wrong notification or alarms
DOkuwa
Re: wrong notification or alarms
Post by DOkuwa »
Another test to indicate snmp is working on the device I don't know if it is timeout issue
sudo snmpwalk 10.255.50.1 -c  xxxx -v2c
SNMPv2-MIB::sysDescr.0 = STRING: TiMOS-C-14.0.R10 cpm/hops64 Nokia 7750 SR Copyright (c) 2000-2017 Nokia.
All rights reserved. All use subject to applicable license agreements.
Built on Wed Jun 21 12:19:14 PDT 2017 by builder in /rel14.0/b1/R10/panos/main
SNMPv2-MIB::sysObjectID.0 = OID: SNMPv2-SMI::enterprises.6527.1.3.10
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (492015484) 56 days, 22:42:34.84
SNMPv2-MIB::sysContact.0 = STRING:
SNMPv2-MIB::sysName.0 = STRING: uschi-eqn1-cs02
SNMPv2-MIB::sysLocation.0 = STRING: Equinix CH1
SNMPv2-MIB::sysServices.0 = INTEGER: 79
IF-MIB::ifNumber.0 = INTEGER: 73
IF-MIB::ifIndex.1 = INTEGER: 1
IF-MIB::ifIndex.2 = INTEGER: 2
IF-MIB::ifIndex.3 = INTEGER: 3
IF-MIB::ifIndex.37781504 = INTEGER: 37781504
IF-MIB::ifIndex.37814272 = INTEGER: 37814272
IF-MIB::ifIndex.37847040 = INTEGER: 37847040
IF-MIB::ifIndex.37879808 = INTEGER: 37879808
IF-MIB::ifIndex.37912576 = INTEGER: 37912576
IF-MIB::ifIndex.37945344 = INTEGER: 37945344
IF-MIB::ifIndex.37978112 = INTEGER: 37978112
IF-MIB::ifIndex.38010880 = INTEGER: 38010880
Post by dwhitfield »
Please upload check_alcatel_ports.pl so that we can take a look.
Also, that's a really old version of Core. Have you considered upgrading?
DOkuwa
Post by DOkuwa »
this is the file been used
(4.66 KiB) Downloaded 601 times
DOkuwa
Post by DOkuwa »
please close this case as matter has been solved
