monitor switch device temperature and fan speed by OID
npolovenko
Re: monitor switch device temperature and fan speed by OID
Post by npolovenko »
@ inas.labib, Not sure if i'm looking at the right plugin but it doesn't look like you're passing the right argument: --protocol=3
-L, --protocols=<authproto>,<privproto>
<authproto> : Authentication protocol (md5|sha : default md5)
<privproto> : Priv protocole (des|aes : default des)
For example, --protocols=md5,des.
Looks like we do have a few other plugins on the Exchange you could try:
https://exchange.nagios.org/index.php?o ... sco%20temp
Also, which one of these plugins are you actually running, 0.35 or 0.41?
https://exchange.nagios.org/directory/P ... re/details
inas.labib
Post by inas.labib »
Thanks for suggesting plugin check_env_stats.py (https://exchange.nagios.org/directory/P ... cs/details)
I want to know whether this plugin only supports snmp version 1 when tried it keeps timing out. As we are using v3 we need to authenticate to progress
SNMP is already configured here in the switch end.
Also for the plugin check_snmp_tempertature its works for temperature
Alarm at 10
SNMPv3 login
SNMPv3 AuthNoPriv login : wdpauth, md5
Retrieving SNMP table 1.3.6.1.4.1.9.9.13.1.3.1.2 to find sensor attribute names
got 1.3.6.1.4.1.9.9.13.1.3.1.2.1 : Chassis Temperature Sensor
match found for ., now set to retrieve 1.3.6.1.4.1.9.9.13.1.3.1.3.1
Getting SNMP data for oids1.3.6.1.4.1.9.9.13.1.3.1.3.1
got 1.3.6.1.4.1.9.9.13.1.3.1.3.1 : . = 46
OK - . Temperature is 46C
Is it possible to check fan speed with this same plugin.
npolovenko
@inas.labib, Yes, looks like that plugin only supports SNMP v1.
To check the fan speed you can try to find another plugin on the Exchange:
https://exchange.nagios.org/directory/P ... ironmental
If you know the fan oid number you may try running a simple check_snmp command:
./check_snmp -H xxxxx -C community -P 3 -o xxxxx.xxxxxx
inas.labib
Thanks for the support team, We got the results as expected
Glad to hear it! Are we alright to close this up then?
inas.labib
Yes you can mark this closed
