpd/access_log
10.0.8.9 - - [15/Sep/2017:13:39:41 -0500] "GET /nagiosna/api/graphs/failures?sid=87&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:41 -0500] "GET /nagiosna/api/graphs/failures?sid=123&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:41 -0500] "GET /nagiosna/api/graphs/failures?sid=18&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:41 -0500] "GET /nagiosna/api/graphs/failures?sid=116&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:41 -0500] "GET /nagiosna/api/graphs/failures?sid=107&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:41 -0500] "GET /nagiosna/api/graphs/failures?sid=67&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:41 -0500] "GET /nagiosna/api/graphs/failures?sid=62&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:42 -0500] "GET /nagiosna/api/graphs/failures?sid=139&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:42 -0500] "GET /nagiosna/api/graphs/failures?sid=38&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:42 -0500] "GET /nagiosna/api/graphs/failures?sid=90&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:42 -0500] "GET /nagiosna/api/graphs/failures?sid=128&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:42 -0500] "GET /nagiosna/api/graphs/failures?sid=101&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:42 -0500] "GET /nagiosna/api/graphs/failures?sid=80&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:41 -0500] "GET /nagiosna/api/graphs/failures?sid=58&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:42 -0500] "GET /nagiosna/api/graphs/failures?sid=49&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:42 -0500] "GET /nagiosna/api/graphs/failures?sid=81&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:42 -0500] "GET /nagiosna/api/graphs/failures?sid=43&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:43 -0500] "GET /nagiosna/api/graphs/failures?sid=47&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:42 -0500] "GET /nagiosna/api/graphs/failures?sid=93&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 190 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:42 -0500] "GET /nagiosna/api/graphs/failures?sid=102&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:43 -0500] "GET /nagiosna/api/graphs/failures?sid=134&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:43 -0500] "GET /nagiosna/api/graphs/failures?sid=99&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:43 -0500] "GET /nagiosna/api/graphs/failures?sid=91&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:43 -0500] "GET /nagiosna/api/graphs/failures?sid=37&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:43 -0500] "GET /nagiosna/api/graphs/failures?sid=118&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:43 -0500] "GET /nagiosna/api/graphs/failures?sid=114&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:43 -0500] "GET /nagiosna/api/graphs/failures?sid=75&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:44 -0500] "GET /nagiosna/api/graphs/failures?sid=29&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 187 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:43 -0500] "GET /nagiosna/api/graphs/failures?sid=106&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:44 -0500] "GET /nagiosna/api/graphs/failures?sid=42&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:44 -0500] "GET /nagiosna/api/graphs/failures?sid=140&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 185 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:44 -0500] "GET /nagiosna/api/graphs/failures?sid=122&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:43 -0500] "GET /nagiosna/api/graphs/failures?sid=88&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:43 -0500] "GET /nagiosna/api/graphs/failures?sid=52&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:44 -0500] "GET /nagiosna/api/graphs/failures?sid=84&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:44 -0500] "GET /nagiosna/api/graphs/failures?sid=56&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:44 -0500] "GET /nagiosna/api/graphs/failures?sid=144&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:44 -0500] "GET /nagiosna/api/graphs/failures?sid=146&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:44 -0500] "GET /nagiosna/api/graphs/failures?sid=19&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:45 -0500] "GET /nagiosna/api/graphs/failures?sid=20&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:45 -0500] "GET /nagiosna/api/graphs/failures?sid=73&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:45 -0500] "GET /nagiosna/api/graphs/failures?sid=141&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:44 -0500] "GET /nagiosna/api/graphs/failures?sid=71&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 180 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:45 -0500] "GET /nagiosna/api/graphs/failures?sid=147&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:45 -0500] "GET /nagiosna/api/graphs/failures?sid=133&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:45 -0500] "GET /nagiosna/api/graphs/failures?sid=148&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:45 -0500] "GET /nagiosna/api/graphs/failures?sid=145&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:45 -0500] "GET /nagiosna/api/graphs/failures?sid=130&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:46 -0500] "GET /nagiosna/api/graphs/failures?sid=76&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:46 -0500] "GET /nagiosna/api/graphs/failures?sid=40&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:45 -0500] "GET /nagiosna/api/graphs/failures?sid=77&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:45 -0500] "GET /nagiosna/api/graphs/failures?sid=4&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:46 -0500] "GET /nagiosna/api/graphs/failures?sid=8&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:46 -0500] "GET /nagiosna/api/graphs/failures?sid=89&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:46 -0500] "GET /nagiosna/api/graphs/failures?sid=65&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 188 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:46 -0500] "GET /nagiosna/api/graphs/failures?sid=48&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:46 -0500] "GET /nagiosna/api/graphs/failures?sid=100&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 189 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:46 -0500] "GET /nagiosna/api/graphs/failures?sid=30&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 188 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:46 -0500] "GET /nagiosna/api/graphs/failures?sid=94&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:47 -0500] "GET /nagiosna/api/graphs/failures?sid=95&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:47 -0500] "GET /nagiosna/api/graphs/failures?sid=138&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:47 -0500] "GET /nagiosna/api/graphs/failures?sid=32&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 185 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:47 -0500] "GET /nagiosna/api/graphs/failures?sid=96&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:47 -0500] "GET /nagiosna/api/graphs/failures?sid=31&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:46 -0500] "GET /nagiosna/api/graphs/failures?sid=113&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 190 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:47 -0500] "GET /nagiosna/api/graphs/failures?sid=124&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:48 -0500] "GET /nagiosna/api/graphs/failures?sid=39&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:47 -0500] "GET /nagiosna/api/graphs/failures?sid=127&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:47 -0500] "GET /nagiosna/api/graphs/failures?sid=142&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:48 -0500] "GET /nagiosna/api/graphs/failures?sid=57&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:44 -0500] "GET /nagiosna/api/graphs/failures?sid=92&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 190 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:48 -0500] "GET /nagiosna/api/graphs/failures?sid=28&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:48 -0500] "GET /nagiosna/api/graphs/failures?sid=61&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:48 -0500] "GET /nagiosna/api/graphs/failures?sid=143&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:48 -0500] "GET /nagiosna/api/graphs/failures?sid=33&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 190 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:47 -0500] "GET /nagiosna/api/graphs/failures?sid=68&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:48 -0500] "GET /nagiosna/api/graphs/failures?sid=125&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:49 -0500] "GET /nagiosna/api/graphs/failures?sid=44&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:48 -0500] "GET /nagiosna/api/graphs/failures?sid=69&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:49 -0500] "GET /nagiosna/api/graphs/failures?sid=78&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:49 -0500] "GET /nagiosna/api/graphs/failures?sid=131&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:49 -0500] "GET /nagiosna/api/graphs/failures?sid=54&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:49 -0500] "GET /nagiosna/api/graphs/failures?sid=103&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:49 -0500] "GET /nagiosna/api/graphs/failures?sid=59&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 180 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:49 -0500] "GET /nagiosna/api/graphs/failures?sid=79&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:48 -0500] "GET /nagiosna/api/graphs/failures?sid=60&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:48 -0500] "GET /nagiosna/api/graphs/failures?sid=115&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:49 -0500] "GET /nagiosna/api/graphs/failures?sid=53&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:49 -0500] "GET /nagiosna/api/graphs/failures?sid=97&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:50 -0500] "GET /nagiosna/api/graphs/failures?sid=22&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:50 -0500] "GET /nagiosna/api/graphs/failures?sid=126&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:50 -0500] "GET /nagiosna/api/graphs/failures?sid=66&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:50 -0500] "GET /nagiosna/api/graphs/failures?sid=23&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:50 -0500] "GET /nagiosna/api/graphs/failures?sid=5&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:49 -0500] "GET /nagiosna/api/graphs/failures?sid=111&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 190 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:50 -0500] "GET /nagiosna/api/graphs/failures?sid=137&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:51 -0500] "GET /nagiosna/api/graphs/failures?sid=35&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:50 -0500] "GET /nagiosna/api/graphs/failures?sid=45&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:50 -0500] "GET /nagiosna/api/graphs/failures?sid=24&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"
10.0.8.9 - - [15/Sep/2017:13:39:50 -0500] "GET /nagiosna/api/graphs/failures?sid=27&begindate=-60+minutes&enddate=-5+minutes HTTP/1.1" 200 191 "http://netflow.snapon.com/nagiosna/" "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/60.0.3112.113 Safari/537.36"Code: Select all
[root@lisl-ngna-01-pv ~]# tail -100 /var/log/httpd/ssl_access_log
10.0.8.10 - - [15/Sep/2017:11:59:50 -0500] "GET /nagiosna/api/graphs/queryviz?sid=133&q[begindate]=2017/09/15.08:00:00&q[enddate]=2017/09/15.12:00:00&q[aggregate_csv]=srcip,dstip&q[rawquery]=&agg1=dstip&agg2=srcip&sortby=bytes HTTP/1.1" 404 311
10.0.8.10 - - [15/Sep/2017:11:59:50 -0500] "POST /nagiosna/index.php/api/queries/execute_anonymous HTTP/1.1" 200 402717
10.0.8.10 - - [15/Sep/2017:12:03:46 -0500] "GET /nagiosna/index.php/logout HTTP/1.1" 200 -
10.0.8.10 - - [15/Sep/2017:12:03:47 -0500] "GET /nagiosna/login HTTP/1.1" 404 297
10.0.8.10 - - [15/Sep/2017:12:03:49 -0500] "GET / HTTP/1.1" 302 -
10.0.8.10 - - [15/Sep/2017:12:03:49 -0500] "GET /nagiosna/index.php HTTP/1.1" 302 -
10.0.8.10 - - [15/Sep/2017:12:03:50 -0500] "GET /nagiosna/login HTTP/1.1" 404 297
10.0.8.10 - - [15/Sep/2017:12:03:57 -0500] "GET / HTTP/1.1" 302 -
10.0.8.10 - - [15/Sep/2017:12:03:57 -0500] "GET /nagiosna/index.php HTTP/1.1" 302 -
10.0.8.10 - - [15/Sep/2017:12:03:58 -0500] "GET /nagiosna/login HTTP/1.1" 404 297
10.0.8.10 - - [15/Sep/2017:12:04:20 -0500] "GET /favicon.ico HTTP/1.1" 404 294
10.0.8.10 - - [15/Sep/2017:12:04:21 -0500] "GET /nagiosna/media/fonts/fontawesome-webfont.woff?v=4.2.0 HTTP/1.1" 200 65452
10.0.8.10 - - [15/Sep/2017:12:04:21 -0500] "GET /nagiosna/media/fonts/fontawesome-webfont.ttf?v=4.2.0 HTTP/1.1" 200 112160
10.0.8.10 - - [15/Sep/2017:12:58:21 -0500] "GET /nagiosna/media/fonts/fontawesome-webfont.woff?v=4.2.0 HTTP/1.1" 200 65452
10.0.8.10 - - [15/Sep/2017:12:58:21 -0500] "GET /nagiosna/media/fonts/fontawesome-webfont.ttf?v=4.2.0 HTTP/1.1" 200 112160
10.0.8.9 - - [15/Sep/2017:13:15:15 -0500] "GET /nagiosna HTTP/1.1" 301 329
10.0.8.9 - - [15/Sep/2017:13:15:15 -0500] "GET /nagiosna/ HTTP/1.1" 200 33547
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/css/jquery-ui-1.10.3.custom.min.css HTTP/1.1" 200 26998
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/css/font-awesome.min.css HTTP/1.1" 200 21984
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/css/main.css HTTP/1.1" 200 11741
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/css/bootstrap-2.3.2.min.css HTTP/1.1" 200 126340
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/js/jquery-1.10.1.min.js HTTP/1.1" 200 93021
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/js/bootstrap.min.js HTTP/1.1" 200 28756
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/js/jquery-ui-timepicker-addon.js HTTP/1.1" 200 74018
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/js/modules/exporting.js HTTP/1.1" 200 8147
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/js/jquery-ui-1.10.3.custom.min.js HTTP/1.1" 200 228137
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/js/helpers.js HTTP/1.1" 200 7696
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/js/highcharts-more.js HTTP/1.1" 200 24398
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/js/highcharts.js HTTP/1.1" 200 165037
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/js/vizhelpers.js HTTP/1.1" 200 15637
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/js/d3.v3.min.js HTTP/1.1" 200 143320
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/images/nnalogo_small.png HTTP/1.1" 200 4822
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/images/glyphicons-halflings.png HTTP/1.1" 200 12799
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/media/fonts/fontawesome-webfont.woff?v=4.2.0 HTTP/1.1" 200 65452
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/api/sources/read?o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 308
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/api/checks/read?q%5Blastcode%5D=0&o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/api/checks/read?q%5Blastcode%5D=1&o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/api/checks/read?o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:15:16 -0500] "GET /nagiosna/api/checks/read?q%5Blastcode%5D=2&o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:15:17 -0500] "POST /nagiosna/api/sources/read HTTP/1.1" 404 308
10.0.8.9 - - [15/Sep/2017:13:15:46 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:16:16 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:16:46 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:17:16 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:17:46 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:18:16 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:18:46 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:19:16 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:19:46 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:20:17 -0500] "GET /nagiosna/api/checks/read?q%5Blastcode%5D=0&o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:20:17 -0500] "GET /nagiosna/api/checks/read?q%5Blastcode%5D=1&o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:20:17 -0500] "GET /nagiosna/api/checks/read?q%5Blastcode%5D=2&o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:20:17 -0500] "GET /nagiosna/api/checks/read?o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:20:17 -0500] "GET /nagiosna/api/sources/read?o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 308
10.0.8.9 - - [15/Sep/2017:13:20:17 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:20:47 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:21:17 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:21:47 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:22:17 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:22:47 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:23:02 -0500] "GET /nagiosna/sources HTTP/1.1" 404 299
10.0.8.9 - - [15/Sep/2017:13:23:07 -0500] "GET /nagiosna/media/icons/bullet_add.png HTTP/1.1" 200 286
10.0.8.9 - - [15/Sep/2017:13:23:18 -0500] "GET /nagiosna/media/icons/accept.png HTTP/1.1" 200 781
10.0.8.9 - - [15/Sep/2017:13:33:57 -0500] "GET /nagiosna/sources HTTP/1.1" 404 299
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/css/bootstrap-2.3.2.min.css HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/css/jquery-ui-1.10.3.custom.min.css HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/css/main.css HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/css/font-awesome.min.css HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/js/jquery-1.10.1.min.js HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/js/jquery-ui-1.10.3.custom.min.js HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/js/jquery-ui-timepicker-addon.js HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/js/highcharts-more.js HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/js/bootstrap.min.js HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/js/highcharts.js HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/js/modules/exporting.js HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/js/helpers.js HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/js/vizhelpers.js HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/js/d3.v3.min.js HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/images/glyphicons-halflings.png HTTP/1.1" 200 12799
10.0.8.9 - - [15/Sep/2017:13:36:04 -0500] "GET /nagiosna/media/images/nnalogo_small.png HTTP/1.1" 304 -
10.0.8.9 - - [15/Sep/2017:13:36:05 -0500] "GET /nagiosna/media/icons/bullet_add.png HTTP/1.1" 200 286
10.0.8.9 - - [15/Sep/2017:13:36:15 -0500] "GET /favicon.ico HTTP/1.1" 404 294
10.0.8.9 - - [15/Sep/2017:13:36:16 -0500] "GET /nagiosna/media/images/nna_splash.jpg HTTP/1.1" 200 9957
10.0.8.9 - - [15/Sep/2017:13:36:49 -0500] "GET /nagiosna/media/fonts/fontawesome-webfont.woff?v=4.2.0 HTTP/1.1" 200 65452
10.0.8.9 - - [15/Sep/2017:13:36:49 -0500] "GET /nagiosna/media/fonts/fontawesome-webfont.ttf?v=4.2.0 HTTP/1.1" 200 112160
10.0.8.9 - - [15/Sep/2017:13:36:55 -0500] "GET /nagiosna/ HTTP/1.1" 200 33547
10.0.8.9 - - [15/Sep/2017:13:37:02 -0500] "GET /nagiosna/media/fonts/fontawesome-webfont.woff?v=4.2.0 HTTP/1.1" 206 1
10.0.8.9 - - [15/Sep/2017:13:37:02 -0500] "GET /nagiosna/media/fonts/fontawesome-webfont.woff?v=4.2.0 HTTP/1.1" 206 49068
10.0.8.9 - - [15/Sep/2017:13:37:02 -0500] "GET /nagiosna/api/sources/read?o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 308
10.0.8.9 - - [15/Sep/2017:13:37:02 -0500] "GET /nagiosna/api/checks/read?q%5Blastcode%5D=0&o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:37:02 -0500] "GET /nagiosna/api/checks/read?q%5Blastcode%5D=1&o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:37:02 -0500] "GET /nagiosna/api/checks/read?o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:37:02 -0500] "GET /nagiosna/api/checks/read?q%5Blastcode%5D=2&o%5Bcol%5D=name&o%5Bsort%5D=ASC HTTP/1.1" 404 307
10.0.8.9 - - [15/Sep/2017:13:37:02 -0500] "POST /nagiosna/api/sources/read HTTP/1.1" 404 308
10.0.8.9 - - [15/Sep/2017:13:37:33 -0500] "POST /nagiosna/api/system/source_status HTTP/1.1" 404 316
10.0.8.9 - - [15/Sep/2017:13:37:44 -0500] "GET /nagiosna/sources HTTP/1.1" 404 299
10.0.8.9 - - [15/Sep/2017:13:39:03 -0500] "GET / HTTP/1.1" 302 -
10.0.8.9 - - [15/Sep/2017:13:39:03 -0500] "GET /nagiosna/index.php HTTP/1.1" 302 -
10.0.8.9 - - [15/Sep/2017:13:39:03 -0500] "GET /nagiosna/login HTTP/1.1" 404 297
10.0.8.9 - - [15/Sep/2017:13:39:40 -0500] "GET /nagiosna/media/fonts/fontawesome-webfont.ttf?v=4.2.0 HTTP/1.1" 206 1Not sure which log file you want me to look at here. Probably this one?Also, when a backup is run, you should see it in the Apache logs as well. Look at them to see if you can find out why they didn't finish.
[root@lisl-ngna-01-pv ~]# tail -100 /var/log/httpd/error_log
[Sun Sep 10 03:36:03 2017] [notice] Digest: generating secret for digest authentication ...
[Sun Sep 10 03:36:03 2017] [notice] Digest: done
[Sun Sep 10 03:36:03 2017] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Thu Sep 14 11:47:15 2017] [notice] caught SIGTERM, shutting down
[Thu Sep 14 11:47:16 2017] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Sep 14 11:47:16 2017] [notice] Digest: generating secret for digest authentication ...
[Thu Sep 14 11:47:16 2017] [notice] Digest: done
[Thu Sep 14 11:47:16 2017] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Thu Sep 14 15:51:41 2017] [notice] caught SIGTERM, shutting down
[Thu Sep 14 15:51:42 2017] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Sep 14 15:51:42 2017] [notice] Digest: generating secret for digest authentication ...
[Thu Sep 14 15:51:42 2017] [notice] Digest: done
[Thu Sep 14 15:51:42 2017] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Thu Sep 14 16:29:40 2017] [notice] caught SIGTERM, shutting down
[Thu Sep 14 16:30:55 2017] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Sep 14 16:30:55 2017] [notice] Digest: generating secret for digest authentication ...
[Thu Sep 14 16:30:55 2017] [notice] Digest: done
[Thu Sep 14 16:30:56 2017] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Fri Sep 15 10:02:54 2017] [notice] caught SIGTERM, shutting down
[Fri Sep 15 10:02:55 2017] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Sep 15 10:02:55 2017] [notice] Digest: generating secret for digest authentication ...
[Fri Sep 15 10:02:55 2017] [notice] Digest: done
[Fri Sep 15 10:02:55 2017] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Fri Sep 15 10:02:55 2017] [notice] caught SIGTERM, shutting down
[Fri Sep 15 10:11:31 2017] [notice] caught SIGTERM, shutting down
[Fri Sep 15 10:12:46 2017] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Sep 15 10:12:46 2017] [notice] Digest: generating secret for digest authentication ...
[Fri Sep 15 10:12:46 2017] [notice] Digest: done
[Fri Sep 15 10:12:47 2017] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Fri Sep 15 10:44:12 2017] [notice] caught SIGTERM, shutting down
[Fri Sep 15 10:44:13 2017] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Sep 15 10:44:13 2017] [notice] Digest: generating secret for digest authentication ...
[Fri Sep 15 10:44:13 2017] [notice] Digest: done
[Fri Sep 15 10:44:13 2017] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operations
[Fri Sep 15 13:13:23 2017] [notice] caught SIGTERM, shutting down
[Fri Sep 15 13:14:36 2017] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Fri Sep 15 13:14:36 2017] [notice] Digest: generating secret for digest authentication ...
[Fri Sep 15 13:14:36 2017] [notice] Digest: done
[Fri Sep 15 13:14:37 2017] [notice] Apache/2.2.15 (Unix) DAV/2 PHP/5.3.3 mod_ssl/2.2.15 OpenSSL/1.0.1e-fips configured -- resuming normal operationsYou do not have the required permissions to view the files attached to this post.
It's likely an apache configuration issue if it works for HTTP but not HTTPS, please run this command and send us the resulting /tmp/httpd_files.zip file so that we can review them:
Thank you
zip -r /tmp/httpd_files.zip /etc/httpd/conf/httpd.conf /etc/httpd/conf.d- snapon_admin
Attached.
Try replacing your /etc/httpd/conf.d/ssl.conf with this file:
Then restart apache:
Then test again, if it still doesn't work, remove this from the bottom of your /etc/httpd/conf.d/nagiosna.conf AND your /etc/httpd/conf.d/ssl.conf, restart apache, and try again:
Let us know the results.
Thank you
service httpd restartCode: Select all
RewriteEngine on
RewriteCond $1 !^(index\.php|scripts|media|app|js|css|img|font|vendor|config.js)
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule nagiosna/(.*)$ /var/www/html/nagiosna/www/index.php/$1 [L,QSA]Thank you
- snapon_admin
That got it, thanks!ssax wrote:Try replacing your /etc/httpd/conf.d/ssl.conf with this file:
kyang
Glad to hear it's working for you!
May we close this topic? Or did you have more questions?
- snapon_admin
You can go ahead and close it, but I would recommend updating your documentation on SSL as adding those lines to that conf file is still a part of that documentation. Thanks for all the help!
kyang
I will ask the documentation team to add that in. Thank you for using the Nagios Support Forum!
