NIC monitoring
Re: NIC monitoring
I have to agree with @gwakem
keerthi.seetharaman
Re: NIC monitoring
Post by keerthi.seetharaman »
Hello Team,
Can you please provide us with the complete command as when we tried to execute it says that check_network is not unknown command.
Please suggest what needs to be done
Thanks & Regards,
Keerthi Prashanth Seetharaman
gwakem
Re: NIC monitoring
Post by gwakem »
Everything you need has been provided multiple times and is detailed in these links. I have posted them below for ease of reading.
Providing a single command would not accomplish what you are looking to do because for that command to work, you must also modify the nsclient.ini or use the nagios XI NCPA wizard, which would handle all of this for you. Please take the time to read the links provided.
NSCLient or NCPA setup - https://support.nagios.com/kb/article/n ... s-781.html
Step by step how to do this with NCPA - using the wizard. (I suggest this one) https://assets.nagios.com/downloads/nag ... 1478524848
Griffin Wakem
Re: NIC monitoring
Thanks @gwakem
