mysqldump failing after changing cert
kyang
Re: mysqldump failing after changing cert
Post by kyang »
Are we still on the same issue? I don't exactly follow?
Does still pertains to your original topic/post?
If you are receiving apply config errors please create a new thread with the errors you are getting so we could work those out in a different forum and are not mixing two in one.
Thanks!
markmerchant
Post by markmerchant »
I finally got this fixed ( I hope ). DB issue was not related to the cert change.
Looks like that was entirely coincidental. Real cause was that DB was not restarting
from sudoers properly. Was able to convince my SAs to do sudoers exactly as it
appeared from the installer.
markmerchant wrote:I finally got this fixed ( I hope ). DB issue was not related to the cert change.
That would do it, yes, all entries we have made to the sudeors are going to be required for one thing or another.
Let us know if you hit other speed bumps.
