it is running on ---
Oracle Solaris 10 1/13 s10s_u11wos_24a SPARC
Swap Memory issue on Solaris Server
kyang
Re: Swap Memory issue on Solaris Server
I tested it on Solaris 10, and it works just as the other servers you mentioned before.But again, we are having issue with only two servers other servers are working fine. and on server end we have checked swap memory seems all are ok, ( Output has been pasted in earlier chat )
Can you show me the check_command of the "Swap Usage" service from the CCM?
Please find attached screen shot for command details and output.
It's possible that plugin got corrupted during the extraction. I found a forum post, describing a similar issue here:
https://support.nagios.com/forum/viewto ... =6&t=32343
How did you install the solaris agent? Did you follow the document below?
https://assets.nagios.com/downloads/nag ... _Agent.pdf
