Thanks @eloyd, I really appreciate your help! Regards.eloyd wrote:Here's something to help you do that: Inside the Nagios XI Configuration Wizard (Config -> Configuration Wizards) is a wizard called "Nagiostats Wizard." RUN THIS ONE! It's basically Nagios monitoring itself as a monitoring tool, as opposed to Nagios monitoring its own operating system.
Specifically, I recommend that you monitor the following:
The first two should cause alarm if they are greater than 1000ms (1 second). This means that Nagios is having problems getting host and service checks to execute.
- Average Active Host Latency
- Average Active Service Latency
- Average Host Execution Time
- Average Service Execution Time
- Active Host Checks 15min
- Active Service Checks 15min
The second two should cause alarm if they are greater than maybe 20,000ms (20 seconds). You will want to adjust this number as you add services and hosts. This indicates, on average, how long it takes to complete a host or service check.
The last two are mainly just counters that you can see over time to get an idea of how many host and service checks you are performing averaged over 15 minute intervals.
All of these data can help you with capacity planning as far as resources to add to the machine.
Good luck!
Nagios XI Hardware Recomendations
Re: Nagios XI Hardware Recomendations
Martin Pedros
You are welcome.
Good luck!
Good luck!
Dear @kyang, yes they have answered my questions very kindly. Sorry, I thought the case was closed by putting the green tilde. Regards.
Martin Pedros
kyang
No worries at all! I'll be closing this thread!
If you have any more questions, feel free to create another thread.
Thanks for using the Nagios Support Forum!
