About Radius
khinmyintmyat
Re: About Radius
That's my difficult. In exicting files, I don't find radius.cfg. this file didn't included but all other files are already have. I found only radius.c file but not radius.cfg.
kyang
Re: About Radius
Could you locate where you defined the check_command? I just would like to see how you are passing the $ARG$ in your command.
Are you passing the correct variables into the $ARG$?
What version of Freeradius do you have? I'm gonna try doing this myself.
$USER1$/check_freeradius.pl -F /usr/bin/radclient/ -H $HOSTADDRESS$ -P $ARG4$ -t $ARG3$ -u $ARG1$ -p $ARG2$What version of Freeradius do you have? I'm gonna try doing this myself.
khinmyintmyat
Re: About Radius
This is cfg file for radius. Please kindly check and help me.
- rad.PNG (8.5 KiB) Viewed 1903 times
kyang
Re: About Radius
Take a look at the exchange for setting up the check_freeradius.pl plugin.
https://exchange.nagios.org/directory/P ... pl/details
For this plugin, he gives you examples to check your FreeRadius server with NRPE.
https://exchange.nagios.org/components/ ... 5&cf_id=30
