SQL Error [ndoutils] : Incorrect file format 'nagios_hoststa
Re: SQL Error [ndoutils] : Incorrect file format 'nagios_hos
Post by dwhitfield »
Do you have another thread for your other issue? If not, I would suggest making one. Also, if you are a customer, you may want to submit a ticket at https://support.nagios.com/tickets/
lucasnap
Post by lucasnap »
Found it, I only needed to set use_https back to true in this file:
vi /usr/local/nagiosxi/html/config.inc.php
$cfg['use_https']=true;
Now all works fine again, thanks for all the help.
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
