Monitor pfSense v.2 NRPE2
AWS
Re: Monitor pfSense v.2 NRPE2
Post by AWS »
Making progress.
Results:
[root@nagios libexec]# ./check_nrpe -H 10.1.1.254 -c check_load
OK - load average: 0.39, 0.17, 0.08|load1=0.390;15.000;30.000;0; load5=0.171;10.000;25.000;0; load15=0.079;5.000;20.000;0;
If you think this is a pfS error, let me know and I can change over to that forum. I don't want you to think I'm abusing your knowledge and asking you to troubleshoot a system error that isn't part of Nagios. :-)
Thanks again,
AWS
AWS wrote:Making progress.
Results:
Thanks again,
AWS
this mean it is working.. That is what is supposed to output..
Now you just need to add the the services in Nagios XI Core Config Manager and you are set.
AWS
Post by AWS »
I believe it is already. No? In my "Configure Service", "Load", on the "Monitoring" tab, in the Monitor Service with this command... (Advanced users only) I have check_nrpe!check_load!-a '-w 15,10,5 -c 30,20,10' (built by the wizard, not by me). The result I get from this on the "Service Status Detail" page is CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
Do I need to change my check_nrpe!check_load!-a '-w 15,10,5 -c 30,20,10' command to something like ./check_nrpe -H 10.1.1.254 -c check_load -a 'w 15,10,5 -c 30,20,10' instead?
EDIT: Tried that and it doesn't like the config - it wouldn't save it. So the command seems to be ok. My money is now on pfS being the problem.
Thanks for your help.
AWS
AWS wrote:I believe it is already. No? In my "Configure Service", "Load", on the "Monitoring" tab, in the Monitor Service with this command... (Advanced users only) I have check_nrpe!check_load!-a '-w 15,10,5 -c 30,20,10' (built by the wizard, not by me). The result I get from this on the "Service Status Detail" page is CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
AWS
Is this in Nagios XI?
AWS
Post by AWS »
Yes, within Nagios XI.
AWS
don't change anything there.
make sure
Check command* = check_nrpe
make sure
Command view = $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
Go to Configure -> Core Config Manager -> Services -> Modify icon next to service
$ARG1$ = check_load
This would be for the load... change per service
AWS
Post by AWS »
Yeah, it all checks out correctly, as you outlined.
AWS
Is it working now?
If not you may not need to set the $ARG2$ because it was already on the client.
AWS
Post by AWS »
OH MY! That's it! I removed text in $ARG2$ and now it's working great!
thank you very much for your help. I've been working on again/off again on this for a long time and could never make it work. thanks so much. :D
AWS
No problem. Glad it is working.
