Failed to start LSB:
DOkuwa
Re: Failed to start LSB:
Post by DOkuwa »
I made adjustment to the Nagios.cfg file and error message again
I am also uploading the nagios.cfg file and hosts.cfg (line 88 & 89 are highlighted in red )
Nagios Core 4.3.4
Last Modified: 2017-08-24
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for host 'generic-host' (config file '/usr/local/nagios/etc/hosts.cfg', starting on line 88)
Error: Could not add object property in file '/usr/local/nagios/etc/hosts.cfg' on line 89.
directives and data definitions. If you are upgrading from a previous
'Whats New' section to find out what has changed
host.cfg-updated.docx
(19.69 KiB) Downloaded 291 times
nagios.cfg
nagios.cfg file
(43.77 KiB) Downloaded 549 times
kyang
Post by kyang »
Could you post this exact cfg file instead of a docx?
And comment out(take out) the cfg_dir in your nagios.cfg that you added in since you added in the cfg_file already.
cat /usr/local/nagios/etc/hosts.cfg
Instead of using name could you switch it to host_name? Here's an example.
        use                     linux-server            ; Name of host template to use
        host_name               xi
        alias                   xi
        address                 192.168.4.125
# Define a host for the local machine
        host_name               nna
        alias                   nna
        address                 192.168.4.45
When I use "name" it doesn't show up as a host in my Core.
DOkuwa
Post by DOkuwa »
it is now working I just removed the entries for generic_hosts in the hosts.cfg
kyang
Post by kyang »
Sounds great! Can I close this topic as resolved?
DOkuwa
Post by DOkuwa »
yes
kyang
Post by kyang »
Closing this topic.
If you have any more questions, feel free to create another thread!
Thank you for using the Nagios Support Forum!
