I did find an old ndo2db process running that should be killed or it could cause problems.
kill -9 6448Code: Select all
ls -l /var/nagiosramdisk/*perfdataCode: Select all
ls -l /var/nagiosramdisk/spool/xidpe/
ls -l /var/nagiosramdisk/spool/perfdata/
thanigaivel.a wrote:Also, found that the "Submit passive check result" option was not working.
process-host-perfdata-file-bulkCode: Select all
/bin/mv /var/nagiosramdisk/host-perfdata /var/nagiosramdisk/spool/xidpe/ $TIMET$.perfdata.hostCode: Select all
/bin/mv /var/nagiosramdisk/host-perfdata /var/nagiosramdisk/spool/xidpe/$TIMET$.perfdata.hostCode: Select all
process-service-perfdata-file-bulkCode: Select all
/bin/mv /var/nagiosramdisk/service-perfdata /var/nagiosramdisk/spool/xidpe/ $TIMET$.perfdata.serviceCode: Select all
/bin/mv /var/nagiosramdisk/service-perfdata /var/nagiosramdisk/spool/xidpe/$TIMET$.perfdata.serviceCode: Select all
/var/nagiosramdisk/service-perfdataOur normal business hours (Central Time) are listed below:
Monday – Thursday: 9:00 am – 5:00 pm
Friday: 9:00 am – 2:00 pm
