Sounds good!
Let us know of any issues or updates again. Thanks!
NagiosXI CCM - Slow to the point of unusable
russell.it
Re: NagiosXI CCM - Slow to the point of unusable
We have run the ramdisk install script set the size to 500mb and CCM is now working quite fast.
I would recommend this to be part of the initial install as with out the ramdisk for us CCM is unusable.
Happy for the ticket to be closed now as CCM is running fine.
Russell
Russell
- Former Nagios Staff
I have made this request to the devs. I cannot say if this will ever be implemented. I would check https://www.nagios.com/roadmaps/ for future inclusion and https://assets.nagios.com/downloads/nag ... NGES-5.TXT for actual inclusion.russell.it wrote: I would recommend this to be part of the initial install as with out the ramdisk for us CCM is unusable.
