./configure --enable-command-args --with-ssl=/usr/local/bin --with-ssl-inc=/usr/local/include/eopenssl/openssl --with-ssl-lib=/usr/local/lib/eopensslCode: Select all
checking for SSL headers... found in /usr/local/include/eopenssl/openssl
checking for SSL libraries... configure: error: Cannot find ssl librariesnpolovenko wrote:@gornm565, Please try the following command:Code: Select all
./configure --enable-command-args --with-ssl=/usr/local/bin --with-ssl-inc=/usr/local/include/eopenssl/openssl --with-ssl-lib=/usr/local/lib/eopenssl/man/man3/Code: Select all
./configure --enable-command-argsCode: Select all
./configure --enable-command-args --disable-ssl
