Did you also have freshness checking enabled for the host in the XI CCM?
Hi @kyang,
Thanks for your response. I have got check host freshness set to 1 in nagios.cfg file of the Server.
I followed the document and set to check_dummy with Arg1 - 2 and Arg2 - "Host disconnected" .
Now all my hosts are disconnected although services inside this hosts are updating fine.
Please be advised that all these hosts are being pulled passively over port 5667 (NSCA).
Is there something I am not doing it right ?
Please advise.
Can you show us how you are sending the NSCA data for the host? I didn't see a post that outlined that.
You are sending a NSCA check for just the host as well as the services correct?
The services are all updating in my local time but the host appear to be down. I set check_dummy following the guide posted by @kyang in previous thread.
I have added the command but returned with message- Command was not found: Check_OK in the Services status.
Is this because host are being pulled passively ?
Also, I am guessing even if this is added, its coming in as Service correct? I have no issues in setting the Services to prompt me "OK, Unknown, Warning, Critical" but what would i expect to see status changing for my host instead.
Also, is there a way where my host will appear down if any/all services go down ?
Some sort of dependency where my host is controlled by the associated services ?
This way my issue is resolved.
rifelixd wrote:Also, is there a way where my host will appear down if any/all services go down ?
