Monitor uptime with threshold
tacolover101
Re: Monitor uptime with threshold
Post by tacolover101 »
npolovenko wrote:@ericssonvietnam, If installing an agent on the remote host is not an option then i'd suggest ./check_by_ssh plugin.
Navigate to /usr/local/nagios/libexec/
and run:
./check_by_ssh -H Your_Server_IP -C uptime
Let us know if this would work for you and if you need help creating a service definition with this plugin.
to add to this, you could also use SNMP. the oid / mib with the related info should be returned in the initial 10 lines of a snmpwalk.
npolovenko
Post by npolovenko »
Thanks, @tacolover101!
@ericssonvietnam, Let us know if you have any other questions.
