NA - Fresh Install - Getting an Error
Re: NA - Fresh Install - Getting an Error
You are missing a package called Pango and it should come from the rhel-7-server-rpms repository.
Try running this to clear out the yum cache
yum clean all
Then see if you can install the Pango package by running
yum install pango pango-devel -y
bosecorp
Post by bosecorp »
here is the error
[root@usvanagiospna1 ~]# yum clean all
Loaded plugins: amazon-id, rhui-lb, search-disabled-repos, versionlock
Cleaning repos: chef-stable epel rhel-7-server-optional-rpms rhel-7-server-rpms rhel-7-server-rt-rpms rhui-REGION-client-config-server-7 rhui-REGION-rhel-server-releases rhui-REGION-rhel-server-rh-common
Cleaning up everything
Maybe you want: rm -rf /var/cache/yum, to also free up space taken by orphaned data from disabled or removed repos
[root@usvanagiospna1 ~]# yum install pango pango-devel -y
chef-stable | 1.4 kB 00:00:00
epel/x86_64/metalink | 15 kB 00:00:00
epel | 4.7 kB 00:00:00
rhel-7-server-optional-rpms | 3.5 kB 00:00:00
rhel-7-server-rpms | 3.5 kB 00:00:00
rhel-7-server-rt-rpms | 4.0 kB 00:00:00
rhui-REGION-client-config-server-7 | 2.9 kB 00:00:00
rhui-REGION-rhel-server-releases | 3.5 kB 00:00:00
rhui-REGION-rhel-server-rh-common | 3.8 kB 00:00:00
(1/20): epel/x86_64/group_gz | 266 kB 00:00:01
(2/20): epel/x86_64/primary_db | 6.2 MB 00:00:00
(3/20): epel/x86_64/updateinfo | 878 kB 00:00:02
(4/20): chef-stable/x86_64/primary | 4.3 MB 00:00:02
(5/20): rhel-7-server-optional-rpms/7Server/x86_64/group | 24 kB 00:00:01
(6/20): rhel-7-server-optional-rpms/7Server/x86_64/updateinfo | 1.8 MB 00:00:01
(7/20): rhel-7-server-optional-rpms/7Server/x86_64/primary_db | 6.2 MB 00:00:00
(8/20): rhel-7-server-rpms/7Server/x86_64/group | 709 kB 00:00:02
(9/20): rhel-7-server-rpms/7Server/x86_64/updateinfo | 2.5 MB 00:00:02
(10/20): rhel-7-server-rpms/7Server/x86_64/primary_db | 47 MB 00:00:01
(11/20): rhel-7-server-rt-rpms/7Server/x86_64/group | 1.8 kB 00:00:05
(12/20): rhel-7-server-rt-rpms/7Server/x86_64/primary_db | 113 kB 00:00:00
(13/20): rhel-7-server-rt-rpms/7Server/x86_64/updateinfo | 71 kB 00:00:05
(14/20): rhui-REGION-client-config-server-7/x86_64/primary_db | 2.5 kB 00:00:07
(15/20): rhui-REGION-rhel-server-releases/7Server/x86_64/group | 709 kB 00:00:08
(16/20): rhui-REGION-rhel-server-rh-common/7Server/x86_64/updateinfo | 33 kB 00:00:00
(17/20): rhui-REGION-rhel-server-releases/7Server/x86_64/updateinfo | 2.5 MB 00:00:08
(18/20): rhui-REGION-rhel-server-rh-common/7Server/x86_64/primary_db | 120 kB 00:00:00
(19/20): rhui-REGION-rhel-server-rh-common/7Server/x86_64/group | 104 B 00:00:08
(20/20): rhui-REGION-rhel-server-releases/7Server/x86_64/primary_db | 47 MB 00:00:09
chef-stable 503/503
Package pango-1.40.4-1.el7.x86_64 already installed and latest version
Package pango-devel-1.40.4-1.el7.x86_64 already installed and latest version
Nothing to do
npolovenko
Post by npolovenko »
@bosecorp, Do you have the libxml2-dev package installed? You can check with:
 yum list installed | grep libxml2-dev
And if you don't please install it:
sudo apt-get install libxml2-dev
bosecorp
Post by bosecorp »
it's already installed
[root@usvanagiospna1 ~]# yum list installed | grep libxml2-dev
libxml2-devel.x86_64 2.9.1-6.el7_2.3 @rhui-REGION-rhel-server-releases
[root@usvanagiospna1 ~]# yum install libxml2-devel.x86_64
Package libxml2-devel-2.9.1-6.el7_2.3.x86_64 already installed and latest version
Nothing to do
Let's manually install the packages that Network Analyzer needs by running the following as root.
yum install php mariadb-server php-mysql php-ldap php-devel sendmail unzip zip gcc make glibc ntp flex byacc libxml2-devel pango-devel cairo-devel bzip2-devel glib2-devel python-devel python-setuptools perl-ExtUtils-MakeMaker MySQL-python sudo net-snmp net-snmp-utils numpy groff python-dateutil php-mcrypt xorg-x11-fonts-75dpi xorg-x11-fonts-Type1 libjpeg-turbo dejavu-sans-fonts dejavu-serif-fonts cjkuni-fonts-common cjkuni-ukai-fonts cjkuni-uming-fonts -y
Then try the fullinstall again and post the full output of the install if it still cannot install.
bosecorp
Post by bosecorp »
Seems like things are getting stuck installing rrd
sudo] password for el872784:
Last login: Mon Jan 29 13:24:28 UTC 2018 on pts/0
[root@usvanagiospna1 ~]# yum install php mariadb-server php-mysql php-ldap php-devel sendmail unzip zip gcc make glibc ntp flex byacc libxml2-devel pango-devel cairo-devel bzip2-devel glib2-devel python-devel python-setuptools perl-ExtUtils-MakeMaker MySQL-python sudo net-snmp net-snmp-utils numpy groff python-dateutil php-mcrypt xorg-x11-fonts-75dpi xorg-x11-fonts-Type1 libjpeg-turbo dejavu-sans-fonts dejavu-serif-fonts cjkuni-fonts-common cjkuni-ukai-fonts cjkuni-uming-fonts -y
Package php-5.4.16-43.el7_4.x86_64 already installed and latest version
Package 1:mariadb-server-5.5.56-2.el7.x86_64 already installed and latest version
Package php-mysql-5.4.16-43.el7_4.x86_64 already installed and latest version
Package php-ldap-5.4.16-43.el7_4.x86_64 already installed and latest version
Package php-devel-5.4.16-43.el7_4.x86_64 already installed and latest version
Package sendmail-8.14.7-5.el7.x86_64 already installed and latest version
Package unzip-6.0-16.el7.x86_64 already installed and latest version
Package zip-3.0-11.el7.x86_64 already installed and latest version
Package gcc-4.8.5-16.el7_4.1.x86_64 already installed and latest version
Package 1:make-3.82-23.el7.x86_64 already installed and latest version
Package glibc-2.17-196.el7_4.2.x86_64 already installed and latest version
Package ntp-4.2.6p5-25.el7_3.2.x86_64 already installed and latest version
Package flex-2.5.37-3.el7.x86_64 already installed and latest version
Package byacc-1.9.20130304-3.el7.x86_64 already installed and latest version
Package cairo-devel-1.14.8-2.el7.x86_64 already installed and latest version
Package bzip2-devel-1.0.6-13.el7.x86_64 already installed and latest version
Package glib2-devel-2.50.3-3.el7.x86_64 already installed and latest version
Package python-devel-2.7.5-58.el7.x86_64 already installed and latest version
Package python-setuptools-0.9.8-7.el7.noarch already installed and latest version
Package perl-ExtUtils-MakeMaker-6.68-3.el7.noarch already installed and latest version
Package MySQL-python-1.2.5-1.el7.x86_64 already installed and latest version
Package sudo-1.8.19p2-11.el7_4.x86_64 already installed and latest version
Package 1:net-snmp-5.7.2-28.el7_4.1.x86_64 already installed and latest version
Package 1:net-snmp-utils-5.7.2-28.el7_4.1.x86_64 already installed and latest version
Package 1:numpy-1.7.1-11.el7.x86_64 already installed and latest version
Package groff-1.22.2-8.el7.x86_64 already installed and latest version
Package python-dateutil-1.5-7.el7.noarch already installed and latest version
Package php-mcrypt-5.4.16-7.el7.x86_64 already installed and latest version
Package xorg-x11-fonts-75dpi-7.5-9.el7.noarch already installed and latest version
Package xorg-x11-fonts-Type1-7.5-9.el7.noarch already installed and latest version
Package libjpeg-turbo-1.2.90-5.el7.x86_64 already installed and latest version
Package dejavu-sans-fonts-2.33-6.el7.noarch already installed and latest version
Package dejavu-serif-fonts-2.33-6.el7.noarch already installed and latest version
Package cjkuni-uming-fonts-0.2.20080216.1-53.el7.noarch already installed and latest version
Package cjkuni-ukai-fonts-0.2.20080216.1-51.el7.noarch already installed and latest version
Nothing to do
[root@usvanagiospna1 ~]# cd /tmp
[root@usvanagiospna1 tmp]# cd nagiosna
[root@usvanagiospna1 nagiosna]# ./fullinstall
ERROR: unable to read system id.
Installing on el7
Nagios Network Analyzer Installation
DATE: Mon Jan 29 15:50:09 UTC 2018
DISTRO INFO:
RedHatEnterpriseServer
7.4
x86_64
Running 'prereqs'...
prereqs step already completed - skipping
Running 'sourceguardian'...
sourceguardian step already completed - skipping
Running 'timezone'...
timezone step already completed - skipping
Running 'build_rrdtool'...
checking build system type... x86_64-pc-linux-gnu
checking host system type... x86_64-pc-linux-gnu
checking target system type... x86_64-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking whether gcc understands -c and -o together... yes
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking minix/config.h usability... no
checking minix/config.h presence... no
checking for minix/config.h... no
checking whether it is safe to define __EXTENSIONS__... yes
checking for a BSD-compatible install... /bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking for style of include used by make... GNU
checking whether make supports nested variables... yes
checking dependency style of gcc... gcc3
checking whether to enable maintainer-specific portions of Makefiles... no
checking whether make supports nested variables... (cached) yes
Audit Compilation Environment
checking for gcc... (cached) gcc
checking whether we are using the GNU C compiler... (cached) yes
checking whether gcc accepts -g... (cached) yes
checking for gcc option to accept ISO C89... (cached) none needed
checking whether gcc understands -c and -o together... (cached) yes
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for fgrep... /bin/grep -F
checking for ld used by gcc... /bin/ld
checking if the linker (/bin/ld) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /bin/nm -B
checking the name lister (/bin/nm -B) interface... BSD nm
checking whether ln -s works... yes
checking the maximum length of command line arguments... 1572864
checking how to convert x86_64-pc-linux-gnu file names to x86_64-pc-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-pc-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /bin/ld option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for ar... ar
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /bin/nm -B output from gcc object... ok
checking for sysroot... no
checking for a working dd... /bin/dd
checking how to truncate binary pipes... /bin/dd bs=4096 count=1
checking for mt... no
checking if : is a manifest tool... no
checking for dlfcn.h... yes
checking for objdir... .libs
checking if gcc supports -fno-rtti -fno-exceptions... no
checking for gcc option to produce PIC... -fPIC -DPIC
checking if gcc PIC flag -fPIC -DPIC works... yes
checking if gcc static flag -static works... no
checking if gcc supports -c -o file.o... yes
checking if gcc supports -c -o file.o... (cached) yes
checking whether the gcc linker (/bin/ld -m elf_x86_64) supports shared libraries... yes
checking whether -lc should be explicitly linked in... no
checking dynamic linker characteristics... GNU/Linux ld.so
checking how to hardcode library paths into programs... immediate
checking whether stripping libraries is possible... yes
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... yes
checking whether to build static libraries... yes
checking if gcc likes the -Werror flag... yes
checking if gcc likes the -fno-strict-aliasing flag... yes
checking if gcc likes the -Wall flag... yes
checking if gcc likes the -std=gnu99 flag... yes
checking if gcc likes the -pedantic flag... yes
checking if gcc likes the -Wundef flag... yes
checking if gcc likes the -Wshadow flag... yes
checking if gcc likes the -Wpointer-arith flag... yes
checking if gcc likes the -Wcast-align flag... yes
checking if gcc likes the -Wmissing-prototypes flag... yes
checking if gcc likes the -Wmissing-declarations flag... yes
checking if gcc likes the -Wnested-externs flag... yes
checking if gcc likes the -Winline flag... yes
checking if gcc likes the -Wold-style-definition flag... yes
checking if gcc likes the -W flag... yes
checking for long long int... yes
Checking for Header Files
checking for ANSI C header files... (cached) yes
checking for dirent.h that defines DIR... yes
checking for library containing opendir... none required
checking langinfo.h usability... yes
checking langinfo.h presence... yes
checking for langinfo.h... yes
checking for stdint.h... (cached) yes
checking for inttypes.h... (cached) yes
checking libgen.h usability... yes
checking libgen.h presence... yes
checking for libgen.h... yes
checking features.h usability... yes
checking features.h presence... yes
checking for features.h... yes
checking for sys/stat.h... (cached) yes
checking for sys/types.h... (cached) yes
checking fcntl.h usability... yes
checking fcntl.h presence... yes
checking for fcntl.h... yes
checking fp_class.h usability... no
checking fp_class.h presence... no
checking for fp_class.h... no
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for unistd.h... (cached) yes
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking math.h usability... yes
checking math.h presence... yes
checking for math.h... yes
checking sys/times.h usability... yes
checking sys/times.h presence... yes
checking for sys/times.h... yes
checking sys/param.h usability... yes
checking sys/param.h presence... yes
checking for sys/param.h... yes
checking sys/resource.h usability... yes
checking sys/resource.h presence... yes
checking for sys/resource.h... yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking float.h usability... yes
checking float.h presence... yes
checking for float.h... yes
checking stdio.h usability... yes
checking stdio.h presence... yes
checking for stdio.h... yes
checking for stdlib.h... (cached) yes
checking errno.h usability... yes
checking errno.h presence... yes
checking for errno.h... yes
checking for string.h... (cached) yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking grp.h usability... yes
checking grp.h presence... yes
checking for grp.h... yes
checking pwd.h usability... yes
checking pwd.h presence... yes
checking for pwd.h... yes
checking for an ANSI C-conforming const... yes
checking whether time.h and sys/time.h may both be included... yes
checking whether struct tm is in sys/time.h or time.h... time.h
checking for stdarg.h... yes
checking for varargs.h... no
checking for sys/param.h... (cached) yes
checking for vsnprintf... yes
checking whether vsnprintf is C99 compliant... yes
checking for snprintf... yes
checking whether snprintf is C99 compliant... yes
checking for vasprintf... yes
checking for asprintf... yes
Test Library Functions
checking for acos... no
checking for acos in -lm... yes
checking for round... yes
checking for strftime... yes
checking for vprintf... yes
checking for _doprnt... no
checking whether byte ordering is bigendian... no
checking for nl_langinfo... yes
checking for tzset... yes
checking for fsync... yes
checking for mbstowcs... yes
checking for opendir... yes
checking for readdir... yes
checking for chdir... yes
checking for chroot... yes
checking for getgid... yes
checking for getuid... yes
checking for setgid... yes
checking for setuid... yes
checking for strndup... yes
checking for strerror... yes
checking for snprintf... (cached) yes
checking for vsnprintf... (cached) yes
checking for vasprintf... (cached) yes
checking for fpclass... no
checking for class... no
checking for fp_class... no
checking for isnan... yes
checking for memmove... yes
checking for strchr... yes
checking for mktime... yes
checking for getrusage... yes
checking for gettimeofday... yes
checking for getpwnam... yes
checking for getgrnam... yes
checking for get_current_dir_name... yes
checking whether strerror_r is declared... yes
checking for strerror_r... yes
checking whether strerror_r returns char *... yes
Map/Fadvis/Madvise checking
checking for fdatasync... yes
checking for fsync... (cached) yes
checking for socket... yes
checking for getaddrinfo... yes
checking for sigwaitinfo... yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking for getpagesize... yes
checking for working mmap... yes
checking for mmap... yes
checking for munmap... yes
checking whether madvise is declared... yes
checking for madvise... yes
checking whether posix_fadvise is declared... yes
checking for posix_fadvise... yes
checking for posix_fallocate... yes
Libintl Processing
checking whether NLS is requested... yes
checking for msgfmt... /bin/msgfmt
checking for gmsgfmt... /bin/msgfmt
checking for xgettext... /bin/xgettext
checking for msgmerge... /bin/msgmerge
checking for ld used by GCC... /bin/ld -m elf_x86_64
checking if the linker (/bin/ld -m elf_x86_64) is GNU ld... yes
checking for shared library run path origin... done
checking for CFPreferencesCopyAppValue... no
checking for CFLocaleCopyCurrent... no
checking for GNU gettext in libc... yes
checking whether to use NLS... yes
checking where the gettext function comes from... libc
IEEE Math Checks
checking for fpclassify... no
checking for fpclassify with <math.h>... yes
checking for isinf... yes
checking whether isfinite is broken... no
checking if IEEE math works out of the box... yes
Resolve Portability Issues
checking tm_gmtoff in struct tm... yes
checking __tm_gmtoff in struct tm... no
checking whether sigwait has 2 arguments... yes
checking if msync with MS_ASYNC updates the files mtime... yes
checking for _NL_TIME_WEEK_1STDAY... no
checking for nl_langinfo(_NL_TIME_WEEK_1STDAY) with langinfo.h... yes
checking if realloc can deal with NULL... yes
checking if ctime_r need special care to act posixly correct... no
checking for the pthreads library -lpthreads... no
checking whether pthreads work without any flags... no
checking whether pthreads work with -Kthread... no
checking whether pthreads work with -kthread... no
checking for the pthreads library -llthread... no
checking whether pthreads work with -pthread... yes
checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE
checking if more special flags are required for pthreads... no
checking for cc_r... gcc
checking do we need malloc/malloc.h... nope, works out of the box
checking size of time_t... 8
checking size of long int... 8
Find 3rd-Party Libraries
checking dbi/dbi.h usability... no
checking dbi/dbi.h presence... no
checking for dbi/dbi.h... no
checking rados/librados.h usability... no
checking rados/librados.h presence... no
checking for rados/librados.h... no
checking tcpd.h usability... no
checking tcpd.h presence... no
checking for tcpd.h... no
checking for glib_check_version in -lglib-2.0... yes
checking glib.h usability... no
checking glib.h presence... no
checking for glib.h... no
checking for pkg-config... pkg-config
checking glib.h usability... yes
checking glib.h presence... yes
checking for glib.h... yes
checking for g_regex_new... yes
checking for png_access_version_number in -lpng... yes
checking png.h usability... yes
checking png.h presence... yes
checking for png.h... yes
checking for pango_cairo_context_set_font_options in -lpangocairo-1.0... no
checking for pkg-config... (cached) pkg-config
configure: WARNING:
* I could not find a working copy of pangocairo. Check config.log for hints on why
  this is the case. Maybe you need to set LDFLAGS and CPPFLAGS appropriately
  so that compiler and the linker can find libpangocairo-1.0 and its header files. If
  you have not installed pangocairo, you can get it either from its original home on
     http://ftp.gnome.org/pub/GNOME/sources/pango/1.28
  You can find also find an archive copy on
     http://oss.oetiker.ch/rrdtool/pub/libs
  The last tested version of pangocairo is 1.28.4.
       LIBS=-lpng -lm  -lglib-2.0   -lpangocairo-1.0 -lpango-1.0 -lcairo -lgobject-2.0 -lglib-2.0
   LDFLAGS=
  CPPFLAGS= -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include   -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/harfbuzz -I/usr/include/freetype2 -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/include/pixman-1 -I/usr/include/libpng15 -I/usr/include/libdrm
checking for pango_font_map_create_context... no
checking for xmlParseFile in -lxml2... yes
checking libxml/parser.h usability... no
checking libxml/parser.h presence... no
checking for libxml/parser.h... no
checking libxml/parser.h usability... yes
checking libxml/parser.h presence... yes
checking for libxml/parser.h... yes
configure: error: Please fix the library issues listed above and try again.
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'build_rrdtool'
Reason: Added Code Wraps around large output.
Thanks for the output. It looks like the packages are all installed but I think the Library path cannot file one of the required libraries NNA needs to compile the rrdtool.
Can you run the following commands as root and post the output to the ticket?
find / -name libpango*
ldconfig -v
bosecorp
Post by bosecorp »
[root@usvanagiospna1 ~]# find / -name libpango*
ldconfig -v
/usr/lib64/libpangomm-1.4.so.1
/usr/lib64/libpango-1.0.so.0
/usr/lib64/libpango-1.0.so.0.4000.4
/usr/lib64/libpangocairo-1.0.so.0
/usr/lib64/libpangocairo-1.0.so.0.4000.4
/usr/lib64/libpangomm-1.4.so.1.0.30
/usr/lib64/libpangoft2-1.0.so.0
/usr/lib64/libpangoft2-1.0.so.0.4000.4
/usr/lib64/libpangoxft-1.0.so.0
/usr/lib64/libpangoxft-1.0.so.0.4000.4
/usr/lib64/libpangox-1.0.so.0
/usr/lib64/libpangox-1.0.so.0.0.0
[root@usvanagiospna1 ~]# ldconfig -v
ldconfig: Can't stat /libx32: No such file or directory
ldconfig: Path `/usr/lib' given more than once
ldconfig: Path `/usr/lib64' given more than once
ldconfig: Can't stat /usr/libx32: No such file or directory
/usr/lib64/atlas:
        libtatlas.so.3 -> libtatlas.so.3.10
        libsatlas.so.3 -> libsatlas.so.3.10
/usr/lib64/mysql:
        libmysqlclient.so.18 -> libmysqlclient.so.18.0.0
/usr/local/lib64:
/lib:
        libudev.so.1 -> libudev.so.1.6.2
        libsystemd.so.0 -> libsystemd.so.0.6.0
        libsystemd-login.so.0 -> libsystemd-login.so.0.9.3
        libsystemd-journal.so.0 -> libsystemd-journal.so.0.11.5
        libsystemd-id128.so.0 -> libsystemd-id128.so.0.0.28
        libsystemd-daemon.so.0 -> libsystemd-daemon.so.0.0.12
        libnss_mymachines.so.2 -> libnss_mymachines.so.2
        libnss_myhostname.so.2 -> libnss_myhostname.so.2
        libpam_misc.so.0 -> libpam_misc.so.0.82.0
        libselinux.so.1 -> libselinux.so.1
        libpamc.so.0 -> libpamc.so.0.82.1
        libgpg-error.so.0 -> libgpg-error.so.0.10.0
        libz.so.1 -> libz.so.1.2.7
        libpcreposix.so.0 -> libpcreposix.so.0.0.1
        libpcprofile.so -> libpcprofile.so
        libauparse.so.0 -> libauparse.so.0.0.0
        libmemusage.so -> libmemusage.so
        libaudit.so.1 -> libaudit.so.1.0.0
        libnss_nisplus.so.2 -> libnss_nisplus-2.17.so
        libpam.so.0 -> libpam.so.0.83.1
        libnss_nis.so.2 -> libnss_nis-2.17.so
        libcap-ng.so.0 -> libcap-ng.so.0.0.0
        libnss_hesiod.so.2 -> libnss_hesiod-2.17.so
        libnss_files.so.2 -> libnss_files-2.17.so
        libcap.so.2 -> libcap.so.2.22
        libnss_dns.so.2 -> libnss_dns-2.17.so
        libattr.so.1 -> libattr.so.1.1.0
        libsepol.so.1 -> libsepol.so.1
        libnss_db.so.2 -> libnss_db-2.17.so
        libcrack.so.2 -> libcrack.so.2.9.0
        libnss_compat.so.2 -> libnss_compat-2.17.so
        libbz2.so.1 -> libbz2.so.1.0.6
        libnsl.so.1 -> libnsl-2.17.so
        libpcrecpp.so.0 -> libpcrecpp.so.0.0.0
        libm.so.6 -> libm-2.17.so
        libpcre32.so.0 -> libpcre32.so.0.0.0
        libdl.so.2 -> libdl-2.17.so
        libdw.so.1 -> libdw-0.168.so
        libcrypt.so.1 -> libcrypt-2.17.so
        libasm.so.1 -> libasm-0.168.so
        libcidn.so.1 -> libcidn-2.17.so
        libpcre16.so.0 -> libpcre16.so.0.2.0
        libc.so.6 -> libc-2.17.so
        libpcre.so.1 -> libpcre.so.1.2.0
        libanl.so.1 -> libanl-2.17.so
        libelf.so.1 -> libelf-0.168.so
        libSegFault.so -> libSegFault.so
        libgcrypt.so.11 -> libgcrypt.so.11.8.2
        libBrokenLocale.so.1 -> libBrokenLocale-2.17.so
        libresolv.so.2 -> libresolv-2.17.so
        ld-linux.so.2 -> ld-2.17.so
        libfreeblpriv3.so -> libfreeblpriv3.so
        liblzma.so.5 -> liblzma.so.5.2.2
        libutil.so.1 -> libutil-2.17.so
        libfreebl3.so -> libfreebl3.so
        libthread_db.so.1 -> libthread_db-1.0.so
        librt.so.1 -> librt-2.17.so
        libgcc_s.so.1 -> libgcc_s-4.8.5-20150702.so.1
        libdb-5.3.so -> libdb-5.3.so
        libstdc++.so.6 -> libstdc++.so.6.0.19
        libpthread.so.0 -> libpthread-2.17.so
/lib64:
ldconfig: Cannot stat /lib64/libgraphite2.so: No such file or directory
        libglibmm_generate_extra_defs-2.4.so.1 -> libglibmm_generate_extra_defs-2.4.so.1.3.0
        libXfont.so.1 -> libXfont.so.1.4.1
        libzip.so.2 -> libzip.so.2.1.0
        libpangox-1.0.so.0 -> libpangox-1.0.so.0.0.0
        libmcrypt.so.4 -> libmcrypt.so.4.4.8
        libpangoxft-1.0.so.0 -> libpangoxft-1.0.so.0.4000.4
        libpangoft2-1.0.so.0 -> libpangoft2-1.0.so.0.4000.4
        libpangocairo-1.0.so.0 -> libpangocairo-1.0.so.0.4000.4
        libpango-1.0.so.0 -> libpango-1.0.so.0.4000.4
        libpangomm-1.4.so.1 -> libpangomm-1.4.so.1.0.30
        libthai.so.0 -> libthai.so.0.1.6
        libcairomm-1.0.so.1 -> libcairomm-1.0.so.1.4.0
        libglibmm-2.4.so.1 -> libglibmm-2.4.so.1.3.0
        libjpeg.so.62 -> libjpeg.so.62.1.0
        libbfd-2.25.1-32.base.el7_4.1.so -> libbfd-2.25.1-32.base.el7_4.1.so
        libopcodes-2.25.1-32.base.el7_4.1.so -> libopcodes-2.25.1-32.base.el7_4.1.so
        libgettextsrc-0.19.8.1.so -> libgettextsrc-0.19.8.1.so
        libnl-xfrm-3.so.200 -> libnl-xfrm-3.so.200.23.0
        libnl-idiag-3.so.200 -> libnl-idiag-3.so.200.23.0
        libnetsnmptrapd.so.31 -> libnetsnmptrapd.so.31.0.2
        libgettextlib-0.19.8.1.so -> libgettextlib-0.19.8.1.so
        libnetsnmpmibs.so.31 -> libnetsnmpmibs.so.31.0.2
        libfastjson.so.4 -> libfastjson.so.4.0.0
        libnetsnmphelpers.so.31 -> libnetsnmphelpers.so.31.0.2
        libGeoIPUpdate.so.0 -> libGeoIPUpdate.so.0.0.0
        libGeoIP.so.1 -> libGeoIP.so.1.5.0
        libseccomp.so.2 -> libseccomp.so.2.3.1
        libmpc.so.3 -> libmpc.so.3.0.0
        libXtst.so.6 -> libXtst.so.6.1.0
        libXaw.so.7 -> libXaw7.so.7.0.0
        libXpm.so.4 -> libXpm.so.4.11.0
        libXi.so.6 -> libXi.so.6.1.0
        libXft.so.2 -> libXft.so.2.3.2
        libXcursor.so.1 -> libXcursor.so.1.0.2
        libGL.so.1 -> libGL.so.1.2.0
        libXdamage.so.1 -> libXdamage.so.1.1.0
        libxkbfile.so.1 -> libxkbfile.so.1.0.2
        libXxf86vm.so.1 -> libXxf86vm.so.1.0.0
        libXmuu.so.1 -> libXmuu.so.1.0.0
        libXmu.so.6 -> libXmu.so.6.2.0
        libXfixes.so.3 -> libXfixes.so.3.1.0
        libXt.so.6 -> libXt.so.6.0.0
        libXrender.so.1 -> libXrender.so.1.3.0
        libXext.so.6 -> libXext.so.6.4.0
        libX11.so.6 -> libX11.so.6.3.0
        libX11-xcb.so.1 -> libX11-xcb.so.1.0.0
        libXdmcp.so.6 -> libXdmcp.so.6.0.0
        libepoxy.so.0 -> libepoxy.so.0.0.0
        libpng15.so.15 -> libpng15.so.15.13.0
        libhesiod.so.0 -> libhesiod.so.0.0.0
        libXfont2.so.2 -> libXfont2.so.2.0.0
        libfontconfig.so.1 -> libfontconfig.so.1.7.0
        libfontenc.so.1 -> libfontenc.so.1.0.0
        libxcb-xvmc.so.0 -> libxcb-xvmc.so.0.0.0
        libxcb-xv.so.0 -> libxcb-xv.so.0.0.0
        libxcb-xtest.so.0 -> libxcb-xtest.so.0.0.0
        libxcb-xselinux.so.0 -> libxcb-xselinux.so.0.0.0
        libxcb-xkb.so.1 -> libxcb-xkb.so.1.0.0
        libxcb-xinput.so.0 -> libxcb-xinput.so.0.1.0
        libxcb-xinerama.so.0 -> libxcb-xinerama.so.0.0.0
        libxcb-xfixes.so.0 -> libxcb-xfixes.so.0.0.0
        libxcb-xf86dri.so.0 -> libxcb-xf86dri.so.0.0.0
        libxcb-xevie.so.0 -> libxcb-xevie.so.0.0.0
        libxcb-sync.so.1 -> libxcb-sync.so.1.0.0
        libxcb-shm.so.0 -> libxcb-shm.so.0.0.0
        libxcb-shape.so.0 -> libxcb-shape.so.0.0.0
        libxcb-screensaver.so.0 -> libxcb-screensaver.so.0.0.0
        libxcb-res.so.0 -> libxcb-res.so.0.0.0
        libxcb-render.so.0 -> libxcb-render.so.0.0.0
        libxcb-record.so.0 -> libxcb-record.so.0.0.0
        libxcb-randr.so.0 -> libxcb-randr.so.0.1.0
        libxcb-present.so.0 -> libxcb-present.so.0.0.0
        libxcb-glx.so.0 -> libxcb-glx.so.0.0.0
        libxcb-dri3.so.0 -> libxcb-dri3.so.0.0.0
        libxcb-dri2.so.0 -> libxcb-dri2.so.0.0.0
        libxcb-dpms.so.0 -> libxcb-dpms.so.0.0.0
        libxcb-damage.so.0 -> libxcb-damage.so.0.0.0
        libxcb-composite.so.0 -> libxcb-composite.so.0.0.0
        libxshmfence.so.1 -> libxshmfence.so.1.0.0
        libpixman-1.so.0 -> libpixman-1.so.0.34.0
        libdrm_radeon.so.1 -> libdrm_radeon.so.1.0.1
        libdrm_nouveau.so.2 -> libdrm_nouveau.so.2.0.0
        libmpfr.so.4 -> libmpfr.so.4.1.1
        libcollection.so.2 -> libcollection.so.2.1.0
        libref_array.so.1 -> libref_array.so.1.2.1
        libdrm_intel.so.1 -> libdrm_intel.so.1.0.0
        libtirpc.so.1 -> libtirpc.so.1.0.10
        libdrm_amdgpu.so.1 -> libdrm_amdgpu.so.1.0.0
        libini_config.so.3 -> libini_config.so.3.2.0
        libbasicobjects.so.0 -> libbasicobjects.so.0.1.0
        libdrm.so.2 -> libdrm.so.2.4.0
        libaio.so.1.0.0 -> libaio.so.1.0.0
        liblvm2cmd.so.2.02 -> liblvm2cmd.so.2.02
        libpciaccess.so.0 -> libpciaccess.so.0.11.1
        libgbm.so.1 -> libgbm.so.1.0.0
        libxcb.so.1 -> libxcb.so.1.1.0
        libXau.so.6 -> libXau.so.6.0.0
        libtevent.so.0 -> libtevent.so.0.9.31
        libglapi.so.0 -> libglapi.so.0.0.0
        libdevmapper-event-lvm2.so.2.02 -> libdevmapper-event-lvm2.so.2.02
        libkms.so.1 -> libkms.so.1.0.0
        libtalloc.so.2 -> libtalloc.so.2.1.9
        libdevmapper-event.so.1.02 -> libdevmapper-event.so.1.02
        libSM.so.6 -> libSM.so.6.0.1
        libhandle.so.1 -> libhandle.so.1.0.3
        libICE.so.6 -> libICE.so.6.3.0
        libparted.so.2 -> libparted.so.2.0.0
        libopts.so.25 -> libopts.so.25.15.0
        libpath_utils.so.1 -> libpath_utils.so.1.0.1
        libparted-fs-resize.so.0 -> libparted-fs-resize.so.0.0.0
        libevent_pthreads-2.0.so.5 -> libevent_pthreads-2.0.so.5.1.9
        libisccfg-export.so.90 -> libisccfg-export.so.90.0.7
        libevent_openssl-2.0.so.5 -> libevent_openssl-2.0.so.5.1.9
        libisc-export.so.95 -> libisc-export.so.95.2.1
        libevent_extra-2.0.so.5 -> libevent_extra-2.0.so.5.1.9
        libirs-export.so.90 -> libirs-export.so.90.0.1
        liblwres.so.90 -> liblwres.so.90.0.5
        libdns-export.so.100 -> libdns-export.so.100.1.1
        libisccfg.so.90 -> libisccfg.so.90.0.7
        libteamdctl.so.0 -> libteamdctl.so.0.1.5
        libisccc.so.90 -> libisccc.so.90.0.4
        libjansson.so.4 -> libjansson.so.4.10.0
        libisc.so.95 -> libisc.so.95.2.1
        libdns.so.100 -> libdns.so.100.1.1
        libjson-c.so.2 -> libjson-c.so.2.0.1
        libbind9.so.90 -> libbind9.so.90.0.8
        libevent_core-2.0.so.5 -> libevent_core-2.0.so.5.1.9
        libsoup-gnome-2.4.so.1 -> libsoup-gnome-2.4.so.1.8.0
        libevent-2.0.so.5 -> libevent-2.0.so.5.1.9
        libpolkit-gobject-1.so.0 -> libpolkit-gobject-1.so.0.0.0
        libnfsidmap.so.0 -> libnfsidmap.so.0.3.0
        libverto-tevent.so.1 -> libverto-tevent.so.1.0.0
        libaio.so.1 -> libaio.so.1.0.1
        libldap-2.4.so.2 -> libldap-2.4.so.2.10.7
        libpolkit-agent-1.so.0 -> libpolkit-agent-1.so.0.0.0
        librpmio.so.3 -> librpmio.so.3.2.2
        libcryptsetup.so.4 -> libcryptsetup.so.4.7.0
        libdevmapper.so.1.02 -> libdevmapper.so.1.02
        librpm.so.3 -> librpm.so.3.2.2
        liblvm2app.so.2.2 -> liblvm2app.so.2.2
        libcurl.so.4 -> libcurl.so.4.3.0
        libcgroup.so.1 -> libcgroup.so.1.0.41
        libpci.so.3 -> libpci.so.3.5.1
        libssh2.so.1 -> libssh2.so.1.0.1
        libsysfs.so.2 -> libsysfs.so.2.0.1
        libbtrfs.so.0 -> libbtrfs.so.0.1
        libharfbuzz-icu.so.0 -> libharfbuzz-icu.so.0.10302.0
        libnm.so.0 -> libnm.so.0.1.0
        libssl3.so -> libssl3.so
        libsoup-2.4.so.1 -> libsoup-2.4.so.1.8.0
        libsmime3.so -> libsmime3.so
        libnsspem.so -> libnsspem.so
        libgnutls.so.28 -> libgnutls.so.28.43.0
        libnss3.so -> libnss3.so
        libnsssysinit.so -> libnsssysinit.so
        libyaml-0.so.2 -> libyaml-0.so.2.0.4
        liblber-2.4.so.2 -> liblber-2.4.so.2.10.7
        libpyglib-2.0-python.so.0 -> libpyglib-2.0-python.so.0.0.0
        libutempter.so.0 -> libutempter.so.1.1.6
        libestr.so.0 -> libestr.so.0.0.0
        libmount.so.1 -> libmount.so.1.1.0
        libpipeline.so.1 -> libpipeline.so.1.2.3
        libnuma.so.1 -> libnuma.so.1
        libprocps.so.4 -> libprocps.so.4.0.0
        libfipscheck.so.1 -> libfipscheck.so.1.2.1
        libgudev-1.0.so.0 -> libgudev-1.0.so.0.2.0
        libqrencode.so.3 -> libqrencode.so.3.4.1
        libtspi.so.1 -> libtspi.so.1.2.0
        librpmsign.so.1 -> librpmsign.so.1.2.2
        libomapi.so.0 -> libomapi.so.0.0.0
        libdhcpctl.so.0 -> libdhcpctl.so.0.0.0
        libndp.so.0 -> libndp.so.0.0.0
        libjson.so.0 -> libjson.so.0.1.0
        libuser.so.1 -> libuser.so.1.5.0
        libslapi-2.4.so.2 -> libslapi-2.4.so.2.10.7
        liblapacke.so.3 -> liblapacke.so.3.4.2
        libpwquality.so.1 -> libpwquality.so.1.0.2
        librpmbuild.so.3 -> librpmbuild.so.3.2.2
        libldap_r-2.4.so.2 -> libldap_r-2.4.so.2.10.7
        libgpgme.so.11 -> libgpgme.so.11.8.1
        libgpgme-pthread.so.11 -> libgpgme-pthread.so.11.8.1
        libpth.so.20 -> libpth.so.20.0.27
        libcpupower.so.0 -> libcpupower.so.0.0.0
        libicutest.so.50 -> libicutest.so.50.1.2
        libnetsnmpagent.so.31 -> libnetsnmpagent.so.31.0.2
        libiculx.so.50 -> libiculx.so.50.1.2
        libicule.so.50 -> libicule.so.50.1.2
        libkrb5support.so.0 -> libkrb5support.so.0.1
        libicuio.so.50 -> libicuio.so.50.1.2
        libkrb5.so.3 -> libkrb5.so.3.3
        libicui18n.so.50 -> libicui18n.so.50.1.2
        libkrad.so.0 -> libkrad.so.0.0
        libicudata.so.50 -> libicudata.so.50.1.2
        liblapack.so.3 -> liblapack.so.3.4.2
        libproxy.so.1 -> libproxy.so.1.0.0
        libkdb5.so.8 -> libkdb5.so.8.0
        libmodman.so.1 -> libmodman.so.1.0.0
        libnetfilter_conntrack.so.3 -> libnetfilter_conntrack.so.3.6.0
        libfreetype.so.6 -> libfreetype.so.6.10.0
        libk5crypto.so.3 -> libk5crypto.so.3.1
        libkmod.so.2 -> libkmod.so.2.2.10
        libblkid.so.1 -> libblkid.so.1.1.0
        libmozjs-17.0.so -> libmozjs-17.0.so
        libss.so.2 -> libss.so.2.0
        libpython2.7.so.1.0 -> libpython2.7.so.1.0
        libavahi-common.so.3 -> libavahi-common.so.3.5.3
        libmnl.so.0 -> libmnl.so.0.1.0
        libavahi-client.so.3 -> libavahi-client.so.3.2.9
        libgssrpc.so.4 -> libgssrpc.so.4.2
        libgssapi_krb5.so.2 -> libgssapi_krb5.so.2.2
        libxslt.so.1 -> libxslt.so.1.1.28
        libssl.so.10 -> libssl.so.1.0.2k
        libexslt.so.0 -> libexslt.so.0.8.17
        libverto.so.1 -> libverto.so.1.0.0
        libsemanage.so.1 -> libsemanage.so.1
        libsefs.so.4 -> libsefs.so.4.0.4
        libnetsnmp.so.31 -> libnetsnmp.so.31.0.2
        libseaudit.so.4 -> libseaudit.so.4.5
        libustr-1.0.so.1 -> libustr-1.0.so.1.0.4
        libqpol.so.1 -> libqpol.so.1.7
        libcrypto.so.10 -> libcrypto.so.1.0.2k
        libnl.so.1 -> libnl.so.1.1.4
        libpoldiff.so.1 -> libpoldiff.so.1.3.3
        libgfortran.so.3 -> libgfortran.so.3.0.0
        libxtables.so.10 -> libxtables.so.10.0.0
        libapol.so.4 -> libapol.so.4.4
        libsensors.so.4 -> libsensors.so.4.4.0
        libnettle.so.4 -> libnettle.so.4.7
        libiptc.so.0 -> libiptc.so.0.0.0
        libhogweed.so.2 -> libhogweed.so.2.5
        libip6tc.so.0 -> libip6tc.so.0.1.0
        libpcap.so.1 -> libpcap.so.1.5.3
        libip4tc.so.0 -> libip4tc.so.0.1.0
        libsnappy.so.1 -> libsnappy.so.1.1.4
        libicuuc.so.50 -> libicuuc.so.50.1.2
        libicutu.so.50 -> libicutu.so.50.1.2
        p11-kit-trust.so -> libnssckbi.so
        libtasn1.so.6 -> libtasn1.so.6.5.3
        libgmp.so.10 -> libgmp.so.10.2.0
        libgettextpo.so.0 -> libgettextpo.so.0.5.4
        libmagic.so.1 -> libmagic.so.1.0.0
        libkeyutils.so.1 -> libkeyutils.so.1.5
        libidn.so.11 -> libidn.so.11.6.11
        libdbus-glib-1.so.2 -> libdbus-glib-1.so.2.2.2
        libdaemon.so.0 -> libdaemon.so.0.5.0
        liblzo2.so.2 -> liblzo2.so.2.0.0
        libexpat.so.1 -> libexpat.so.1.6.0
        libwrap.so.0 -> libwrap.so.0.7.6
        liblua-5.1.so -> liblua-5.1.so
        libasprintf.so.0 -> libasprintf.so.0.0.0
        libnewt.so.0.52 -> libnewt.so.0.52.15
        libslang.so.2 -> libslang.so.2.2.4
        libquadmath.so.0 -> libquadmath.so.0.0.0
        libp11-kit.so.0 -> libp11-kit.so.0.3.0
        libnfnetlink.so.0 -> libnfnetlink.so.0.2.0
        libharfbuzz.so.0 -> libharfbuzz.so.0.10302.0
        libnl-route-3.so.200 -> libnl-route-3.so.200.23.0
        libblas.so.3 -> libblas.so.3.4.2
        libcroco-0.6.so.3 -> libcroco-0.6.so.3.0.1
        libnl-nf-3.so.200 -> libnl-nf-3.so.200.23.0
        libedit.so.0 -> libedit.so.0.0.42
        libaprutil-1.so.0 -> libaprutil-1.so.0.5.2
        libsoftokn3.so -> libsoftokn3.so
        libnl-genl-3.so.200 -> libnl-genl-3.so.200.23.0
        libcairo.so.2 -> libcairo.so.2.11400.8
        libunistring.so.0 -> libunistring.so.0.1.2
        libnl-3.so.200 -> libnl-3.so.200.23.0
        libgomp.so.1 -> libgomp.so.1.0.0
        libsqlite3.so.0 -> libsqlite3.so.0.8.6
        libext2fs.so.2 -> libext2fs.so.2.4
        libacl.so.1 -> libacl.so.1.1.0
        libgdbm.so.4 -> libgdbm.so.4.0.0
        libe2p.so.2 -> libe2p.so.2.3
        libgdbm_compat.so.4 -> libgdbm_compat.so.4.0.0
        libsasl2.so.3 -> libsasl2.so.3.0.0
        libgiomm-2.4.so.1 -> libgiomm-2.4.so.1.3.0
        libteam.so.5 -> libteam.so.5.3.4
        libnssdbm3.so -> libnssdbm3.so
        libgthread-2.0.so.0 -> libgthread-2.0.so.0.5000.3
        libcairo-script-interpreter.so.2 -> libcairo-script-interpreter.so.2.11400.8
        libgobject-2.0.so.0 -> libgobject-2.0.so.0.5000.3
        libassuan.so.0 -> libassuan.so.0.4.0
        libEGL.so.1 -> libEGL.so.1.0.0
        libgmodule-2.0.so.0 -> libgmodule-2.0.so.0.5000.3
        libnl-cli-3.so.200 -> libnl-cli-3.so.200.23.0
        libglib-2.0.so.0 -> libglib-2.0.so.0.5000.3
        libgirepository-1.0.so.1 -> libgirepository-1.0.so.1.0.0
        libsigc-2.0.so.0 -> libsigc-2.0.so.0.0.0
        libapr-1.so.0 -> libapr-1.so.0.4.8
        libgmpxx.so.4 -> libgmpxx.so.4.4.0
        libffi.so.6 -> libffi.so.6.0.1
        libavahi-core.so.7 -> libavahi-core.so.7.0.2
        libhistory.so.6 -> libhistory.so.6.2
        libreadline.so.6 -> libreadline.so.6.2
        libdbus-1.so.3 -> libdbus-1.so.3.7.4
        libuuid.so.1 -> libuuid.so.1.3.0
        libmenu.so.5 -> libmenu.so.5.9
        libformw.so.5 -> libformw.so.5.9
        libform.so.5 -> libform.so.5.9
        libdb-5.3.so -> libdb.so
        libgpm.so.2 -> libgpm.so.2.1.0
        libtinfo.so.5 -> libtinfo.so.5.9
        libtic.so.5 -> libtic.so.5.9
        libgio-2.0.so.0 -> libgio-2.0.so.0.5000.3
        libxml2.so.2 -> libxml2.so.2.9.1
        libnssutil3.so -> libnssutil3.so
        libpanelw.so.5 -> libpanelw.so.5.9
        libpanel.so.5 -> libpanel.so.5.9
        libcom_err.so.2 -> libcom_err.so.2.1
        libplds4.so -> libplds4.so
        libplc4.so -> libplc4.so
        libnspr4.so -> libnspr4.so
        libncursesw.so.5 -> libncursesw.so.5.9
        libncurses.so.5 -> libncurses.so.5.9
        ld-linux-x86-64.so.2 -> ld-2.17.so
        libpopt.so.0 -> libpopt.so.0.0.0
        libncurses++w.so.5 -> libncurses++w.so.5.9
        libncurses++.so.5 -> libncurses++.so.5.9
        libmenuw.so.5 -> libmenuw.so.5.9
/lib/sse2: (hwcap: 0x0000000004000000)
/lib/i686: (hwcap: 0x0008000000000000)
/lib64/sse2: (hwcap: 0x0000000004000000)
/lib64/tls: (hwcap: 0x8000000000000000)
Lets remove and reinstall the troublesome packages as I feel they may be not installed correctly or corrupted.
Run these commands as root to remove and reinstall the packages.
yum remove pango pango-devel
ldconfig -v
Now see if you can install NNA.
bosecorp
Post by bosecorp »
same error
Resolving Dependencies
--> Running transaction check
---> Package pango.x86_64 0:1.40.4-1.el7 will be installed
---> Package pango-devel.x86_64 0:1.40.4-1.el7 will be installed
Dependencies Resolved
Package Arch Version Repository Size
Installing:
pango x86_64 1.40.4-1.el7 rhel-7-server-rpms 275 k
pango-devel x86_64 1.40.4-1.el7 rhel-7-server-rpms 316 k
Transaction Summary
Install 2 Packages
Total download size: 591 k
Installed size: 3.9 M
Is this ok [y/d/N]: y
Downloading packages:
(1/2): pango-1.40.4-1.el7.x86_64.rpm | 275 kB 00:00:00
(2/2): pango-devel-1.40.4-1.el7.x86_64.rpm | 316 kB 00:00:00
Total 760 kB/s | 591 kB 00:00:00
Running transaction test
Transaction test succeeded
Running transaction
Installing : pango-1.40.4-1.el7.x86_64 1/2
Installing : pango-devel-1.40.4-1.el7.x86_64 2/2
Verifying : pango-1.40.4-1.el7.x86_64 1/2
Verifying : pango-devel-1.40.4-1.el7.x86_64 2/2
Installed:
pango.x86_64 0:1.40.4-1.el7 pango-devel.x86_64 0:1.40.4-1.el7
Complete!
root@usvanagiospna1 nagiosna]# ldconfig -v
/usr/lib64/atlas:
/usr/lib64/mysql:
/usr/local/lib64:
/lib:
/lib64:
