migration tools for Nagios Core
DOkuwa
Re: migration tools for Nagios Core
Post by DOkuwa »
error message
sed -i --regexp-extended -e "s/^(\s*check_result_buffer_slots\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g" \ -e 's/^(\s*use_embedded_perl_implicitly\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g' \ -e 's/^(\s*sleep_time\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g' \ -e 's/^(\s*p1_file\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g' \ -e 's/^(\s*external_command_buffer_slots\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g' \ -e 's/^(\s*enable_embedded_perl\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g' \ -e 's/^(\s*command_check_interval\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g' \ nagios.cfg
sed: can't read -e: No such file or directory
sed: can't read s/^(\s*use_embedded_perl_implicitly\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g: No such file or directory
sed: can't read s/^(\s*sleep_time\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g: No such file or directory
sed: can't read s/^(\s*p1_file\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g: No such file or directory
sed: can't read s/^(\s*external_command_buffer_slots\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g: No such file or directory
sed: can't read s/^(\s*enable_embedded_perl\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g: No such file or directory
sed: can't read s/^(\s*command_check_interval\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g: No such file or directory
sed: can't read nagios.cfg: No such file or directory
DOkuwa
Post by DOkuwa »
scott,
error message
DOkuwa wrote:No such file or directory
Is nagios.cfg in this directory?
ls -al nagios.cfg
DOkuwa
Post by DOkuwa »
yes it is in the /usr/local/nagios/etc
lets change the command to
   -e 's/^(\s*command_check_interval\s*=\s*)/# Line Commented out for Nagios v4 Compatibility\n#\1/g' \ /usr/local/nagios/etc/nagios.cfg
copy the whole thing and paste command in terminal
DOkuwa
Post by DOkuwa »
still getting the same error message
lets step back because this is taking more effort trying to run this script than necessary..
Can you verify your config
If so, there is nothing else to do.
If you get an error about an invalid config option then we likely need to remove it from /usr/local/nagios/etc/nagios.cfg
DOkuwa
Post by DOkuwa »
Nagios Core 4.3.4
Last Modified: 2017-08-24
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for host 'generic-host' (config file '/usr/local/nagios/etc/hosts.cfg', starting on line 88)
Error: Could not add object property in file '/usr/local/nagios/etc/hosts.cfg' on line 89.
directives and data definitions. If you are upgrading from a previous
now we need to see /usr/local/nagios/etc/hosts.cfg
DOkuwa
Post by DOkuwa »
hostsfile as requested
host.cfg-updated.docx
(19.69 KiB) Downloaded 353 times
