Nagios needed server checks - advices are welcome
kyang
Re: Nagios needed server checks - advices are welcome
Post by kyang »
@shwele,
Glad you were able to install the plugins and got it working!
As for the AR server, check_http is one way if you wanted to check the subdomain.
/usr/local/nagios/libexec/check_http -H my.domain -u '/subdomain#/123/abc'
As for a plugin to check an AR server, have you checked the Nagios exchange? Other than that, it depends on what the AR server does --> which can point in the right direction of what to check.
https://exchange.nagios.org/
Otherwise, did you have any more questions?
Shwele
Post by Shwele »
All good my friend, guess Im going to check with exchange even deeper if I find something, so far no solutions.
Will go with HTTP check for now, see what exchange has to offer and maybe write with colleague one check if we need something particular.
It goes on certain port so probably gonna put that check too, to see if application is working over that port, maybe check API.
Thanks! We can lock this one!
kyang
Post by kyang »
Sounds good! I'll be closing this topic.
If you have any more questions, feel free to create another thread!
Thank you for using the Nagios Support Forum!
