nagios not working properly
- Former Nagios Staff
Re: nagios not working properly
Please PM or attach your nagios.cfg. Also, are you using ndoutils? If so, what is the output of ipcs -q. Are you any other add-ons, such as mod_gearman?
1.ipcs -q
2.on top of nagios we are using nagiosql
3.nagios.cfg
1.ipcs -q
------ Message Queues --------
key msqid owner perms used-bytes messages 3.nagios.cfg
# LOG ARCHIVE PATH
# LOGGING OPTIONS
# If you want messages logged to the syslog facility, as well as the
# Nagios log file set this option to 1. If not, set it to 0.
use_syslog=1
# NOTIFICATION LOGGING OPTION
# If you don't want notifications to be logged, set this value to 0.
# If notifications should be logged, set the value to 1.
log_notifications=1
# SERVICE RETRY LOGGING OPTION
# to 0. If retries should be logged, set the value to 1.
log_service_retries=1
# HOST RETRY LOGGING OPTION
# 0. If retries should be logged, set the value to 1.
log_host_retries=1
# EVENT HANDLER LOGGING OPTION
# If you don't want host and service event handlers to be logged, set
# this value to 0. If event handlers should be logged, set the value
# to 1.
log_event_handlers=1
# INITIAL STATES LOGGING OPTION
# If you want Nagios to log all initial host and service states to
# the main log file (the first time the service or host is checked)
# you can enable this option by setting this value to 1. If you
# are not using an external application that does long term state
# statistics reporting, you do not need to enable this option. In
# this case, set the value to 0.
log_initial_states=0
# CURRENT STATES LOGGING OPTION
# If you don't want Nagios to log all current host and service states
# after log has been rotated to the main log file, you can disable this
# option by setting this value to 0. Default value is 1.
log_current_states=1
# EXTERNAL COMMANDS LOGGING OPTION
# If you don't want Nagios to log external commands, set this value
# to 0. If external commands should be logged, set this value to 1.
# Note: This option does not include logging of passive service
# checks - see the option below for controlling whether or not
# passive checks are logged.
log_external_commands=1
# PASSIVE CHECKS LOGGING OPTION
# If you don't want Nagios to log passive host and service checks, set
# this value to 0. If passive checks should be logged, set
# this value to 1.
log_passive_checks=1
# GLOBAL HOST AND SERVICE EVENT HANDLERS
# These options allow you to specify a host and service event handler
# command that is to be run for every host or service state change.
# The global event handler is executed immediately prior to the event
# handler that you have optionally specified in each host or
# service definition. The command argument is the short name of a
# command definition that you define in your host configuration file.
# Read the HTML docs for more information.
#global_host_event_handler=somecommand
#global_service_event_handler=somecommand
# SERVICE INTER-CHECK DELAY METHOD
# This is the method that Nagios should use when initially
# "spreading out" service checks when it starts monitoring. The
# default is to use smart delay calculation, which will try to
# space all service checks out evenly to minimize CPU load.
# Using the dumb setting will cause all checks to be scheduled
# at the same time (with no delay between them)! This is not a
# good thing for production, but is useful when testing the
# parallelization functionality.
# n = None - don't use any delay between checks
# d = Use a "dumb" delay of 1 second between checks
# s = Use "smart" inter-check delay calculation
# x.xx = Use an inter-check delay of x.xx seconds
# MAXIMUM SERVICE CHECK SPREAD
# This variable determines the timeframe (in minutes) from the
# program start time that an initial check of all services should
# be completed. Default is 30 minutes.
max_service_check_spread=30
# SERVICE CHECK INTERLEAVE FACTOR
# This variable determines how service checks are interleaved.
# Interleaving the service checks allows for a more even
# distribution of service checks and reduced load on remote
# hosts. Setting this value to 1 is equivalent to how versions
# of Nagios previous to 0.0.5 did service checks. Set this
# value to s (smart) for automatic calculation of the interleave
# factor unless you have a specific reason to change it.
# s = Use "smart" interleave factor calculation
# x = Use an interleave factor of x, where x is a
# number greater than or equal to 1.
service_interleave_factor=s
# HOST INTER-CHECK DELAY METHOD
# "spreading out" host checks when it starts monitoring. The
# space all host checks out evenly to minimize CPU load.
# MAXIMUM HOST CHECK SPREAD
# program start time that an initial check of all hosts should
max_host_check_spread=30
# MAXIMUM CONCURRENT SERVICE CHECKS
# This option allows you to specify the maximum number of
# service checks that can be run in parallel at any given time.
# Specifying a value of 1 for this variable essentially prevents
# any service checks from being parallelized. A value of 0
# will not restrict the number of concurrent checks that are
# being executed.
max_concurrent_checks=0
# HOST AND SERVICE CHECK REAPER FREQUENCY
# This is the frequency (in seconds!) that Nagios will process
# the results of host and service checks.
# MAX CHECK RESULT REAPER TIME
# This is the max amount of time (in seconds) that a single
# check result reaper event will be allowed to run before
# returning control back to Nagios so it can perform other
# duties.
max_check_result_reaper_time=30
# CHECK RESULT PATH
# This is directory where Nagios stores the results of host and
# service checks that have not yet been processed.
# Note: Make sure that only one instance of Nagios has access
# to this directory!
check_result_path=/usr/local/nagios/var/spool/checkresults
# MAX CHECK RESULT FILE AGE
# This option determines the maximum age (in seconds) which check
# result files are considered to be valid. Files older than this
# threshold will be mercilessly deleted without further processing.
# CACHED HOST CHECK HORIZON
# This option determines the maximum amount of time (in seconds)
# that the state of a previous host check is considered current.
# Cached host states (from host checks that were performed more
# recently that the timeframe specified by this value) can immensely
# improve performance in regards to the host check logic.
# Too high of a value for this option may result in inaccurate host
# states being used by Nagios, while a lower value may result in a
# performance hit for host checks. Use a value of 0 to disable host
# check caching.
cached_host_check_horizon=15
# CACHED SERVICE CHECK HORIZON
# that the state of a previous service check is considered current.
# Cached service states (from service checks that were performed more
# improve performance in regards to predictive dependency checks.
# Use a value of 0 to disable service check caching.
cached_service_check_horizon=15
# ENABLE PREDICTIVE HOST DEPENDENCY CHECKS
# This option determines whether or not Nagios will attempt to execute
# checks of hosts when it predicts that future dependency logic test
# may be needed. These predictive checks can help ensure that your
# host dependency logic works well.
# Values:
# 0 = Disable predictive checks
# 1 = Enable predictive checks (default)
# ENABLE PREDICTIVE SERVICE DEPENDENCY CHECKS
# checks of service when it predicts that future dependency logic test
# service dependency logic works well.
# Values:
# SOFT STATE DEPENDENCIES
# This option determines whether or not Nagios will use soft state
# information when checking host and service dependencies. Normally
# Nagios will only use the latest hard host or service state when
# checking dependencies. If you want it to use the latest state (regardless
# of whether its a soft or hard state type), enable this option.
# Values:
# 0 = Don't use soft state dependencies (default)
# 1 = Use soft state dependencies
soft_state_dependencies=0
# TIME CHANGE ADJUSTMENT THRESHOLDS
# These options determine when Nagios will react to detected changes
# in system time (either forward or backwards).
#time_change_threshold=900
# AUTO-RESCHEDULING OPTION
# automatically reschedule active host and service checks to
# "smooth" them out over time. This can help balance the load on
# the monitoring server.
# WARNING: THIS IS AN EXPERIMENTAL FEATURE - IT CAN DEGRADE
# PERFORMANCE, RATHER THAN INCREASE IT, IF USED IMPROPERLY
auto_reschedule_checks=0
# AUTO-RESCHEDULING INTERVAL
# This option determines how often (in seconds) Nagios will
# attempt to automatically reschedule checks. This option only
# has an effect if the auto_reschedule_checks option is enabled.
# Default is 30 seconds.
auto_rescheduling_interval=30
# AUTO-RESCHEDULING WINDOW
# This option determines the "window" of time (in seconds) that
# Nagios will look at when automatically rescheduling checks.
# Only host and service checks that occur in the next X seconds
# (determined by this variable) will be rescheduled. This option
# only has an effect if the auto_reschedule_checks option is
# enabled. Default is 180 seconds (3 minutes).
auto_rescheduling_window=180
# TIMEOUT VALUES
# These options control how much time Nagios will allow various
# types of commands to execute before killing them off. Options
# are available for controlling maximum time allotted for
# service checks, host checks, event handlers, notifications, the
# ocsp command, and performance data commands. All values are in
# seconds.
service_check_timeout=600
host_check_timeout=300
event_handler_timeout=30
notification_timeout=30
ocsp_timeout=5
perfdata_timeout=5
# RETAIN STATE INFORMATION
# This setting determines whether or not Nagios will save state
# information for services and hosts before it shuts down. Upon
# startup Nagios will reload all saved service and host state
# information before starting to monitor. This is useful for
# maintaining long-term data on state statistics, etc, but will
# slow Nagios down a bit when it (re)starts. Since its only
# a one-time penalty, I think its well worth the additional
# startup delay.
retain_state_information=1
# STATE RETENTION FILE
# This is the file that Nagios should use to store host and
# service state information before it shuts down. The state
# information in this file is also read immediately prior to
# starting to monitor the network when Nagios is restarted.
# This file is used only if the retain_state_information
# variable is set to 1.
state_retention_file=/usr/local/nagios/var/retention.dat
# RETENTION DATA UPDATE INTERVAL
# This setting determines how often (in minutes) that Nagios
# will automatically save retention data during normal operation.
# If you set this value to 0, Nagios will not save retention
# data at regular interval, but it will still save retention
# data before shutting down or restarting. If you have disabled
# state retention, this option has no effect.
retention_update_interval=60
# USE RETAINED PROGRAM STATE
# This setting determines whether or not Nagios will set
# program status variables based on the values saved in the
# retention file. If you want to use retained program status
# information, set this value to 1. If not, set this value
# to 0.
use_retained_program_state=1
# USE RETAINED SCHEDULING INFO
# This setting determines whether or not Nagios will retain
# the scheduling info (next check time) for hosts and services
# based on the values saved in the retention file. If you
# If you want to use retained scheduling info, set this
# value to 1. If not, set this value to 0.
# RETAINED ATTRIBUTE MASKS (ADVANCED FEATURE)
# The following variables are used to specify specific host and
# service attributes that should *not* be retained by Nagios during
# program restarts.
# The values of the masks are bitwise ANDs of values specified
# by the "MODATTR_" definitions found in include/common.h.
# For example, if you do not want the current enabled/disabled state
# of flap detection and event handlers for hosts to be retained, you
# would use a value of 24 for the host attribute mask...
# MODATTR_EVENT_HANDLER_ENABLED (8) + MODATTR_FLAP_DETECTION_ENABLED (16) = 24
# This mask determines what host attributes are not retained
# This mask determines what service attributes are not retained
# These two masks determine what process attributes are not retained.
# There are two masks, because some process attributes have host and service
# options. For example, you can disable active host checks, but leave active
# service checks enabled.
# These two masks determine what contact attributes are not retained.
# There are two masks, because some contact attributes have host and
# service options. For example, you can disable host notifications for
# a contact, but leave service notifications enabled for them.
# INTERVAL LENGTH
# This is the seconds per unit interval as used in the
# host/contact/service configuration files. Setting this to 60 means
# that each interval is one minute long (60 seconds). Other settings
# have not been tested much, so your mileage is likely to vary...
interval_length=60
# CHECK FOR UPDATES
# This option determines whether Nagios will automatically check to
# see if new updates (releases) are available. It is recommend that you
# enable this option to ensure that you stay on top of the latest critical
# patches to Nagios. Nagios is critical to you - make sure you keep it in
# good shape. Nagios will check once a day for new updates. Data collected
# by Nagios Enterprises from the update check is processed in accordance
# with our privacy policy - see https://api.nagios.org for details.
check_for_updates=1
# BARE UPDATE CHECK
# This option deterines what data Nagios will send to api.nagios.org when
# it checks for updates. By default, Nagios will send information on the
# current version of Nagios you have installed, as well as an indicator as
# to whether this was a new installation or not. Nagios Enterprises uses
# this data to determine the number of users running specific version of
# Nagios. Enable this option if you do not want this information to be sent.
bare_update_check=0
# AGGRESSIVE HOST CHECKING OPTION
# If you don't want to turn on aggressive host checking features, set
# this value to 0 (the default). Otherwise set this value to 1 to
# enable the aggressive check option. Read the docs for more info
# on what aggressive host check is or check out the source code in
# base/checks.c
# SERVICE CHECK EXECUTION OPTION
# This determines whether or not Nagios will actively execute
# service checks when it initially starts. If this option is
# disabled, checks are not actively made, but Nagios can still
# receive and process passive check results that come in. Unless
# you're implementing redundant hosts or have a special need for
# disabling the execution of service checks, leave this enabled!
# Values: 1 = enable checks, 0 = disable checks
Reason: Please please the Code button on long output so you get code tags...or add them manually [code][/code]
hi,
please ignore previuos nagios.cfg ... now i have attached nagios.cfg
regards
Prasanth
regards
Prasanth
nagios.cfg- (44.49 KiB) Downloaded 451 times
npolovenko
- Support Tech
@prasa880, Please open /etc/group and make sure that nagios user has the following permissions:
nano /etc/group
nagios:x:500:nagios,apacheAs of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
HI,
nagios already having permissions...but suddenly" Restart failed - Nagios command file not found or no execute permissions " in nagiosql.
nagcmd file it self not there.. once you kill and restart nagios file get apperared.
thanks
thanks
Does it? Earlier, the output of
was incorrect.
I'm concerned because useradd: user 'nagios' already exists. Did it actually add it to the groups?
cat /etc/group|grep nagI'm concerned because useradd: user 'nagios' already exists. Did it actually add it to the groups?
hi,
nagios
500:nagios,apache
nagcmd
501:nagios,apache
nagios
nagcmd
Do you mean nagios.cmd? I just want to make sure we are trouble-shooting the correct problem. What are the permissions on that file when it does exist?prasa880 wrote: nagcmd file it self not there..
basically i am facing issue with starting and stopping nagios.
while starting
Running configuration check...
Stopping nagios:kill: usage: kill [-s sigspec | -n signum | -sigspec] pid | jobspec ... or kill -l [sigspec]
done.
Starting nagios: done.
2. in nagios frontend ,while disabling notifcations or clicking process commands like "restart nagios process" or Disable notifications
i am hitting "Error: Could not stat() command file '/usr/local/nagios/var/rw/nagios.cmd'!
The external command file may be missing, Nagios may not be running, and/or Nagios may not be checking external commands.
An error occurred while attempting to commit your command for processing."
3.ls -l /usr/local/nagios/var/rw/
total 0
prw-rw---- 1 nagios nagcmd 0 Dec 16 12:36 nagios.cmd
srw-rw---- 1 nagios nagcmd 0 Dec 16 12:35 nagios.qh
4. i have created group called nagcmd in that nagios apache both are added.
5. in top of nagios i am using nagiosql.
thanks in advance
prasanth
while starting
done.
total 0
thanks in advance
prasanth
As a trouble-shooting measure, can you turn off the nagiosql integration? What version of nagiosql are you running? You may need to bring this up with the nagiosql developers: https://sourceforge.net/projects/nagios ... rce=navbar
