Monitoring of Data Store in VCenter
Re: Monitoring of Data Store in VCenter
Thanks for the assist, @mcapra!
@amitgupta19, let us know if you have further (related) questions.
amitgupta19
Post by amitgupta19 »
In the services.cfg file we are passing the 4 arguments only.
For Eg i am attaching the screenshot of the same.
But my command is defined to accept the user name and password. But i am not able to find where the variables User11 and User12 are defined.
Can you help me to find where the user11 and user12 could have been defined mentioned in the command.
Also if i decide to upgrade to the 0.7.1 version, what would be the steps so that my previously setup monitoring of the VCenter does not gets impacted?
if it is setting $USER12$ and $USER13$ these are set in the resources.cfg
The path to this file is located in the nagios.cfg and it may be in the same directory as your nagios.cfg
