Hi @dwhitfield
Unfortunately no, I wasnt able to find the required information using the logs.
Also I wasnt able to try the VB Script plugin since there are some restrictions on installing additional piece of softwares in production systems.
However, I hope this would be a great feature if you can bring it into your system. Therefore I hope if you can make a request to implement a way to check the list of Hosts & Host Groups which use the same NRDP configs using Nagios XI GUI that would be great. Also logging it in nagios logs would be beneficial too.
List of hosts using the same NRDS Config File
- Former Nagios Staff
Re: List of hosts using the same NRDS Config File
I have made this request to the devs. Did you have any other questions or comments, or should I lock this up?
kyang
Sounds good! I'll be closing this thread!
If you have any more questions, feel free to create another thread.
Thanks for using the Nagios Support Forum!
