Log Out Option -Post Upgrade
Re: Log Out Option -Post Upgrade
I have done the manual upgrade.
Yes I have backup before upgrade 5.2.9.
Regards,
Neha Singh.
Regards,
Neha Singh.
Höegh
Höegh
It could be that there is a old PHP cache file on the server that is hiding the logout link from the GUI.
To clear them out, login to the server as root and delete all of the files in this folder.
Then restart apache by running
Then login to the XI GUI and see if the Logout link is there.
/var/lib/php/sessionCode: Select all
service httpd restartBe sure to check out our Knowledgebase for helpful articles and solutions!
Hi ,
Cleared the cache sessions from the above locations and restarted httpd service.
No changes reflected.
Again the same issue.
Thanks & Regards,
Neha Singh.
Thanks & Regards,
Neha Singh.
Höegh
Höegh
npolovenko
- Support Tech
@hoegh, What kind of web browser are you using and what version? I did experience similar behavior when I ran XI on a raspberry pi.
We are using Internet explorer
Google chrome
Microsoft Edge browsers.
I have tried clearing cache and cookies also from browser but it is not working.
Regards,
Neha.
Google chrome
Regards,
Neha.
Höegh
Höegh
npolovenko
- Support Tech
@hoegh, Could you send in your Nagios XI System Profile so I can review it?
To send us your system profile. Login to the Nagios XI GUI using a web browser.
Save the profile.zip file, upload it to a cloud storage of your choice and share a link with me via pm.
After that please post something in this thread to bring it back up in the support queue.
We have sent you our Nagios XI System Profile.
Please review it.
Regards,
Mayur
Please review it.
Regards,
Mayur
Höegh
Höegh
npolovenko
- Support Tech
@hoegh, I received the profile and shared it with our techs.
I see a lot the following entries in the apache log file:
Can you upload the following two files so that we can check to see what happened to your authentication settings?
AuthType not set!Code: Select all
/etc/httpd/conf.d/nagiosxi.conf
/etc/httpd/conf.d/nagios.conf As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy.
Hi Npolovenko,
I have PM you the below 2 config files.
Kindly check and let me know if any changes is required.
Thanks & Regards,
Neha Singh.
Thanks & Regards,
Neha Singh.
npolovenko
- Support Tech
@hoegh, I received your message but didn't receive the files. After you select the files on your computer don't forget to click on the "upload" button. Can you try one more time?
